Canski
Everything posted by Canski
My ecologist certainly made his.
It always go one way or the other. They don't call me Mr Lucky for nothing.
Only one got me on this and it hurts. The tiler. Not much money but just the principle. Probably the best tiling I have seen and when he was there he was quick and tidy. He couldn't manage more than 5 hrs a day though and unbeknown to me when I met him had no license or vehicle so his visits were limited to when he could find a labourer with a vehicle. 🙂 I felt sorry for him I think because he had so much potential to get a thriving business going. I just gave him one advance too many which most likely went up his nose and I ended up finishing the last few return visit bits myself. DON'T PAY THE FERRYMAN. This is so true and if you are supplying the materials make sure they help you format the shopping list. It saves hold ups which invariably lead to bigger charges. I always do this with my brickwork customers and it saves me money. Also Nods sites are spotless. There is no better way to prevent chaos than not presenting trades with chaos. My advice is to take time out to plan ahead and keep some work that you can do yourself while the other trades are working. This way you can be on site when queries do arise. My back just loved 210 m2 of porcelain paving followed by fencing and landscaping.
I believe they need to assess the 30 minute meter readings for a few days before the tariffs change. I got fed up with having to learn a different language to speak to BG to sort out their metering problems and recently moved to Octopus at no charge,. The transition went smoothly and we have been up and running with them for about a month. We are on their cosy tariff which gives us 8 hrs of half price electricity at various times during the day. All has been good so far and their customer service for a couple of minor queries has been excellent.
Finaly have our Completion certificate
Canski replied to Buzz's topic in General Self Build & DIY Discussion
I was dancing when I realised there was no CIL here. Unfortunately it was exchanged for an expensive section 106. That was a short party. -
Years ago I made the mistake of putting 100 mm rock wool into a 4x2 stud wall. Bear in mind the 4x2 comes out at 97 x 47mm. We squeezed it in and fixed the plasterboard only for the fixings to pop.
Well done. The final stages are seeming to take an age on mine. We will get there by year 2 -
Oh thanks. I can’t bring myself to build them for a loss. Maybe the same applies to the OP. We all know it would be a better house if demolished and rebuilt but I doubt if the numbers would add up.
It may be me. I managed an Oh Lordy Lordy out of him for not fitting MVHR 😂😂
You are not going to get brickwork or blockwork supplied and fitted for those rates. I'm unsure about the other items.
We had meters installed by British Gas and they were spot on up to that point. When we raised some issues concerning the smart meter they turned to shite. Some of the idiots I spoke to in their call centre were absolutely useless. Remembering that they had no exit fee I have just swapped to Octopus who have been OK up to now.
B&B edge & outer leaf of cavity are not parallel
Canski replied to Tony L's topic in Bricklaying, Blockwork & Mortar
Don’t worry about this. You saved having to cavity fill by having the trench blocks to below the beams. Cavity tray is just DPC but wider. It gives you an extra level of damp protection. It’s not expensive and would be installed quicker than cavity filling. You would have to install it over your air bricks anyway so it’s just an extension of this. Get some good tape for the corners though. Start planning the superstructures. -
Honestly that's not the end of the world. A 200 mm cavity instead of 150 which is what it looked like from the other photo would have been a problem. Your cavity trays will be from the top of the first course of block above DPC (+ 225mm ) down to DPC on the outer skin (0.00) Make sure your insulation is in and photographed before these go on. Move on to the next stage. -
Yep you will need to submit your section 80 and wait for the reply. It was only a week or so for me.
This is what I mentioned yesterday. It looks more like 200 to me from your photo. That’s why I asked how they were going to infill the ends of the beams.
Please tell me what size cavities you are supposed to have.
This is true. I’d like this question to be asked …. What happens between the ends of the beams ? And just out of interest ( it’s good to see the holes on the blues filled in) but why with black mortar ? Nothing wrong with it but why ?
No that’s nuts. Maybe they took it off to point the blues but even so.
do what all the young ones do at my place. Get to the door then send a text.
Methods for setting up & using site datums?
Canski replied to Alan Ambrose's topic in General Construction Issues
No I used them to check the setting out on all of the external walls. What is this luncheon thing that you refer to ? -
Of course but there's usually a few of these on a house build. I calculated many diagonals on my build and marked an A3 drawing up with them on and laminated it ready for site use during setting out. -
Remember Pythagorus is your best friend when checking setting out. -
No no no. Don't build anything different than what is on the beam and block drawing. Every action has a reaction and if you don't follow the beam and block drawing you may discover this first when you come to a S&VP. If you have a situation like the section on the left simply lay the DPC at the level of the bottom of the beams then lay the 'slips' on this and lay the block on top of these with a mortar bed in between.
Window position in a timber frame house (and damp issues)
Canski replied to Kuro507's topic in Timber Frame
This would help divert the water to the outside but I’d be more concerned about how the water is getting in. Is there a drip groove below the cill ? I can’t tell from the photos. -
For levels I had a 100 mm board fixed to the fence. I had the 2 FFL plus 1 m marked on there for the 2 houses. I had an engineer come out and mark out the building. While he was there I got him to extend the long line of the brickwork and marked it on the rear fence with a nail at the front I marked it next to the pavement. I then had the rear wall points extended and marked on the fence. I also took a couple of measurements from a fixed point to the corners of the house in a few places just in case. I had a 2 stakes with a nail in it for this and used 2 tapes to get the corner points. again to set out the brickwork corners. Levels were taken with a laser from the FFL points from the fence. Once up to DPC and everything is checked you don't need them again. I was glad I did it as the digger lost a couple of corner points whilst manouvering.
