trialuser
Everything posted by trialuser
I'm building a 2000 sq foot timber frame extension to a small Galloway farm cottage. When it's done we will effectively live in the extension 95% of the time and the original house will be for hobbies and the rellies. The extension is well insulated and will hopefully be fairly airtight. We are having MVHR and I would therefore like to install fairly airtight doors in the two doorways which will link to the original cottage which leaks like a sieve. The other doors in the extension will be the usual vertical planked oak veneer type, so ideally I'd like to get some that look similar but preferably come as a pre hung set complete with air sealing. Do they exist, or can effective seals be fitted to standard doors, I imagine it's the bottom gap which will be the problem. Any ideas or links very welcome.
Getting broadband set up for new build
trialuser replied to Ben G's topic in Networks, AV, Security & Automation
Have you considered 4g. We live in rural Wigtownshire and have just binned Bt as the speed was about 2 Mb/s down and 0.3 up. We now have a TP link 4g router and an EE unlimited data sim and get about 60 down and 20 up fo a quid or two less than the BT cost.- 7 replies
- openreach
- broadband installation
@ProDave Know it well, we had a friend there and we used to take the kids paddling in the ford when they were small, they are in their 20's now so you were probably there at the time. I wanted the Highlands but the boss won with D&G, that and the midges. @Russell griffiths Windows - I too hated paying over 3K for four blokes and a spider crane for a day to lift my windows into position so I can now level and seal them, but it seems to be the going rate. I suppose you are also paying for them to take the risk of breakages. @Rainmaker sorry no modern social meeedya stuff, yours looks a big project, good luck.
- 29 replies
Triple. Just seen you are in South Oxon, we have just moved fron Upton near Didcot to SW Scotland, small world.
- 29 replies
Fixing a mirror to plasterboard wall
trialuser replied to canalsiderenovation's topic in General Construction Issues
I've just bought some geefix https://www.ebay.co.uk/itm/Trade-pack-of-25-Geefix-fixings/124269874930?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 Not use any yet (no plasterboard yet) but I was suckered by the videos, principle looks good https://www.geefix.com/charlie-diyte-youtube-video-review/ -
Norrsken, 65 square M, inc 2 entrance doors and a 4M lift and slide, 21 items, 30k ish inc vat, 8 weeks to deliver, no fitting, very pleased with them, great company to deal with.
- 29 replies
Cheers. I won't be able to do that now as the windows will fit within the thickness of the timber frame wall panels and only have about <10mm gap all round. I thought this was correct from a heat loss aspect. Might be able to do that with the tin corner flashing I suppose.
Just to tag onto this as it now affects me. Is the above (compriband) suitable for sealing the outside gap between the timber frame of the aluclad window and the tyvek covered frame,. The windows will sit within the depth of the wall panel, possibly flush with the outside or possibly with the 10mm of aluclad proud of the external face of the frame. All the youtube stuff I have seen is about the flanged style USA windows. Can I just X cut the opening, fold the edges, patch the corners with tyvek and illbrook me315 , fit the windows, compriband the outside, foam the inside and clad up to the aluclad window with my cedar and tin. That's the plan so far. Do I need extra waterproofing to the top of the wall under the bottom of the window cill for example? Drawings or videos would be especially useful. Thanks
Ah. A technique I use is to withdraw completely and re enter the hole repeatedly until the cave ins pack tight and stop. I was reluctant to type that!
yes https://www.amazon.co.uk/Extra-Long-Metre-Long-Masonry-Drill/dp/B01MSFG1Y6/ref=sr_1_6?dchild=1&keywords=3+foot+sds&qid=1607198885&sr=8-6 I too have walls like that. These are ok for the price, I find it's the splined end which is hammered which gets knackered before the tip. Perhaps they are no good for sds max?
I have a worcester oil condensing combi and have experienced two 9f 855 faults which the manual says is fuel supply. One was - water in the fuel. If you have recently run ouit of oil the fill of oil may have stirred up any possible layer of water at the bottom of the tank. This can then knacker the fuel pump apparently. The second fault was a blocked condensate bottle, I washed this out and all good since.
Pozi Joist deflection and cantilevers
trialuser replied to BartW's topic in General Structural Issues
Sorry, floor size is approx 6M wide x 17M long. I used Stevenson and Kelly as supplier. -
Just another set of numbers. I have easijoists, 6345 long, (approx 6050 clear span) 304 x 147, 400mm centres, 8.4mm deflection, slight bounce if you jump, otherwise fine. Partitions and ceilings not yet in place. Not sure if these will make it better or worse. Cost for approx 17M run was just under 4.5K inc vat and delivery -
I think that was in response to my post, thanks. I was hoping to initially fit a willis heater, prior to an ashp, then leave it in situ as a backup or possibly as a dump for a little bit of excess solar. Would that be possible? Presumably if I just connected it in series with the flow to the ufh from the ashp it might throttle the flow rate a bit much? Cheers.
@Nickfromwales, for my sanity, could you indicate on here where the flow and return from the boiler or ashp would join into this please. And also where the ufh loops pump sits. Thanks
Cold water manifold, how big is toooo big
trialuser replied to Russell griffiths's topic in General Plumbing
Following a bit more research, I'm going to use copper. We definately have a mice issue. I assume that apart from a central point of isolation, there isn't't really a huge benefit to the manifold system. -
Thanks everyone. I had been looking at uponor pipe, the shrink fit which needs a special expander tool. I didn't realise hep pipe was ok for constantly circulating hot water, that makes things much easier. @MikeGrahamT21 what are you linking to, I cant tell from the page, cheers. -
@Nickfromwales, or anyone. As I understand it, one of the benefits of the distribution manifold is the absence of joints on the pipe journey, so this implies plastic pipe. Can you suggest a plastic pipe that is suitable for a HRC that doesn't need fancy tools to join. I'm struggling to find anything. Many thanks -
Cladding details
trialuser replied to Russell griffiths's topic in General Self Build & DIY Discussion
Thanks jamiled -
Cladding details
@jamieled and @dnb, thanks very much re the intumescent fire stop. Can either of you suggest a product or supplier. I have done some googling but everything I have found is going to be very expensive, perhaps that's just the way it is. I will be having tin cladding to the first floor and vertical cedar or siberian larch to the ground floor. cavity will be 25mm + 25mm ground floor. and 25mm +45mm first floor. the tin overlaps the wood slightly. Thanks -
Cladding details
I would also be interested to see any details / pics, particularly detailing how you can have a ventillated (not just vented) cavity and firestopping, Still struggling with this detail. -
Thanks very much, very comprehensive. I have used tek screws with square profiled steel roofs and I know exactly what you mean about the thump ? Did you fix say at the tops and lay half a dozen or so and chalk a line to align the fixings, or use a gauge rod, or how? I think I'm asking how best to get a decent straight line of screws. It also hadn't occured to me to fix the row under the ridge in the valley, but makes sense. I'm glad that the flat tek washer seals well on the curve of the corrugated profile, I didn't fancy removing and replacing thousands of flat washers with the baz ones One more thing, do you notice any issues with thermal expansion, my roof slope is about 4.2M and black, so potentially the tin could want to try and lengthen by a couple of mm Thanks again.
Thanks JamesP ☺️
Anyone. Have I done whatever is necessary to bring this to the attention of Cpd? I though if you put an @ sign in front of a name they got a notification, is that right? Thanks
@Cpd. Your roof looks great. I am probably about to change from standing seam to crinkly tin as it's a quarter of the price and my wife really likes it. I see from your photos that you used the type of flat washered tek screw usually used when fixing through the trough of square profile sheets. From my research it seems it is usual to use a fixing with a cupped baz type washer when fixing through the crest of corrugated panels. Can I ask how yours are standing up to weathering, do they seal properly? Most of the cupped washer fixings I can find are either for fibre cement, or else they wont accept the colour matching cap. Thanks
