Nickfromwales
    346
  1. You just need to unscrew the bush too, which either leaves you with a 1/2 or 3/4” bsp thread. You then just buy the reducing bush for £2 and screw the vent into that. PTFE is your friend here.
  2. Near the beds, as a fail safe. If the existing one is a few years old, replace it. ’vans rely heavily on the airflow through floor / lower wall vents, which most block up in winter, to allow gas appliances like cookers and fires to breathe / vent. Modern boilers are “room sealed” and have a coaxial flue to outdoors; smaller inner pipe ejects the fumes and outer pulls air in for combustion. Balanced flues need air from the room. Stayed in a large static once, and it was like a colander lol. Wife was paranoid so refused to let me leave the gas fire on overnight in the living room (at night this was the adult / spare bedroom) and it was like a fridge once that got turned off.
  3. Needs to be equal pressure opposing on all sides so the fitting and insert don’t deform.
  4. Weak concrete pads at the start and end of the run, and then multiples more every 1200mm or less will make life easier here. Be mindful that you cannot compact / whack anything retrospectively, so do as much of that as you need to, prior to installing the pipe.
  5. Just use trapped gulleys on the furthest one, to manage leaf litter / other debris?
  6. @flanagaj Beware the plywood skirt preventing ventilation / adventitious airflow to any gas burning appliances. Please tell me you have more than one CO1 detector in there? Oh, and congrats on being on site, just be safe!
  7. You can cut the T out and revert to compression 16mm fittings to connect this lot back up. You use 15mm comp joints but they have 16mm nuts / inserts / olives to adapt from 15>16mm. A lot of decent merchants carry these nowadays if you just ring around. Not sure how much pipe drops out of the T so hard to advise. Can you take that bit of insulation off to show what ‘we’re’ working with?
  8. Get another vent and swap the gauge out. You have one on the red expansion vessel control group where you fill / top up.
  9. 1). Why? You don’t need this. Just close off one side of each of the 3 loops with the manual blank caps and jump on the ends of the manifold. Simple and a zero spend / rework.
  10. 🫡 If it’s to the EV then is the intention for the EV charger to have internet connectivity or for the cat cable to get you a set of CT clamps back at the head / meter? Doing this for a current client atm, but was thinking to run a second (separate, duct-grade) CAT6 to the carport to offer up a future WAP there. Cables cheap enough to put a redundant run in (<35m). So the hybrid cable @Adrian Walker linked to, is that cat cable intended for CT clamps? Only now dipping my toes in the EV charger waters…..
  11. It’ll also be an acoustically poor solution, so with moderate to hard rain the sound will be notable to the room interior. A blown-in insulation would be the very best solution for weaving around the metal webs and those associated impossible to get to gaps, and give a huge boost to sound deadening. As @ProDave says, this is something you need to stop all wires with and get a solution to, before moving any further forwards. Just had Gordon Lewis on site pumping my current clients roof with Warmcell (blown-in cellulose) and he’s done a fantastic job getting every nook and cranny packed full of the good stuff. 👌 Abandon the rigid insulation in the roof, and preserve that for the vertical walls only. Arcitect will need to rerun the intersitial condensation analysis before pulling any trigger. Airtightness is moot, the original house will underperform most likely, just all about draft proofing at this point; plus obvs managing repeat cold bridging, and maxing out on the (properly installed) insulation.
  12. Is that a down pipe it eventually goes into, and is it metal?
  13. Common tbh. Water defo backs up and fills the combustion chamber. Loads of British Gas installs suffered from the connection (non return) of the condensate > soil pipes, mostly in cold snaps where the valve internals (massively reduced internal bore) freeze up. @LLL just cut or disconnect the condensate pipe under the boiler and let it drain into a bucket to get you back up and running Are you 100% sure this isn’t frozen? Or hasn’t been frozen and has now thawed out and cleared?
  14. The VA service manual should be your friend here?
  15. The rf controls are plug and play, with the windows addressable to open / close etc in tandem (or more) at the press of one button. Not seen 24v options but I’ve not seen every model / iteration. Velux tech should be able to give you concise information regarding which models / units can be manipulated the way you want them to be. Lots of options, so it may be advantageous to better understand what’s available so you can get the best results.
  16. Glad you have a way forward. The 20a option is a perfectly good ‘way out’. If you’re the only person living there then it’s fine to deem yourself competent, but if you’ve family to consider then get a sparky in and enjoy the safety of knowing that the jobs been done to the current standard and tested accordingly. Better safe than brown bread. It’s not much money in the grand scheme.
  17. Link Just get 28mm male > 1” bsp connectors to make these off in compression, if you don’t want to solder.
  18. Big time doesn’t mean in pvc Heavy gauge conduit or galv trunking. What he said. First time I’ve heard of that cable tbh. Every day is a school day.
  19. I was just wondering about needing a fire rating for the cavity, if attached, as on garages I’ve had to close the sides and heads of openings where there’s habitable spaces immediately off them.
  20. The elephant in the room is that this is terminally ill though? If water / moisture are a constant then this’ll keep recurring. The only cure would be to replace the twin and earth with HO5 or 7, for a long term solution, and swap the metal boxes for PVC ones.
  21. That one is DIY friendly and at a price even you’d like
  22. Seems to be very few instances though? Ive been quite intensively ‘around’ a respected member of the STA and a major supplier (German gear) and I’ve not heard any of them over the years mention panels going en-flambé or DC isolators doing likewise. If these are disconnected under load then expect the worst, but that’s damage done in ignorance by dimwits or idle thumbs.
