I'd be quite concerned if my architect was basing his preferred construction method on vehicular impact . I'd expect a slightly more 'relevant' argument.....wouldn't you?
Ok, daft question , but what's the appeal of these boilers to the extent that you've chosen to chase this up? They're not mega cheap so what gives?
That's pretty much the point where I'd ask him to shut the door on the way out
Soil stack to 110 drain -- the wrong way and right way
Nickfromwales replied to TerryE's topic in Waste & Sewerage
A new hand saw such as a Jacksaw is my weapon of choice. Nice wide blade to keep the cut straight and true. The multi tools tend to melt / cut through so be prepared to have to do some extra de-burring if you use that. I do use them for this task occasionally, but only in adverse situations. -
2nd place is still a trophy mate -
One of a few decent looking ones. http://m.ebay.co.uk/itm/Manthorpe-Tile-Access-Panel-GLTAP-500-/272270041907?nav=SEARCH -
I usually cut a section of plywood out and fix a tile on with 4 or 5 50p size blobs of mastic. The tile the gets grouted as normal and looks flawless. I tell the customer to keep at least one full box of tiles, and the idea is if you need to get in ever, you just cover the tile in gaffa tape and whack it in the middle to break it. Remove it and clean up, change whatever and stick a fresh tile back. Fwiw most modern taps are all services from above . I only put an access option on these kind of jobs as there was also an air admittance valve ( on top of the white pipe shown ) so was more worried about that failing tbh. -
Wall or floor, ceramic / porcelain / natural......
Nickfromwales replied to Nickfromwales's topic in Wall Tiles & Tiling
FYI @sphannaby In addition to the above..,.. Remember that the 2- 3mm gap between the top of the batten / ply and the underside of the tray is to allow the bead of SF to create a cushion so the tray can flex slightly rather than sit on the timber directly. That's to allow for movement whilst your in the shower, singing and scrubbing. If your tray has a centre leg or more than one centre leg, leave these wound up and just set the tray by the outer ones. Leave the SF to cure ( 24 hours ) and THEN wind the other legs out to hand tight only. -
Yup. Don't use the add-on upstands as they're useless without sealant anyway. Plus they come between the side of the tray and the wall, so stop you getting a good fix ( as your then relying on the double sided sticky tape to hold both bonded surfaces together where the upstand goes ). Dry fit the shower tray and set the height and level to suit. Draw around the upper edge with a pencil, and if you can reach do the same at the underside. Fit a batten around the 2 / 3 sides stopping 50mm short of each outer corner ( to allow fitting of the skirt / plinth ). A better option is to cut strips of 18mm ply and fit that like skirting board, so it sits on the floor and supports the underside of the tray in one solid section. Bond that to the walls with the Sikaflex ( SF ) and fix with a few screws going through into the studs, or rawlplug into the masonry. Set the battens 2-3mm shy of the pencil line and put a 12mm bead of SF atop for the tray to be offered down into / onto. Once you've got to that stage, draw the tray 15-20mm or so away, re-goop the top of the ply / batten, and then run two parallel lines of SF around the wall, one at half tray depth and another just shy of the top pencil line. Push the tray home against the SF and move it around a bit of possible to ensure the goop has taken well. DONT FORGET TO MAKE SURE THE PLASTIC FILM HAS BEEN REMOVED FIRST, ( if the tray has it fitted, some don't ). CHECK AND DOUBLE CHECK AS ITS SOMETIMES HARD TO SEE IT . Then follow the method described, in the thread I linked, re forming the SF upstand whilst the SF is all still wet / masking etc. Simples -
We have a site toilet... At last.
Nickfromwales replied to ProDave's topic in General Self Build & DIY Discussion
ugh. -
I somehow missed the part where I recommended the Hitachi gas nailer under my pseudonym. "Sparrow Fart" for the uninitiated. Thanks again, Ian .
Don't forget to whittle a loo roll holder -
Have a read of this and see if that will suffice cone back with questions, no worries. -
Like his n hers? I bet you get whichever is coldest as your outnumbered ? -
Don't you mean bog? Happy days. -
If you don't hear from me ever again...............
Hmmm, so you didn't keep the living roof then? Congrats ! Piss up and a bbq sounds good to me
Thanks Jane. There are many rides at the funfair not just this roller coaster . Feel free to choose another, just please keep your arms and legs inside the carriage at all times until the ride stops ! The managment.
Heatmiser UFH wiring centre with TS
Nickfromwales replied to sphannaby's topic in Underfloor Heating
Did they give a reason for including the additional circulation pump ? -
Very well said, and pretty much exactly what we're all about Actis can by all means come here and comment, as long as it's factual and not commercial. I for one would welcome it, but I doubt if they ( after reading the content of this thread fully ) would open themselves up to ridicule as it's doesn't appear that they would be able to defend their previous practices, and I fear it would just descend into a marketing squabble, much as we've seen before. Id be happy to be proved wrong.
It's what I would do, and have done on just about every stack I've ever connected to. No issues yet, and I'd assume that if shitty black and grey waste water had been leaking anywhere, particularly inside the envelope of a customers home, I'd be the first to know . -
Top access shower wastes
Nickfromwales replied to sphannaby's topic in Bathrooms, Ensuites & Wetrooms
Alternate grille design -
Just bought this McAlpine one. A very good unit, finishes flush, chrome plated solid brass and a huge top access bucket ( hair trap ) for easy full cleaning. Most other 90mm wastes have a sort of mushroom cover which is elevated, sitting on plastic prongs. They don't last long if you inadvertently step on them. I'll be buying the above from now on, and bin / sell the crap ones that usually get supplied with the trays. I'll take some pics tomorrow. -
Ah, good point about the 'user definable' height with the adjustable frame of the Geberit. The last one I fitted I purposely jacked up by a good 35mm, above normal WC pan height, as the punter had bad knees. There are 'comfort' height floor standing WC pans around, as well as Doc M suites which also adopt a higher pan level. All jokes aside, and believe me I've done well here to fight the urge, you may well find it a good idea to jack the height up a bit for comfort, and the side effect will be the ease of connection for the ground floor loo. Im not sure about where the hang ups are coming from with having a pushfit at the base of the tee, eg a triple pushfit socket tee, as using double socket connectors, bends and 45's etc is commonplace. Amen to that. You get one shot with these.
