Ufh, look at these plans please.
Nickfromwales replied to Russell griffiths's topic in Underfloor Heating
Stick to one manifold. As long as the runs are 100m or less you’ll be perfectly ok. As peter says, ask Wunda for the auto balancing actuators and you don’t need to do any commissioning whatsoever. Just plug and play, and go to the pub. Where the pipes are congested, just insulate the flows and leave the returns bare. If you’re on an ASHP then stick to 150mm centres to keep the water volume high. -
As above. Fit and forget.
Also, make sure you’re cleaning out all the bits of goop and PTFE tape as they’ll go into the float valve and cause it to fail early.
Wrong fitting You need a tap connector not a female 1/2” BSP as shown. The tap connector will have the seal inside it already ( assuming Hepworth ) so nowhere to go wrong.
They’re not cheap for anything robust, so decide how much you want to part with before mentioning car port or “solar pergola”..... This is what is in the NSBRC if you want to go and see one in the flesh; https://en.irfts.com/pergosolar/ The one there is 2 panels deep ( landscape ) by 3 panels wide, measuring in at 6m x 2.5m give or take. Supply and fit for that is ~£10k including delivery and installation, so a big chunk of change! The aluminium system above is very nice tbh and includes such trinkets as a hidden rainwater runoff system, which has the down pipes in the legs, but after hearing the price most run off in the nearest opposite direction. I’d consider putting an in roof system over an oak frame setup if you want the best bang for your buck. At 4x7 you could get an on-roof setup with 16 panels ( 4x4 landscape ) but for a much nicer look you’ll need 4.5x 7.2 to allow for an in roof setup which will look a LOT nicer. 16 panels @285w pp will give you 4.5kWp gross output, so would not be insignificant, but you could go up to 330w pp and then you’d be looking at over 5.2kWp. Do a survey for shading as that will dictate what you’ll end up with from each solar day, and then start the maths as to what is sensible to invest vs the estimated break even point and RoI over the next 25 years.
Moisture resistant plasterboard is ample, if used sensibly and in conjunction with a tanking solution. Why spend stupid amounts of money on something that requires tanking ANYWAY? If you want something waterproof then cement board ( Aqua panel etc ) is a one-up option but if you’re tanking is still overkill imo. Ive a 1/4 century of high-end bathroom installs under my belt btw, so am not making these comments without care and confidence.
- 9 replies
- shower recess
- shower niche
(and 3 more)
Chock it up, and then wind the legs up as per above. Almost every single DW I’ve ever fitted has the screw at the front to raise / lower the leg/s at the the rear. RTM ( Read the manual ) or google the fitting instructions for details. ?. Replace the wooden board with cement board / other. Why the ‘support’? Timber floor?
Sizing a boiler for UFH and greedy hot water guzzlers
Nickfromwales replied to MrsDeS's topic in Boilers & Hot Water Tanks
Beware fitting a bigger device, if your existing supply and pipe work won’t effect the desired results -
Depends on whether it’s all being squeezed down one 15mm pipe which is T’eed off repeatedly, or through well thought out and dedicated radial supplies. The difference that can make to the same cold mains is significant. Most combis have 15mm inlet & outlet whereas an UVC / TS have 22mm so can convey much more water / have lower paths of resistance. Designing a new system from scratch makes this possible, but solving a retro fit is a bloody nightmare as you’re constrained by the existing pipe work etc. -
Another option could be a floor standing high flow combi , ( Worcester Bosch do a tidy one iirc, used in a lot of B&B’s / small guest houses ), and a 2-300L cold mains accumulator to fortify cold mains delivery, but you’d still need a small / medium buffer to compliment the gas vs UFH situation to get your condensing range reliable. The issue is the length of hot water draw off duration stated in the OP. No accumulator will defeat that problem, unless you’ve a room full of them. -
Crossed with Peter. -
Yes. As long as it’s a dedicated ‘high flow’ unit it’ll do the job. Most you can expect in reality is two “ok” showers simultaneously, or one excellent shower, but two is possible. This is remembering that an instant hot water heater, of whatever fuel origin, is ‘cold mains dependant’, so if during the two ok showers someone flushed the loo, you’re going to know all about it. Same if any white appliances are set to run whilst you’re showering that would be a disaster. Discipline is number one in this scenario, so with unsympathetic teenagers in the mix I’d forget anything instantaneous here @MrsDeS. Boiler + thermal store is what I’d fit here, or a bigger than necessary UVC ( unvented ( mains pressurised )) cylinder, but you’ll then suffer the longer term ownership issues when said water thieves fly the nest and it’s just you guys there. As you have UFH ( and why have you oversized the rads if you’re on gas not a heat pump ?!? ) I’d say fit the TS ( thermal store ) as it’ll give you a buffer for running the UFH and give you your condensing range, ( which you won’t get at very low temps btw ). Downside is you need to keep the TS hot all summer for DHW ( same as you would with an UVC, but typically hotter than ) so losses need to be considered and managed. Best way is to put it in the airing cupboard to warm your trollies all year round. Cold mains needs to be surveyed before deciding, as you can’t get a pint out of a half pint pot, and you’ll probably need to have all the cold mains in 22mm and pipe accordingly for your needs. -
?. I have a POE switch and am about to hook up a single AP for my kids to be able to use their iPads outside. Did you just link the AP’s direct to your POE switch and off to go? With a single AP I assumed that would work, but with multiple AP’s I couldn’t get anything working without the key ?
Sounds like the turn screw adjuster on the fill ( float ) valve is set too high and water is getting to the top of the overflow pipe and then discharging to the WC pan. Can you remove the flush plate, and then observe if the water is indeed getting to the top of the internal overflow ? That pipe should be dead centre of the cistern when you look inside. If it’s not getting to that height and the unit is brand new, it’s likely the cistern flush valve insert isn’t seated properly. Check Grohe / YouTube for service info and follow that. They’re quite informative. I fit Geberit routinely so am a not completely familiar with Grohe stuff, sorry.
Why don’t you buy one and use it to survey the house? You may find one in the middle of the L is sufficient. Or that two may just become advantageous. I’m fitting Ubiquity AP’s for my current clients after great success on previous installs. The paperwork suggests needing the safety gateway / router doo-dah, but you only need the ‘key’, as if you’re connecting to a BB suppliers own hub it will fight with the Ubiquity gateway. Good to remember, also, that it’s the device that jumps to the best signal, vs the AP’s ‘grabbing’ the device when it gets ‘near’. Devices will look for the strongest signal and will jump from A.P. to AP by themselves.
tanking around floor core holes?
Nickfromwales replied to magnethead's topic in Bathrooms, Ensuites & Wetrooms
Check that it's 15mm not 16mm ( as most MLC pipe comes as as standard ) or you'll have to keep converting back to 15mm everywhere -
Shower trays with shallow traps
Nickfromwales replied to Nick1c's topic in Bathrooms, Ensuites & Wetrooms
Do you have a pic of the junction between the floor and the tray edge? -
Not sure TBH as I've never disassembled one, just cannot think of what else that could be..... Possibly a stray blanking plug installed by a manufacturer of one or other bits of kit upstream? My best guesses I'm afraid!
FWIW, I would not fit a factory finished tray flush with the floor. You should, ideally, go for about 15mm of tray being proud of the FFL so you have some 'meat' there to seal back against for water-proofing immediately outside the tray ( aka the splash area ). -
Looks like one of the shields around the moving part of the ball valve to me. Can you strip that out and rule it out?
You have to tile it then -
https://www.ebay.co.uk/itm/15mm-27mm-PIPE-INSULATION-10m-thermal-lagging-protection-hot-cold/401593150594?var=671333738851&hash=item5d80d12c82:g:luoAAOSwBFVbjjgR Just slides over the pipe, but a 2 man job for long runs. Glass-fibre rods ( electricians ones ) will make short work of threading them through. -
Were you planning on having the tray finish flush to the final floor covering? If not, does the 5mm present any other issues? That's a nice looking tray, not seen those before, so I'd go for that unless 5mm will cause issue elsewhere? Any photos available of the actual waste / underside of the tray? -
https://www.screwfix.com/p/ph2-drywall-screwdriver-bits-ph2-2-pack/6623v
Today's dumb plumbing question - Chrome Waste.
Nickfromwales replied to ProDave's topic in Waste & Sewerage
Q1, yes, just a simple 32mm compression fitting. Do NOT lube up the compression side that goes onto the chrome tail. That needs to be dry fit to get the rubber to ‘grab’ the chrome surface. Q2, dunno. ? Suck it and see, but the trap should just screw straight on.
