Nickfromwales
    346
  1. 90L here if you do go for the kettle option; https://www.guinnessworldrecords.com/world-records/67159-largest-kettle
  2. Buy a dirt cheap DIY fit ASHP and fit a well insulated *500L UVC. Telford will spray extra insulation on for not much £££. Yes, electricity is very simple and convenient, and if that's your choice then it will work. Simple and quick. Larger storage means you can load-shift off E10 instead of E7, *so you can top up midday too if needed. Run the ASHP whenever you like, it's cheap enough to use not to worry about when, but anytime it's running on E10 you benefit even further . Introducing wood burning into the heating / DHW system is a big leap from simplicity so be very careful about how you introduce that into your equations ( as the installation costs will be big ). Difficult to say much more as you demonstrate a preference for options with a small capital expenditure. Log gasification attracts RHI, but you'd need room and at least 1000L of buffer tank, ideally more, plus a guaranteed / maintainable abundance of seasoned fuel stock.
  3. Not really. If a registered installer goes to a job, they should see what’s ‘going to go wrong’ and make it safe. Same way when “we” cut a moulded plug off an appliance “we’re” supposed to mutilate that plug so it cannot be plugged in so the live cut off end cannot hurt someone who doesn’t know the danger of doing so. Regardless of the timeline, the last person there working on oil is responsible for at least identifying the possible dangers and capping off the old tank. If you went to a job where there was a shed that had been removed, and an SWA was sat on the grass still made off but just the breaker turned off, what would you do? If you ask for a little badge that says you’re fit, competent and qualified, you are then ordained to go above and beyond in all you do. In the instance of this oil spill, that due diligence fell to the wayside. On a project a year it’s ok ago, there was an oil tank with about 1800L of oil in it which was decommissioned to convert to a log gasification system. The scaffolders who put their scaffold yo for us to do the flue etc trampled all over the 10mm oil lines as they went along. Then it started to leak. I switched the shut off valve off and instructed the client, in writing, that it needed to be rectified by an OFTEC reg’d and insured installer immediately. The cottage was at the bottom of a steep valley with a fast flowing stream at the front of the house. You can imagine what 1800L of oil into that would have done, environmentally, let alone cost repercussions, and even though that tank was never touched by us, I still felt it was my responsibility to make the client aware of the massive dangers that were in front of me, ( even though it was caused by the complacency of others ).
  4. As long as it's not in @daiking's hot tub i'm all good.
  5. AONB / conservation / listed?
  6. When you're finished, we'll all meet up and go out on the piss Could do with a blow-out
  7. sending you a high-5 down the line. She any good at grouting?
  8. This should all land squarely on the shoulders of the OFTEC installer who commissioned the new tank / de-commissioned the old one. This is ENTIRELY their fault and should be coming off their insurance.
  9. Just knock the bloody thing down already !! Dig the shite out and dispose of, and then infill and compact, and rebuild. The writing is on the wall.......the house is on borrowed time. Oh, and don't listen to rumours, most are utter bollocks.
  10. Yellow stains will be the LEAST of your problems!!!!!!!
  11. Flat, not shiny. I’d have said mirror otherwise ? Big walls will always have some kind of undulation, but for every 2.5m run @ 2.4m high you should be expecting a very good finish over the given area. Beware the spreads that don’t lay opposites on and let them go hard before then laying adjoining, eg spreads who put a whole room on ‘wet on wet, and then there is very little they can do to get all the internal angles and lines crisp and straight. Yes, they do make internal corner trowels, I own one, but not many people can use one without doing more harm than good. 3 sets a day is good going, just depends how old your spread is ?
  12. You can use a small fan heater to kick start things if you’ve ever forgotten to turn the UFH on so no big problems there.
  13. Tres bien. As for tike adhesive, just butter the wall, enough for 2 or 3 tiles ( maybe more once you pick it up ) and put x number of £2 coin sized blobs of adhesive on the back of the tile. This will give plenty of adhesion and allow you to use the same principal as used for laying the tray, eg pushing the tile in and squashing the blobs until each tile is minted lamb. Don’t butter too much wall at any one time as the adhesive has a much shorter working aka “open” time when spread thinly on the wall Beware to use a level, vertically, as you go up the wall, as this method will see you slowly coming out away from the wall as the courses rise. Keep that in check. Check course by course. You need a bucket of clean water and a nice soft sponge + small paint brush to clean each grout line out when you get a bit of ‘ooze’ coming through. As you go, you’ll quickly get a gauge of what is too much / not enough and you’ll ooze less ( that sounds so wrong ). Every 10 / 15 tiles laid, prise one back off and check how much % of contact you’re maintaining. 60-70% is ample, and panic yea not about gaps at the edges, just ram the grout in, when you get to that stage, and the corners will be just fine. As far as cuts, where to start / stop etc, work it out so prominent features get the most sympathies cuts. @Onoff says he’d have raised the bottom cut higher to get rid of the rip at the ceiling. I think that would have been worse when you look what that would have done to the cut under the window
  14. A 4 day plastering course for £500 for two people.....will just about give you the confidence to mix the plaster properly. Absolute total waste of £500. Same as driving lessons, some need less, some need more, and sometimes you still don’t get how they were given a license at the end ‘COS THEY STILL CANT BLOODY WELL DRIVE!! I’ve had spreads in and on the first set I’ve told them not to come back tomorrow. If it’s not like a sheet of glass, you’re out on your ass. Don’t put up with a crap spread, bin them immediately and go onto the next one.
  15. 340w panels; 12,000 / 340 = 35 panels. Don’t forget the consumables / trays etc. GSE don’t cover every panel size, so check compatibility and consider EasyRoof if you need bigger. If you’re on true split elevations you’ll need a dual string inverter, and if you use micro inverters you’ll need to factor in the cost of a controller. Make sure you get the required parts list right when ascertaining costs
  16. Nice to see that din rail mounted gen meter. Neat solution. The size of the second PV CU now makes sense.
  17. 16mm earth, but why not use 3-core and then problem solved? You’ll have to split the 25mm core between two of the 16mm max ( iirc ) earth bar connections to make it off. Assume spark will do this so won’t be your prob. Either that or run a 2-core and zip tie the separate 16mm earth along its length. They need to stay together btw.
  18. Take it to the grave with you. ? All good from what I’ve seen / heard. ?
  19. Academic fight I meant. You’re a small, ruffian of a man for suggesting anything else..... Obnoxious enough? ✌️??
  20. .....when they muck spread ?
  21. Tell them to FO. Better still, sell them your consent for £5k.
