DCV compression on plastic? I'm not sure...
Nickfromwales replied to Super_Paulie's topic in General Plumbing
Straight in with these my friend. For showers with a 3/4" entry you just wind a brass reducing bush in first, then these 1/2" fittings wind into those. -
Also look at what difference V2G will bring about, as this will likely make a lot of domestic batteries nigh-on redundant eg for anyone who works from home / is retired etc. You would be plugging the house into the car then and not the other way around!
What a kerfuffle! I'm not a big fan of these re-invented wheels.
You'd need to do the maths meticulously to be honest. Tariffs seem to be starting to favour the consumer these days, and I expect that to continue to improve. If you install any cylinder you'll benefit immediately from excess diversion to DHW, so the question then is how much bigger do you go to get maybe 24hrs of DHW from an cheap nights (or days) grid juice. If you're able to track agile and use that to your advantage, then a dual immersion setup will allow you to rapidly heat the cylinder from much shorter windows of low rate availability. I'm assuming you'd need to buy the diversion controller too, so you'll be happy to know that the My Energy Eddi will give proportional power out to 2 loads, consecutively. So you could heat the upper immersion first, and then the lower one after that has been satisfied. They only do 1x 3kW throughput over 2 outputs, but not simultaneously. A relay card can be added but that is 100% on or 100% off, vs the proportional output from the factory offering.
Polythene above insulation prior to UFH
Nickfromwales replied to eandg's topic in Underfloor Heating
500 will tent. Use thinner. Could you explain, please? -
Durisol - in administration
Nickfromwales replied to PeterW's topic in Insulated Concrete Formwork (ICF)
Yup. They literally 'suck'. In more ways than one. Folk who have used / are using them, please feel free to ask how I/"we" got some bloody good results for airtightness and made the best of the product. It just took a lot of time, effort and ultimately money. I will offer up help as much as I offer up the above highlighting of these very real issues. -
Is the pipework down already? If so, you'll need a much lighter membrane (1200 or so) otherwise the membrane will tent over the pipes and not envelop them. This will lead to poor heat transfer from pipe > screed / other. You lay that in lots of sections rather than one large area and tape after it's been tucked in as best as possible. -
The woodcrete is like a non branded breakfast cereal for sure. The rain hitting the building up high heads south, that starts to saturate the "air pockets" which then fill with water and occupy that pore. Then as this carries on south over 1 or 2 stories the water then finds itself wanting a way out. That's gravity and a bit of capillary action at its best. The blocks which have woodcrete bridges from leaf to leaf (not so with Velox) are terrible at stopping conveyance of this rainwater to the interior layer. By the time it has been soaked, saturated, and has dropped down a few metres of height, the interior woodcrete starts to take on the moisture / damp / water via those bridges. That's a fact. They act like a wick. Just don't do it people, and I haven't even started on how awful they are to get airtight too. I'm simply sharing my experiences; from working directly, hands on with these products, on real live projects, and I post this information for free in my 'spare' time. -
Opinions on best way to drop a ceiling
Nickfromwales replied to Thorfun's topic in General Construction Issues
It's down to available space tbh, but I'd say it would be useful to know the possible tariffs p/kWh before deciding on capacity. You're burning natural gas which is reasonably efficient and cheap enough (you could be on LPG for eg) so this is just down to the amount of DHW that you go through. Typically I'd say a 210-250L tank would be suffice, but if the maths can be swung by a good cheap rate of electricity, then you could be up at 300-400L with dual immersions without being silly. Not much uplift for the larger cylinder and the installation costs should be pretty much like-for-like. Viessmann tech support will confirm, I do little to nothing with gas these days sorry and even less around those particular boilers. I was a Baxi and Vaillant man I'm afraid.
Won't matter, as air is usually humid for a decent % of the year anyways The MVHR duct is a sound tunnel, so acoustically it may not be sensible, but also if there is even the slightest vacuum applied to it (the ASHP fan can be going at some serious pace for DHW) then you'll pull the MVHR out of balance, as stated above. The energy in the stagnated air in the under croft would be gone in 10 mins or so, then you'd be solely reliant on sucking fresh cold / humid air in and through to get to the ASHP, so also pointless, sorry. No harm in thinking about these things, and defo worth asking
Block and Block with 180mm cavity instead of Isotex ICF
Nickfromwales replied to Chanmenie's topic in Brick & Block
https://www.kore-system.com/insulation-series-using-eps-for-cavity-wall-insulation-applications/ -
I've said my bit. Based 100% on facts, and with me kneeling in water, clients effing and jeffing about dehumidifiers not even scratching the surface, etc etc. -
There were 3 stories of ICF on that project (4-storey house if you count the basement), hence the choice. -
Will be easier to employ one company (imo) to just do the lot in one visit? -
Final (hopefully) bit of tape and membrane done today
Nickfromwales replied to Thorfun's topic in Ventilation
Cheer for the clarity. Rodding points not so much of a worry, and usually just a tick-box for BCO's. AAV's defo need access or locating strategically Good that you have that in hand already. -
Then you were very lucky indeed. What I wrote was entirely 'my' (clients) experience, and no exaggeration whatsoever. On both the Velox project, and the Isotex project, the uplift to get rainproof and airtight was "significant". 5 figures for each project. The Isotex was marketed as being ready to take plaster directly.......wtf?! Whilst installing the UFH I was literally kneeling down and getting soaked by a series of mini-rivers running over the sub-floor, and that was with a meticulous builder installing the Velox! Woodcrete is absolutely definitely porous, so don't expect the same results with that as you'd get with EPS (which is pretty-much rain-proof and AT by default) as you won't. I would be surprised if anyone could demonstrate otherwise, maybe not the rivers but there is no way on this earth that rain doesn't get through / soak into the woodcrete systems. I've done enough to know. -
You could also use the immersion to heat the cylinder off cheap-rate electricity (overnight Octopus etc) if available? Cheaper than gas is great, but even better is going same price but zero wear and tear on the combi too!
Aco drain at start of surface water run
Nickfromwales replied to Canski's topic in Rainwater, Guttering & SuDS
£80 here? -
Woodcrete has a boat load of them!! EPS is a no-brainer. You can with Velox, but that only solves the issues of the shape. Then you are still left with the list of cons / caveats. -
Hello from someone considering demolishing and rebuilding
Nickfromwales replied to Norbert's topic in Introduce Yourself
That was because it would give you a lower structure that was nearly 100% non-hygroscopic. If a flash flood actually took water levels up to the house, the EPS ICF would be unaffected. A TF would have to be cut open to evacuate lost insulation / clear crud out of cavities etc, whereas with EPS ICF you'd only be replacing the bottom of the plaster boards. -
If it was my house, I'd cap everything and go to the nth degree to get the actual ACH of the fabric. What is the point in doing all of the work up to that point, if a slightly faulty / leaky valve then gives you a shite ACH score!?!?! -
These need to remain accessible? -
They minimise airflow (convection) so would be my choice. The cavity can be fully blown, and very few gaps/cavities are left when done by a good company. -
1000% the right thing to do! 👍. Tightening metal onto soft plastic is just bonkers. The insert just stops the pipe from caving in, but doesn't stop the nut and olive chewing into the plastic. If you even slightly over-tighten (or tighten as you would with metal / metal) then the olive will start cutting into the plastic of the pipe. 👎
