Temp
Everything posted by Temp
+1 to that question. Daft electrician? I found this study awhile back.. http://electrical.theiet.org/wiring-matters/15/current-ratings.cfm?type=pdf Basically it says cables under insulation might need to be derated by reducing the circuit breaker value. Otherwise the wire might have to be fatter than the standard 2.5mm^2. The exception was some lighting cables where they say.. .
- 11 replies
- loft
- insulation
(and 2 more)
Spray foam under room in roof floorboards - expensive option?
Temp replied to readiescards's topic in Heat Insulation
Have you considered doing a partial conversion? I think all you need is to put the insulation at rafter level instead of floor level and fit a vapour barrier (plastic sheet). I don't think you would need to plaster board it. Perhaps ask the BCO? -
What needs done to add an elec shower?
Temp replied to Crofter's topic in Consumer Units, RCDs, MCBOs
Can you expand a bit on what you mean by "a rather unpleasant showering experience"? When you say the pressure is good do you mean the mains pressure is good but the shower pressure is low? If so that sounds like the tank in the loft is a vented tank. Switching to a well insulated mains pressure tank might be an option. -
Is there a potential issue with Part E (Sound) in that if you don't build to a "robust standard detail drawing" you may have to get a sound transmission test done?
Not unless it freezes. When you connect it up remember to put some corrosion inhibitor in the system.
Ask your SE if he has any specific things he wants included and if he can recommend a company to do it. Typically it involves digging two or more holes and pushing probes in at various depths to test the load bearing capacity of the ground. Samples are also taken and sent to a lab to look for anything that might effect the foundation design. The report describes the various layers they find and the results of the sample analysis. Do you have a builder lined up or are you using subcontractors? You might save money if you provide a digger and driver although most companies can arrange one if you haven't. If the ground is clay.. Will you also need a percolation test to see if soakaways work and to provide data to size them? If so you might get this done at the same time.
Perhaps it's just me but what are "lookouts"? The planners only want to know what it will look like from the outside not the internal structure. So you can remove a lot of the detail but need to add info on the cladding (wood/render? Colour/stain?). They will also want to see how it relates to the rest of the house so you will probably need to draw the house and extension together. The drawing you have done is more suitable for Building Control Approval which is the next step after getting Planning Permission.
Winter/spring here can be quite wet but it looks like you have the concrete base arranged so the frame is raised well above local ground levels. It also looks like you have avoided a common mistake which is to lay a flat topped slab that is slightly larger than the building. They forget that this allows water to run under the cladding to contact the frame. It looks like you have a step in the concrete to prevent this. A few courses of bricks or even a visible brick plinth is sometimes used. Building Control will probably want details of the damp proof membrane (DPM), damp proof course (DPC - between concrete and sole plate) and the wall membrane. Perhaps consider a linear drain across the door opening if you haven't already planned this. Are there any purlins planned? Perhaps I misunderstand the drawing but if the clear span of the rafters is 18 feet they will need to be deeper than 6". I can't tell your rafter spacing but that might be different between Canada and UK. Here it's normally 400 or 600mm.
Do the Aico support a reset/kill switch? Wonder if I can add one to mine. In case it matters, I think you can only interlink alarms of the same make/model.
Thought I had seen dimensions on the Paving Expert site but I was mistaken. That just refers to.. http://www.pavingexpert.com/drain03.htm "Most local authorities and/or water boards have their own specification for an outfall detail, but the illustration opposite shows the type of scheme favoured by many authorities for small outfalls."
I remember seeing guidance for stream end (the outfall into the stream). That might set the height that end. Will try and find it. Then working back up from there to the digester you need a fall on the pipe. At 1:40 that would be 2.5 meters over 100m.
I think this would be possible with a bit of planning. Most pocket door kits have some sort of metal frame that plasterboard is screwed to. If I remember correctly the frame is thick enough to form a void for a wire. Run the wire before cladding the frame with plasterboard.
+1 Presumably there are pumps on the manifold that draw water through the boiler and these are over powering the pump supplying the DHW tank. If this part of the system can't be balanced you could consider giving the DHW tank priority over the UFH as it won't take long to heat/top up the DHW tank. The UFH probably has lot of thermal mass so the temperature of the house won't fall much while the DHW is calling for heat. I've lived in houses where the rads and DHW worked like this.
I've had enough: please check my thinking before I.....
Temp replied to ToughButterCup's topic in Planning Permission
Regarding living on a building site... The GPDO allows temporary buildings http://www.legislation.gov.uk/uksi/2015/596/schedule/2/made As I understand it that's usually interpreted to mean building workers don't need PP to live in a site van on site but a spouse (that isn't a building worker) and children (who cannot be building workers) would need PP. In the latter case councils sometimes turn a blind eye if permission for a house has been granted. Why was the application for a house refused? If it was refused due to a design detail the council might turn a blind eye in anticipation of a new modified application for the house. If it was refused for a whole host of policy reasons/green belt/no chance of a house there then they should really look at taking enforcement action. Otherwise once they have been living there 10 years they should be able to get PP for change of use allowing the caravan to remain indefinitely. -
I might be wrong but I think "domestic (householder) planning applications" are only for extensions and outbuildings not new houses? If the original application was for a new house I think it must have been a Full Application and I think the deadline to appeal that is 6 months. Edit: Householder Application.. https://www.planningportal.co.uk/info/200126/applications/60/consent_types/2 This form should be used for proposals to alter or enlarge a single house, including works within the boundary/garden of a house. It should be used for projects such as: Extensions Conservatories Loft conversions Dormer windows Garages, car ports and outbuildings Full Application... https://www.planningportal.co.uk/info/200126/applications/60/consent_types/3 You should use this application form to make a detailed planning application for development, excluding householder developments. For the purposes of this form, development includes building, engineering or other works, in, on, over or under land, or the making of any material change in the use of any buildings or other land. As such it should be used for: Any works relating to a flat Applications to change the number of dwellings (flat conversions, building a separate house in the garden) Changes of use to part or all of the property to non-residential (including business) uses Anything outside the garden of the property (including stables if in a separate paddock) -
MVHR vent location
Temp replied to dogman's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Our exit vent makes a bit more noise than the inlet so perhaps don't put it/them near your patio? Don't put the inlet down wind of your or a neighbours gas/oil boiler flue/bonfire location. -
BT/Openreach New Connection
Temp replied to worldwidewebs's topic in General Self Build & DIY Discussion
As I suggested earlier, you could put your own cable and backup draw rope in the duct. You can do that before putting the duct in the ground. -
Wickes charge £35-£100 for delivery unless spending over £300. I think TP still do free delivery for web orders? and £15 max on bulk bags in store? Not sure as it's been awhile.
- 9 replies
- builders merchants
- travis perkins
(and 3 more)
In my area Mick George currently has Mot Type 1 for £29+Vat = £35 (850kg bag) with free delivery if your order is over £100. MOT Type 1 can include a lot of dust so perhaps go see what you are getting before you buy. https://www.mickgeorge.co.uk/residential/miniload/primary-aggregates/type-1-mot-granite/ MOT Type 3 has less dust and can be used for drainage/permeable surfaces but some places have never heard of it. http://www.mainlandaggregates.co.uk/mot-type-3-sub-base.html
- 9 replies
- travis perkins
(and 3 more)
I've had the same problem. In heavy rain the water overshoots the gutter if you aren't careful with the geometry. Google found this.. http://www.ribaproductselector.com/Docs/4/21084/external/COL521084.pdf See page 11 for a drawing and.. PS In my opinion the drawing shows the gutter too low. Will have too much overshoot.
Can't decide if this is cool or uncool... It's a shower head with built in temperature display that is powered by the water flowing through it... http://www.ebay.co.uk/itm/Hand-Shower-LED-Digital-Temperature-Display-Insignia-/171981885486?hash=item280aeb502e:g:Y7wAAOSw5ZBWMOQ1
Ryan doesn't mention a thermal store so the boiler will fire whenever a room stat calls for heat. The flow and return temperatures moderately critical with the Grant... They say the return temperature should not be below 40C as that can cause corrosion. Nor should it be higher than 55C in order that it stays in condensing mode. Page 3.. http://www.grantuk.com/wp-content/uploads/2015/05/Vortex-Outdoor-Modules-installation-and-servicing-manual-DOC52-Rev00-October-2004.pdf Dose the system with a corrosion inhibitor. I use Fernox but there are others.
