Dreadnaught
    5
Everything posted by Dreadnaught
  1. Following this discussion with interest. Tempted by a cheap DC only PV setup for my passive build with an electricity-only solution for space heating and DHW. Have a shaded site but might be able to justify some east/west panels.
  2. Wonderful news! Such a beautiful house, and country setting, which I have had the privilidge to visit. Well done Moira and Henry!
  3. For a bit of bank-holiday fun, tell us the one feature of your house design, or future design, that is your favourite — the cherry-on-the-cake, the wow-factor, your pièce de résistance, your pride-and-joy? Choose anything at all: on show or hidden away, aesthetic or structural, thematic or specific, real or imagined, present or future, sensible or just plain silly.
  4. In my (limited) experience, coordinating with sub contractors is part of an architect's usual standard product offer, their bread-and-butter. He seems to be reacting in this vein. By all means, tell him that you will do this yourself and he should provide you with the needed files to do so. Once you have the files, what you do with them is your business so long as you are using them solely for the project as originally intended, and not, for example, setting yourself up as a retailer of said plans to third parties, which would infringe his copyright.
  5. @ultramods its an ambiguous email from your architect. My reading of the email is that it says that they wont provide info to third parties on your behalf (without being paid to do so). They are not however saying that they wont give such information to you, which you can then give to the third parties. I am currently engaging an architect. From my research, I think that CAD files are a grey area. But I will be stating explicitly with mine at the time of engagement that I can have all the drawings & files I wish.
  6. @epsilonGreedy these videos are pitched at my level too. Will be watching them for my much needed education, with my marketing sensor tuned to high gain. Thanks for posting.
  7. Beginner's question: as a local sensor, why would it benefit from being tuned? What local conditions matter here, humidity?
  8. @newhome Perhaps there is a typo in the fourth sentence?
  9. Second link is broken for me.
  10. Prompted by this discussion I have been reading-up on enthalpy heat exchangers and am now considering specifying one for the MVHR in my build. The marginal cost of having one is of course much reduced if specified up-front. Targeting internal comfort as I am, it seems like a worthwhile extra spend to consider. I learnt that: an enthalpy heat exchanger is the same shape and form as a typical metal heat exchanger but just made of a polymer material, which is somewhat more costly to manufacture. As has been said before, they are a 1:1 substitution. No labour required. some earlier designs of polymer heat exchanger, ones based on cellulose (like paper), had a finite life but more modern ones seem to last indefinitely. the polymer membrane is selected to prevent any larger molecules than water, such as most air pollutants or pathogens, passing. enthalpy heat exchangers are less efficient at heat exchange than their metal brethren (by about 9%) but the increased humidity levels indoor mean a latent heat gain due to the reduced evaporation losses. This "closes the performance gap" in terms of energy recovery between the two systems. typical moisture recovery rates are about 65%. Slightly off topic on the subject, might having an enthalpy heat exchanger reduce the potential for winter freezing of the MVHR and so reduce the use of the pre-heater designed in all units to prevent it? Reasoning being: intake air will be low humidity already in winter but exhaust humidity will be much reduced, reducing icing.
  11. External antennae to make one's router look like a bristling stealth fighter jet strikes me as just marketing. There are few situations where an external antenna is really justified. After all, mobile phones have long since dispensed with them. Antenna design is a fascinating subject all to itself.
  12. @Ann welcome! Perhaps consider the implied hourly rate of the cost. How many hours might the job take for an experienced engineer? And is is just desk work or is surveying required? 10 hours for example would imply a £250 hourly rate, which I would consider extremely generous. Do also note that the VAT will not be reclaimable from HMRC at the end. Finally, its good advice to always get three quotations, every time. — Edited to add: slightly off topic, as a shortcut I try to extract an hourly rate from all the contractors (professional and the trades), if only for comparison purposes. It gives me an ability to compare their value-for-money as I perceive it in a more equivalent manner and even between disciplines. And I find it avoids mismatches in expectations on financial matters between them & I. I can then compose my team on a value-for-money basis based on my own priorities. For example, I did this exercise across architects and am just about to select one that is every bit as good than the others (and in some ways better in their knowledge of Passive Hosue for example) but has an hourly rate that is half that of the priciest one. I expect that in the longer term this will lead to a more harmonious relationship, with fewer rankles over fees.
  13. The second video is up: Credit to Ben Adam Smith's twitter feed for the link.
  14. Its the hardware and software within the APs (Wifi access points) that matters. The only effective solution is to use APs that support WiFi roaming and seamless handoff, 802.11r or a proprietary equivalent. The AP requires a special controller functionality within and the vast majority of home WiFi routers do not have it. Without WiFi roaming, using the same SSID for multiple WIFI sources is generally not a good idea as, as you have found, it doesn't assist with roaming and it can make debuging more difficult. Which APs are you using? Are they true APs or just home routers connected by ethernet cabling and set to bridge mode, each creating its own sub-net and with multiple NAT. Or even worse WiFi extenders connected wirelessly, again with multiple sub-nets and NAT, and likely a halving of data throughput?
  15. Just picking this thread up again after more than a year. Pondering a green roof for my coming build. @vivienz did you get anywhere with your idea? Has anyone currently got a green roof? Anything good or bad to say about them? Cost? Maintenance? Do they play well with roof lights? Complete beginner here.
  16. Thank you all. Excellent points. Plenty of new thoughts to mull. Notably… splays decrement delay of vacuum panels may be low but actual heat flow will likely be tiny the risk of puncturing vacuum panels alternatives to vacuum panels, e.g. aerogel a green roof giving evaporative cooling and being an additional thermal buffer. (Neighbour would like the look of it too) I am now minded to avoid vacuum panels and be armed with all these new ideas instead. Thank you.
  17. The issue is less about an initial connection but more about how long a device will hold on to a dwindling network as you walk away. With multiple access points ("AP"), it is far better to have an AP with the technology to switch between APs as you roam. Most domestic (i.e. non-commercial) APs don't have this. It makes all the difference. Ubiquiti have their own technology for WiFi roaming but also support 802.11r. The same applies if you manually give the same SSID to two APs. Without the ability to roam, it will still hold on to the first network for too long, until the signal strength dwindles. In the reality of a home environment it often means that it never switches automatically at all. And having always to manually switch networks is an annoyance, a distant second best in my experience.
  18. As for Ubiquiti kit, you should have plenty of change from your budget. UniFi AC Lites cost about £80 each and you can pick them up on eBay second hand from time to time for about £50 or so. Suggest to buy 2x UniFi AC Lite's and nothing else. (Plus a laptop to do the setup remotely using the free Unifi software.) Regarding "2x or more", it depends on coverage areas and signal attenuation by thick walls. Suggest trial-and-error. Start with 2x and buy more if you need them. In a modern house, two did the whole house. In a big older house with brick internal walls, 3x were needed. If you need an weather-tight outside AP, they are available too from the "mesh" range (e.g. UAP-AC-M). Optional extra: a PoE ethernet switch (made by Ubiquitu or a third party, doesn't generally matter) so that PoE injectors, which are included in the box, are not needed at each access point. Initially you don't need a UniFi Cloud Key, which is for remote monitoring of your network and more commonly deployed for commercial installations.
  19. Thanks @SteamyTea. Would it be more meaningful to say vacuum panels have a (near) infinite decrement delay factor, not zero as in the linked information? And, even more relevantly, in your view should I not be concerned about decrement delay in a thin roof with vacuum panels?
  20. From @JSHarris and others I have learnt about the importance of decrement delay as a characteristic of the fabric of a house in providing internal comfort. Background. My build may well be a single-floored, flat-roofed building of contemporary design. As a rear-garden plot surrounded by other dwellings, it has precious few sight lines and instead will have a profusion of roof lights to let in light. As a (near) Passive House, the roof will be thick and there is a concern that the roof lights will give the impression from inside of a house deep underground. One suggestion to address this is to thin the roof, to use high-prefromance insulation such as vacuum panels in the roof to improve the aesthetic look instead of cellulose filled I-beams. So far so good but I worry that a roof with vacuum panels will have a low decrement-delay factor. So to the subject decrement delay. As I have learnt, a cellulose-filled roof would have a welcome decrement factor. But what about vacuum panels? I have done a little google-ing and came across the following summarised from here: Thus to my question: how can Vacuum Insulated Panels have a decrement delay of 0 hr? I understand that the decrement-delay factor is product of λ (lambda), which is very low for vacuum panels. But is also related to specific heat capacity and the density of the material concerned and I do not understand how to consider these two for a vacuum insulated panel. I wonder, can anyone enlighten me? (For those interested in learning more about decrement delay factor, I found this explanation a help: http://www.greenspec.co.uk/building-design/decrement-delay/)
  21. A tweet today: What significance does this have for us self builders, if any?
  22. +1 for UniFi. Done two installs of UnIfi AC Lite's recently and very impressed with the outcome in each case. Rock solid. EDIT: By the way, if you do go down this route, feel free to ask for advice. As a product often used for commercial installations, the plethora of options can be a little dauting. A basic install for home use is much simpler than it may at first seem.
  23. On the nature of PCM34, as Andrew Bessell of SunAmp told us, PCM88 uses Strontium Bromide Hexahydrate. Source reposted by @Alphonsox from the previous forum here: In the letter from Andrew Bessell on the current issues re posted with permission by @le-cerveau in the thread below it says only that SU34 is a bromide with a different metal ion, i.e. not Strontium.
  24. Out of interest, why?
