Everything posted by Dreadnaught
That makes eminent sense. Thanks Jeremy.
@JSHarris, @TerryE describes how he uses the concrete slab as his buffer. Is that not a better solution for you? Just transfer the heat for space heating straight into the slab? (I am sure that you will have a good explanation why not )
For clarity, on the subject of maximum output temperature: if a SunAmp unit only has PCM34 cells then it can output any temperature up to about 34ºC (good for under-floor heating but inadequate for central heating with normally sized radiators or for domestic hot water) if a SunAmp unit has both PCM34 and PCM58 cells then it can output any temperature up to about 58ºC (good for domestic hot water) In each case, within the device the output can be blended down with cold water to any target output temperature below the limit. In a unit with both types of cell in series, PCM34 cells can be used to preheat water for PCM58 ones. (It is worthy of note that I have not heard of a SunAmp unit in the wild that has PCM34 cells alone). if you would like even more splendid @JSHarris-style detail, I found this re-post by @Alphonsox from another forum of an entry by Andrew Bissell (SunAmp CEO) from September 2015 instructive — look to the seventh comment:
As I learnt from this site myself, they are two different phase-change material compositions. And it relates to them being tuned to different input temperatures not output temperatures. For example input from an ASHP will be lower than that generated from PV electricity.
Ah, oh well! Looking forward to their next product announcements.
Sneaky-peak photo?
mobile phone signal inside the house
Dreadnaught replied to lizzie's topic in General Self Build & DIY Discussion
Fabulous! A few Unifi AC Lites (and perhaps a waterproof one outside too if you have a huge garden) and an (entirely optional) PoE switch and you're good to go. A glorious fast* uninterrupted WiFi signal will be yours! * at least as fast as your ISP will allow. -
@lizzie that sounds like a real challenge. Hope you can get it sorted, at least for your new home. As a general point of advice, using wifi "boosters" within your house that themselves use wireless is far inferior to running ethernet cables between WiFi access points, even when using the latest "mesh" routers that in some cases use a dedicated radio frequency for the routing signal. It is always preferable to run ethernet cables if you can. Regarding WiFi access points, the better ones have protocols that handle seamless handover between access points. It makes all the difference. I have recent experience of two recent installs, one of which was in a house with very thick walls. The solution worked very well and exceeded my expectations. Of course, none of this can overcome a slow internet supply from your ISP but at least it removes one source of complaint. In your new house I do hope you have run some ethernet cable. Sounds like a Vodafone specific deficiency. There is no reason in principle why voice-over-wireless must exclude SMS. -
Not so, at least in my case. My iPhone was not purchased from Three. Yes, its too much hassle in my opinion so I have rarely if ever used that app. Oh, that's a surprise. Have not had a problem with texts myself. Texts themselves use such tiny amounts of data that I am intrigued that they have caused you a problem. Oh dear! I am sure there are other threads on this, and at the risk of hijacking your thread, but installing a couple of Ubiquity Unifi AC Lites if you have an ethernet network will solve your problem. They are superb. https://unifi-sdn.ubnt.com -
My Three mobile service also includes "Three WiFi calling". Phone calls are made over Wifi, both inbound and outbound, no special app required. Works fairly well in my experience and even in locations where there is no cellular reception at all. It is a service that is part of the mobile technological standard (IEEE 802.11). It is not a proprietary solution and just requires the telecoms provider to support it. Adoption seems to be widening but not yet universal. Might that help you? Although it might require a change of mobile telecoms supplier. And I believe it requires a smartphone such as an iPhone. But might mean you don't need a signal booster at all. Here's a list of which telcos support it today: https://www.4g.co.uk/news/ee-o2-three-and-vodafone-which-networks-offer-wi-fi-calling/ I think this is the relevant Wikipedia page: https://en.wikipedia.org/wiki/Voice_over_WLAN -
MVHR: More extracts than supplies?
Dreadnaught replied to Crofter's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I like your idea better than mine. Could you have the extract not at the apex but as high and far towards what I assume is the kitchen and facing towards it, and the supply as you have marked it, facing downwards, so within your constraints maximising their separation. I wonder what an MVHR designer would recommend. -
For the supply terminal, could you have the terminal not in the ceiling directing air from above and downwards but mounted in the internal gable and facing into the big air space to the left, located as close to the current location that you have shown in your diagram and as far as the internal gable structure would allow? Thus, could it be that the supply air could be directed into the big air space and so minimising the short circuit that Jeremy mentioned, perhaps using a special design of terminal that directs the air? I have no knowledge of MVHR ducting so disregard my idea if you wish. -
Very good points. My word, these assessments are complicated!
Oh, of course. Less of a factor.
Very good point. I am tempted to plan for PV but not install it until an economic case becomes clear. Two complications about this decision are: (i) the possibility of recovering VAT at the time of build, should that sway the choice; (2) I am expecting the cost of PV to continue falling, especially as material science continues to advance.
What a kind offer. I will PM you. I am slowly learning that. Much more to learn. It is indeed a rather intimidating prospect having read some of the blogs and threads, although thus far is not deterring me, although I am rather apprehensive. Ben Adam Smith of the House-Planning-Help podcast seems to be going down the route of doing as little himself as possible for his newly-started build. I now can understand why. Makes sense. Thank you.
Oh, very good point. Just store the energy in the slab. Obvious now you say it. Truly excellent point. Not at all sure how to do this. I assume PHPP and an eagle-eye on the builders will not be enough. Have more to learn. By the way, @TerryE do I understand your arrangement correctly that you generate DHW from your Willis heater (at least as for showers)? I think that can't be so but I was confused about your comment of a SunAmp being only useful in your case for baths.
Ah, I see. So all the new 3rd-generation Sunamp would need to add is separate circuits for DHW and UFH so that they don't mix (and no doubt lots of other goodies that I can't even imagine). And now I also understand @Nickfromwales's point about the different phase-change materials (PCMs). They are simply to cope with different sources of energy. The lower temperature PCM is for heat derived form an air-source heat pump (ASHP), which cannot generate high temperatures without sacrificing COP (or using a complex multi-stage heat pump). I am also aware that, with a SunAmp that does contain both high- and low-temperature PCMs within, then the low-temperature PCM can be used to preheat water that then feeds into the high-temperature PCM, and then this higher-temperature water can be blended down to the target temperature. So in my scenario, using E7 and PV, a high-temperature PCM Sunamp would be the choice unless I anticipate possibly adding an ASHP later, when having both PCMs might be desirable. Anyhow, it seems @Nickfromwales has some good news up-his-sleeve about some thing for early March!
Yes, I was thinking about that. Assuming that the UFH water circuit is a closed loop, would you bypass some of the water around the Sunamp and re-blend the unheated water with heated water from the SunAmp outlet using a thermostatic blending valve? Sorry for my basic description, I know next to nothing about plumbing.
@Visti, at the risk of going off at tangent, given that @Bobnjudi was asking a specific question about a cylinder, I am learning that one of the greater risk with a passive house is not the winter space heating but the complication of keeping the home cool in the summer. I believe @JSHarris found this and somewhat to his surprise. I therefore weigh the overheating benefits of SunAmp highly given how costly cooling can be in terms of either house design (shading installation, etc.) and possible cooling technology (such as air-to-air or air-to-water heat pumps, etc.). Also the ability to have a (marginally) smaller plant room (not applicable to @Bobnjudi I assume given their advance stage) is another cost to be considered. Just a thought. Hope its not too off topic. Sorry @Bobnjudi!
- 12 replies
Yes. As I understand it the new version of the SunAmp will contain two types of cell, with two different phase-change materials to cater for two different hot water temperatures: one well suited to DHW (higher temperature) and one good for UFW (lower). The SunAmp PV always had the equivalent of a Willis heater built-in. It is what converted the PV (or any electrical supply for that matter) to heat energy which was then chemically stored, so no change their. The advance with the new version of the SunAmp, as I understand it, is the ability to output water sufficiently low temperature to be suited to UFH (and presumably on a separate circuit so that UFW and potable water is not being mixed), all in one package. Others will surely be along to correct me if I am wrong.
Thanks @Nickfromwales. Now that's a great idea. Music to my ears!
At the risk of going off-topic, as @PeterW mentioned, SunAmp(s) would take up less space and the lower heat loss would in the summer lessen the risk of overheating for your Passive House. An alternative?
- 12 replies
