Everything posted by Dreadnaught
My guess is that… You should pay VAT on the hardcore that you buy but only if you're buying from a VAT-registered entity. You would then claim it back at the end of the build if you qualify for the "DIY Housebuilders’ scheme". The crusher man is correct in charge you 0% VAT on his services (including his machine, which he operates) as that counts as site labour. … only a guess.
I have a mono-bloc so no F-gas certification needed. I might guess without evidence that the majority of domestic installs are mono-blocs. If you want a career in heat pumps, is F-gas certification really needed. Could the Heat-Geeks course, or similar, be a better route in to the industry. Utterly ignorant so I could be missing the mark. Just my tuppence worth.
Back in 2022, I was charged by Latzel €20.83 on a £500 order so sounds plausible.
Thanks @nod. Makes sense. Very helpful. Thanks all!
Thanks @TonyT. Good to hear. My decision has also been helped by when I saw the price difference for "full-pallet-only" specials compared to the lines held in-stock. Nothing dampens my perfectionism more than being asked to pay a *lot* extra to achieve it
Thanks @nod. Good idea I will try that. If that fails, I have some t-bar at the ready. 3m height without a join would have been nicer but I guess a join isn't the end of the world. With top joins, I assume its best to avoid any four-way cross-style joints and aim for t-joints such that the fill-in board at the top over sails the board-to-board joint beneath.
I need about 19x boards of 3m acoustic plasterboard (3m x 1.2m x 15mm), e.g. Gyproc Soundbloc, Duraline, Knauf Soundshield Plus, or Siniat dB board, etc. Any will do. Of course, all the suppliers near me (Cambridge) only want to sell me a full pallet of 36 boards. Does anyone know of a supplier anywhere who will split a pallet of 3m acoustic boards?
Insulated twin pipe, 32mm or 40mm
Dreadnaught replied to HughF's topic in Air Source Heat Pumps (ASHP)
To help any others reading his table above … "Here you have the external pipe diameter on the left, and how many kW/s of power the pipe can carry in the centre" … from the Heat Geek website. -
Personal preference override automation
Dreadnaught replied to Pocster's topic in Networks, AV, Security & Automation
A mmWave radar sensor would work far better as a presence centre than an IR-based traditional sensor. They can detect subtle movements such as breathing. (I haven't got one myself (yet) but I hear they can be tricky to set up. ) Example: https://www.amazon.co.uk/Aqara-Positioning-Multi-Person-Detection-Precision/dp/B0BXWZMQJ3 -
+1 The various smarthome speakers will soon be able to listen for an alarm going off and send you a notification when it hears one. Apple's HomePod can already do this and I am guessing it will become a standard feature for other providers too. Link for Apple below. Buy reliable detectors. And let your choice of Apple, Google or Amazon send you the notifications. https://support.apple.com/en-gb/guide/homepod/apd1f1921722/homepod
Metal framing: which infill timber for doorways?
Dreadnaught replied to Dreadnaught's topic in Timber Frame
What purpose does the timber inside the stud serve at a door frame? Is it just to give something to screw in to, as I had assumed? Or is it to add rigidity, to allow for a heavy door on the hinge side? And/or to stop vibration as a door slams? -
That's an interesting approach. Another way to make a box could be to use another section of track as a cloak for the stud, as is used with wider spans. -
Thanks @nod. What dimension timbers should I buy for 70mm C-studs? -
Thanks @Conor. The fact that they are treated and you are using them inside your dwelling isn't a concern? -
I am currently doing my MF internal walls, GYPROC Metal C.Stud 70S50 (70mm). What have people used as the timber piece in the uprights. I tried Travis Perkin's C16 38mm x 63mm x 2.4m but it doesn't quite fit. Otherwise I can only find online treated battens of 50 x 25mm (i.e. roofing battens) or expensive PSE at 44 x 22.5 mm. What timber have others used in their doorways? @nod?
Acoustic Flanking Strips: Where to use them?
Dreadnaught replied to Dan F's topic in Sound Insulation
Good point. MVHR ventilation gaps under doors can undo a lot of good work. For the study/TV-room, I am going to move the ventilation gap from underneath the door to a new grill-vent through a cupboard in to a quiet neighbouring corridor. The door will be a snug fit. -
@Moonshine, I am using MF internal walls rather than timber stud. Is there still a sufficient impedance mismatch between concrete and steel/MF to make the use of acoustic-isolation strip largely redundant? (Mine is new-build bungalow and the reason I ask is that I am just now starting on my internal wall installation and wondering whether to order some acoustic-isolation strip.) Sorry to resurrect an old thread. -
PIR wall insulation between studs AND on top of studs internally
Dreadnaught replied to DanHW's topic in Timber Frame
It's unlikely to be a problem I would guess for that thickness. Many insulation companies will do an interstitial condensation assessment free-of-charge. I had one done for the roof build up when I decided to add another layer of insulation underneath. I added an extra 100mm of woodfibre insulation beneath a warm roof of 200mm of PIR. It wasn't a problem. Good airtightness will help of course as the main source of interstitial condensation is warm moist air migrating in to the fabric from within the building.- 1 reply
More tuppence. If you go the timber-frame route, make friends with your frame designer. He will have a wealth of knowledge about what's buildable and how to make the frame simpler. Don't fall for the mistake of letting the frame designer deal only with your builder or frame manufacturing company. Your builder may sign the contract with the designer and may well pay his bill at the end of the day, but you should have long discussions with the designer yourself both so that you can learn and that your priorities will end up being incorporated in the frame design. This is what I did. If I build another house (and I may), I will change the process. I will first choose and retain a frame designer myself (probably the same one as I used this time as we got on well) and design the dwelling with him (plus an architect for the aesthetic input). And then take the design to a timber frame manufacturer to make and install it all on site.
My tuppence worth. I agree with @kommando. I have restricted access, albeit only 80 metres worth. And could not have a crane on site too. My frame builder, which I chose to be local, simply had the frame designer design smaller panels, which were made in the factory and brought to site on a smaller lorry and then handballed in to position with dollies and few burly lads. It went up easily.
Are you aware that you can contact Vaillant directly and they will provide a custom system design for your particular setup. That's what I have done. They ask for the name of your Vaillant adviser and I just used the name of the local area rep without having ever spoke to him. They did not seem to mind. (In my case, I have my heat pump and UniTower on site. I have done the physical installation of the heat pump only so far. I have not installed the UniTower yet. Nor have I made the hydraulic and electrical connections for the heat pump, although I have bought the parts for the hydraulic connection.)
Narrow extension for laundry and shower room
Dreadnaught replied to Jilly's topic in General Self Build & DIY Discussion
By joining to the neighbour's garage, is there any risk that your house might change its "estate-agent" description from "detached" to "linked detached" and thus affect its perceived attractiveness to a future buyer? Such things shouldn't of course make any difference but sometimes do. Or did I get the wrong end of the stick and your house will be unaffected.
