Everything posted by Dreadnaught
Very interesting topic. Will be following. I wonder, do you plan for the lights be dimmable or controllable with automation?
Hi all - Just about to embark on a new build...
Dreadnaught replied to Milo's topic in Introduce Yourself
Welcome @Milo. -
Welcome!
Why might that be so? (Hoping to have FTTP for my forthcoming build and I think there are providers in my area, as well as there being Virgin Media).
More ingenuity. Impressed!
Hadn't thought of that as a solution: ingenious. Any reason why metal mesh, stapled in place, wouldn't have worked?
Thanks @jack, I went back to some of your earlier posts. Lots of interesting reading there! It seems you have re-branded Hunter Douglas blinds. I notice that @Bitpipe has roma.de blinds on Gaulhofer windows (fixed to the windows in the factory). I wonder if they produce blackout? (He said in 2016 that "and can almost act as a blackout"). Edit: I notice that the Gaulhofer website says: "People who want their home to be absolutely dark are advised to go for roller shutters. For everyone else who find 99% darkness sufficient and prefer a bit more flexibility in terms of light management, Venetian shutters are the first choice."
I wonder how would security blinds interact with fire evacuation requirements for a bedroom? I saw a reference online to a US site that said such security roller blinds for a bedroom were not allowed there because of building regulations, presumably fire evacuation regulations. It is relevant for the bedrooms in my bungalow I think, for which the windows have fire-evacuation sized openings.
Thanks @HerbJ. Ah so I see they are called "Rollladen" in German.
- 15 replies
- roller shutter
- security shutters
(and 2 more)
I am interested in those German windows you see when you visit a German home that have those built-in external window shutters mounted into the window itself and opened with a strap on the inside. Like in this video… Anyone knows who makes them, any brand names? I am expecting that there is a huge billion-€ German company that dominates the market that most people have never heard of.
- 15 replies
- roller shutter
- security shutters
(and 2 more)
Which model of Airport do you have? I can probably guide you through its setup if you want to fix it. You can PM me if you wish.
I agree with @Mr Punter and @Temp. There are specialised matched base-station/extender pairs that transmit the signal between a base station and its extender on a different frequency from the usual WiFi frequencies, which gets around the problem of an extender halving a network's bandwidth. But in my opinion these solutions are far inferior to Temp's suggestions. And besides, such solutions require both the base station and extender to be made by the same manufacturer and are expensive. Furthermore, most generic cheap extenders do not actually facilitate roaming. There is no "handoff", even if the extender is set to mimic the original network's name (SSID). A device will hold on to the original router's signal for far too long. You may be standing next to your new extender but your device will still hold its connection to the distant router located all the way across the house until its dwindling signal is finally lost, which is long after the speed of transmission has dropped to useless levels. An unsatisfactory experience.
That looks well done. How did you construct the cupboards? And pre-cut system? I am looking for storage ideas for the two bathrooms in my forthcoming build.
Clever idea. More here: https://www.youtube.com/watch?v=XK3s_qJ-BW0
Which ASHP are set up to cool
Dreadnaught replied to Triassic's topic in Air Source Heat Pumps (ASHP)
I like the idea of an extra loop for duct cooling/heating. I think it gives the flexibility for duct cooling but also heating too. As @jack said: "If I were doing it again, I'd stick with UFH driven by an ASHP, but add a loop to allow some comfort heating of the MVHR supply air (really just enough to take the chill off the air due to the imperfect heat exchange in the MVHR unit)." https://forum.buildhub.org.uk/topic/7859-top-up-heat-sources/?do=findComment&comment=133325 One thing to consider, with a duct cooler you might need a condensate drain, unless the amount of condensation is so low that it can be allowed to evaporate. -
Garage green roofs / wildflowers
Dreadnaught replied to Moonshine's topic in New House & Self Build Design
My council has mandated a green roof on my forthcoming build for stormwater drainage reasons. I have chosen the simplest option. A sedum roof using a system of trays and mats. In my case the roof won't be visible, only my neighbours will see it. -
There is an example at PYC’s new offices in Wales. (They are an importer of WarmCel). The ceiling of their high-ceilinged open-plan office is fully coated with it. It’s a rather unusual and pleasing texture and they intend for it to remain on show. Good for dampening echos too I would think.
Not witnessed one yet but I believe they do both and take an average of a series.
Beattie Passive Haus 4 one
Dreadnaught replied to ProDave's topic in General Self Build & DIY Discussion
Interesting to see. I wonder how much they cost. -
Welcome @Diane. Congratulations on finding a plot! I was in your position about a year ago. In this post I listed some of the things I looked out for: I am sure others will be along soon with more help.
Location and type of airtight barrier
Dreadnaught replied to davidc's topic in General Construction Issues
Sounds like Touchwood Homes. That is their approach. I have visited two of their builds, both good. The other advantage of having the airtightness layer on the outside is the reduced chance of it being invisibly punctured during second fix. -
I wonder, can you place any panels on the flat roof at the top of the (huge) dormer, angled in frames? They may not shade the ones on the roof above.
Dew Point - What is it and why does it matter
Dreadnaught replied to Triassic's topic in Boffin's Corner
A warm welcome back @SteamyTea!
