Miek
Everything posted by Miek
One of my favourite Welsh phrases.. 'He's on his own' 🤣
Wall plate 75 wide, dormer face made of 100x47
Miek replied to DanieldeLorsh's topic in Introduce Yourself
I wouldn't worry. Pack it out with batten if you feel the need -
Fill the void with insulation, 'foamed in' PIR would be my choice.
I use a hand saw. Put the sheet on saw horses with a couple of scaffold boards to fully support the sheet underneath, then neel on top of the sheet and cut along using a straightedge as a saw guide. I find this more accurate than following a line. Oversize by 1 or 2mm when cutting for a tight fit .
I think this is probably your best solution to heat the whole tank. Also has no moving parts so no pump needed. Often used to retrofit solar thermal heating to an old tank, so it's a proven solution. As with anything relying on convection use big bore pipes and swept bends to reduce pipe friction hindering the circulation
I've done this on my own too. Put the boards on trestles on the ground floor , vertically, so you can reach down and grab them from above. Ball ache but quick really.
If you had to move the car to move the bins up the sump plug version that would be annoying.
Mad idea for DHW retrofit based on Mixergy?
Miek replied to JamesPa's topic in Air Source Heat Pumps (ASHP)
Not sure what your doing to generate that level of heat! More like 100W per adult. -
The Mixergy has dedicated tappings for the PHE circulator, unfortunately in a retrofit situation the use of existing cylinder tapings is mandatory. You can add your own tappings believe it or not, provided you have an immersion element boss. Buy a tank connector, Cut a hole where you want the tapping, drop a string in from the immersion boss and hook it with wire in to the new hole, drop the tank connector down the string so it locates in the hole , screw on nut. Pat yourself on the back :). I've done this a few times on old tanks. You can even retrofit secondary coils but that can be quite tricky. -
Give it to the farmer, make a friend with someone with useful stuff, might come In handy when you need a telehandler later in the build
Better to cut that cold if its coated in paint zinc or plastic . Make a piece of wood that fits inside as a support and cut with a TCT chop saw or table saw. Hacksaw if its sharp but again a support block really helps.
It's water based acrylic and can be cleaned off surfaces easily enough. Holes upto 12mm can be filled or larger if the hole is meshed first. I think this has a real potential to improve old housing stock but I expect it is an expensive service currently. One to watch.
Amazing, truly innovative.
Help me with my MVHR quote!
Miek replied to Mikey's topic in Mechanical Ventilation with Heat Recovery (MVHR)
If your house is 370m2 as it says you may have some long runs which often means double or triple, depending on room size and type as its 75mm ducting. Worth considering having a detailed layout done from your plans so you know exactly what you need and where. Personally I would consider going up a pipe diameter to 90mm or so to have fewer pipe runs. Not sure if BPC offer this, though other suppliers are available. -
What size are you building this time? House and workshop.
Cheap(ish), fancy(ish) toilets - Toto, Vitra, Grohe
Miek replied to puntloos's topic in Bathrooms, Ensuites & Wetrooms
I'm not positive but I think if it had a double check valve it would be OK, like a regular shower IMO . -
The merchants are there to supply the trades who pass the cost on to the customer. Convenience is their main selling point, almost always dearer than online.
Usually the larger Solar thermal cylinder would be twin coil with the solar coil at the bottom to heat the whole tank and the gas coil half way up to heat the top 150l only. Used carefully Solar thermal can provide about 60-70% of your yearly DHW. That's what I found anyway. The huge drop in the cost of Solar PV in the last decade has largely seen Solar thermal relegated to history as electricity is so much more useful than hot water.
