Ground floor for bungalow: joists better than a slab?
SteamyTea replied to Dreadnaught's topic in Timber Frame
Get those willows, poplars, eucalyptus and Leylandii planted. -
It will all be ok as Boris is not cutting corporation tax now as promised, but is going to spend the 2% difference on the NHS. Apparently that is £6bn. Is that on top of the £18bn bus promise. A 30% increase, I better go and break something.
Even that went from a polluted brown field to production in about 4 years. There is the last tin mine that was productive. For the last 20+ years there has been arguements about reopening it. Latest twist us that they could not build housing nearby because if the noise that the mine may make. 20 (expletive deleted)ing years to do nothing, the UK really had to get a grip on development and rethink our planning system which is hurting the country at every level.
Scaffolding tent for temporary roofing
SteamyTea replied to andyscotland's topic in General Self Build & DIY Discussion
Also, as a rule of thumb when using CSM, weight it, then weight out twice the amount of resin. You won't be far out. -
It is a bit if a combination of things. RH is really only a problem when very high, and in a hot place. If you warm the boards, curing can start sooner on the first layer. But don't think that will be a problem. What may be worth while is upping the catalyst a bit if the final layer is put down more that about 15 to 20 minutes after the first layers. Trouble with having the resin warm and the boards cold is that it reduces the pit life of the resin. Do a metre by metre square at a time until you get a feel for what is going on. And don't do too much if there is a chance that it is not going to cure in about an hour and a half. Curing will not catch up the next day. Sun us out in Aylesbury. -
It is a combination of pipe diameter, cumalative resistance and pressure. There are two pressures, static (tap closed) and dynamic (tap open). https://www.copely.com/tools/flow-rate-calculator/
So you have now made the sail, get the hang of the GRP and you are well on your way to making a boat. Make sure it is warm enough to lay up the GRP. You could use cobalt accelerator if it looks like the temperature is too low. If very low, then amine accelerator (have used that for very quick repairs when about 0°C. -
Heard on the news that the factory in China, which was a field in January is now making cars. From Wikipedia The Shanghai regional government approved the agreement to build the production facility in July 2018, and a long-term lease was signed for about 86 hectares (210 acres) of land in October 2018.[1][3] Construction began in December 2018 with the installation of secure fencing and site offices. The General Assembly Building was nearly complete by August 2019, and manufacturing line equipment was being installed for both batteries and automobiles. News reports in August noted production could start as early as November 2019,[4] and CNBC reports that Tesla is expected to manufacture more than 6000 vehicles at Gigafactory 3 by year-end 2019.[5] The plant had begun initial production of Tesla Model 3 cars by October 2019.[6] How long does it take us to get planning and design a building, let alone build one.
Do i have to retract the fact that i called him a W"%ker
SteamyTea replied to Big Jimbo's topic in Planning Permission
Quick look at a joist calculator and it is the difference between a 2" by 8" and a 2" by 10" But by having an extra meter on width, the stairs could be turned 90°, so shorter joists could be used, so probably not so different. I seem to remember that during mathematics classes there was a problem about making the largest volume container with a fixed amount of material. Was meant to show the power of calculus. https://www.analyzemath.com/calculus/Problems/maximum_volume_problem.html -
I am not 100% sold on that argument. If there was no such thing as a small house, then the replacement would be larger. The price points would be the same as that is what the consumer can afford. The 'loss' would just be on the land value. -
The Tank Arrives
SteamyTea commented on Patrick's blog entry in Timber Portal Frame - but stick built
Bit of subsidence there. -
Not in the ex industrial bit of Cornwall I am in. There are two Cornwalls. The picture postcard one and then the deprived area (one of the most deprived in Europe). To the best of my knowledge, they were built as a test for a new construction method. Then repeated a few thousand times across the county. Thing is, they are not that small compared to some newer places, and quite large compared to some of the old housing (most of Cornwall has only been developed in the last 200 years). I know my neighbour bought his place cheaper than it originally sold for, but that was the early 90's property slump that caused that. I don't think plot prices are reasonably priced, or easy to get hold of, from what I have been told. They are not Mayfair prices, but not giveaway either. -
Rust Removal Adventures: Electrolysis, Acid etc
SteamyTea replied to Onoff's topic in Tools & Equipment
Washer Woman Fingers surely. -
I never remember which way around they are. Is a TS a normal cylinder, and a UVC the one with the coil heat(s) exchanger in it only? They seem to be used interchangeably too much for my liking.
Not really as the water in the thermal store is not the water that you bath in, that just comes from the mains via the coil in the cylinder. And, as far as I know, there has not been a proven case of Legionnaires Disease in the domestic environment.
No idea. It was built in 1987, so probably plot, an old scrap yard, was sold 3 years before that. Really sad things they could have been built bigger if more imagination had been used. Had a discussion with caliwag on his blog about it. -
The 4 m by 7 m are the outside dimensions. It is on two levels, so that is 56 m2. It then looses half a metre because of walls, so 3.5m by 6.5m. 45.5 m2. Then there is the small porch for the front door (where you can't easily open both doors at the same time. Cornwall has many small places like this (several hundred around the corner from me). And yes, it is chalet sized. -
Turn it off before you go away maybe.
4 by 7ish 48 m2 in total internal space. One of the reasons that I bang on about small housing being dreadful. There are 6 houses where I am, and 15 people, soon to be 16. So that will be 18 m2 per person. Once you take away kitchens, bathroom and stairway, hall and landing, you are down to ~12 m2. Some vehicles are larger. -
Still bigger than the footprint of my house. -
Insulation thickness difference
SteamyTea replied to Russell griffiths's topic in Building Materials
http://www.circularecology.com/embodied-energy-and-carbon-footprint-database.html -
It is normal to oversize an ASHP, so you may well find that the 12 kW is the better fit. Under the old RHI rules, the ASHP had to supply enough energy 99% of the time before any suplimentary heating is required. Was a sensible rule.
Anyone else put up wall paper that looks like @Onoffroof? Should have used anaglypta.
Mate of mine bought a house of her. I said put a blue plaque up, but then, most houses in Bucks and Berks could claim she slept there.
