February 11, 20197 yr I'm putting 70mm of insulation under my joists. Using 100mm screws and insulation washers. Pesky little things insulation washers; they don't tell you which way round to attach them ..... Wrinkly side-up or smooth side up? Theres a bit of me which thinks that I should have the smooth side uppermost. But you know me and thinking about stuff. Too much too often. Does it even matter?
February 11, 20197 yr 6 minutes ago, recoveringacademic said: I'm putting 70mm of insulation under my joists. Using 100mm screws and insulation washers. Pesky little things insulation washers; they don't tell you which way round to attach them ..... Wrinkly side-up or smooth side up? Theres a bit of me which thinks that I should have the smooth side uppermost. But you know me and thinking about stuff. Too much too often. Does it even matter? One on the right
February 11, 20197 yr Author 5 minutes ago, nod said: One on the right Ok.... erm, why Gary? (sorry mate)
February 11, 20197 yr 1 hour ago, recoveringacademic said: Ok.... erm, why Gary? (sorry mate) Normally the flat side Against the insulation I don’t supose it would matter The left one would dig into the insulation when you knock it on
February 11, 20197 yr The one on the left. You want it so it sits flush and the screw is a bit into the insulation as if the screws are left proud the plasterboard may not sit flat.
February 11, 20197 yr Another vote for the one on the left, it is designed to bite into the insulation.
February 11, 20197 yr left one - -how you fitting drywall on top of this ? direct with screws or batons ? maybe make sure your drywall fixings don,t clash with theses fixings fixings done like left one could break the foil on insulation ? Edited February 11, 20197 yr by scottishjohn
February 11, 20197 yr Won't really matter as your going to have to screw it in far enough that it breaks the foil slightly so it sits flush or you will have bumps in the plasterboard. If you are going to batten over it then and board then it won't need to bust the foil.
February 11, 20197 yr Assuming you are battening. (I would. So I could use an auto feed gun for plasterboard) I can't see it would matter which way round. Just put a couple in per board and let the battens hold the sheets up properly. Also battens would allow a service void for all your lighting cables. (unless of course they already have a route)
February 11, 20197 yr 8 minutes ago, recoveringacademic said: You say potatoes I say patatoes. Interesting innit? Let's be honest.... You say taters
February 14, 20197 yr @recoveringacademicJust a thought, if you run out of those dreadful plastic things buy some of these instead loads better, sit flatter, don’t damage face of insulation so much.
February 14, 20197 yr On 11/02/2019 at 16:11, Construction Channel said: Assuming you are battening. (I would. So I could use an auto feed gun for plasterboard) I can't see it would matter which way round. Just put a couple in per board and let the battens hold the sheets up properly. Also battens would allow a service void for all your lighting cables. (unless of course they already have a route) fixing batons will be interesting as the fixings screws will need to be very very long 70mm foam +50mm baton=120mm + fixing in rafters =150mm+ ? sorry, re read 70mm insulation --sure in another post you said 80mm insulation --still a very long screws Edited February 14, 20197 yr by scottishjohn
February 14, 20197 yr 55 minutes ago, Russell griffiths said: @recoveringacademicJust a thought, if you run out of those dreadful plastic things buy some of these instead loads better, sit flatter, don’t damage face of insulation so much. Got a link? What are they called? ...other than "the blades from my old Mum's mincing machine"?
February 14, 20197 yr Author Thanks for the support. The thread on underboarding too early ( Woke up in a cold sweat ) is related to this one ; the advice @PeterW gave is the one I'd prefer to follow. (Place some 4 by 2 across the bottom of the rafters and butt the insulation up to that.) Recently I have been glancing at ceilings to see if I can detect the bumps made my the washers holding the underboarding. And of course, I hardly ever see any, because very few houses have underboarded rafters (I assume) - and I hardly ever get off the site. Nerd......
February 14, 20197 yr Wow @recoveringacademic your washers look like something from Hubble ! I ran out of penny washers to hold up my insulation and as the postie is away on holiday for two weeks I needed to improvise..... bandsaw, pillar - drill - bandsaws. Done ! Made about 100 in no time at all.
February 14, 20197 yr Author 4 minutes ago, Cpd said: [...] needed to improvise..... bandsaw, pillar - drill - bandsaws. [...] And I need to learn from you. Loadsa spare 3mm ply, a table saw, and drill. Job done.
February 14, 20197 yr 38 minutes ago, Cpd said: Wow @recoveringacademic your washers look like something from Hubble ! I ran out of penny washers to hold up my insulation and as the postie is away on holiday for two weeks I needed to improvise..... bandsaw, pillar - drill - bandsaws. Done ! Made about 100 in no time at all. Don't they need to be round!!
February 14, 20197 yr Author 1 minute ago, Pete said: Don't they need to be round!! Ok, I'll use a hole saw......?
February 14, 20197 yr 1 minute ago, recoveringacademic said: Ok, I'll use a hole saw......? OCD is your friend here!
