Gary G Posted September 13, 2018 Posted September 13, 2018 Hi all, My original drawings (attached) show Marley board to first floor and render to ground, however, I've had a quote for this come in and its eye watering! £42,000 to be precise. That is supply and fit of Marley lap and K Rend onto Aqua panel. Any suggestions for cheaper alternatives? Regs_Grey_B_L02_(1).pdf
PeterW Posted September 13, 2018 Posted September 13, 2018 That sounds well over the top..!! Have you looked at Cedral ..?
Triassic Posted September 13, 2018 Posted September 13, 2018 I’m watching this with interest, my design calls for a 50/50 mix of Cedral and Krend over render boards. So a cost effective solution is what I'm looking for.
vivienz Posted September 13, 2018 Posted September 13, 2018 Crumbs, that's quite a price. Is it worth getting a quote yourself on just the materials to check where the money is going and whether you;re paying over the odds for installation? I don't know if they stock it but I found Sydenhams to be very competitive on pricing and at least it would give you a guide.
Gary G Posted September 13, 2018 Author Posted September 13, 2018 I was hoping for around half that cost and a maximum budget of £30k to clad the exterior. Working on a materials only price now. To be honest wish I hadn't gone 50/50 split on finishes as it complicates things a bit.
vivienz Posted September 13, 2018 Posted September 13, 2018 FWIW, I'm having vertically hung slate on the top storey and Tier system stone slips on the ground (and the full height stairwell). I reckon the tier cladding will come at about £9k, installation cost TBC.
PeterW Posted September 13, 2018 Posted September 13, 2018 3 minutes ago, Gary G said: I was hoping for around half that cost and a maximum budget of £30k to clad the exterior. Working on a materials only price now. To be honest wish I hadn't gone 50/50 split on finishes as it complicates things a bit. May help you. Cladding Calculator Whats the area for both cladding and render ..?
K78 Posted September 13, 2018 Posted September 13, 2018 Is K rend not vastly inferior to modern products?
Gary G Posted September 13, 2018 Author Posted September 13, 2018 House is approx 13m x 8m so call it 100sq m and it's two storey. No idea about K Rend, what are the alternatives?
K78 Posted September 13, 2018 Posted September 13, 2018 28 minutes ago, Gary G said: House is approx 13m x 8m so call it 100sq m and it's two storey. No idea about K Rend, what are the alternatives? I attended a durisol course this week. They mentioned that modern polymer renders were a lot better than k rend. I didn’t pay much attention to the polymer renders as I’m using timber cladding.
Triassic Posted September 13, 2018 Posted September 13, 2018 No doubt someone with experience of modern renders will be along to enlighten on which is best.
Pete Posted September 13, 2018 Posted September 13, 2018 I have put the timber battens and moisture resistant render board on my house, approximately 280sqm and that cost about £4000. I have had the Parex thin coat system put on top and that has cost £15400.
Russell griffiths Posted September 13, 2018 Posted September 13, 2018 Has anybody looked at bringing this stuff in from abroad i used an acrylic thin coat render on a house in oz and the prices over here seem crazy they have whole showrooms over there just selling render and plastering products i will try and remember the company
Triassic Posted September 13, 2018 Posted September 13, 2018 1 hour ago, Pete said: approximately 280sqm ............ I have had the Parex thin coat system put on top and that has cost £15400. I must admit I was somewhat taken aback by the price!
Russell griffiths Posted September 13, 2018 Posted September 13, 2018 Found it https://www.rockcote.com.au/ i was bored.
nod Posted September 13, 2018 Posted September 13, 2018 1 hour ago, Triassic said: No doubt someone with experience of modern renders will be along to enlighten on which is best. I regularly use most of the through coloured renders K rend silicon based is as good as anything out there Though we try not to use Webber
nod Posted September 13, 2018 Posted September 13, 2018 15 minutes ago, Triassic said: I must admit I was somewhat taken aback by the price! That price is top Hevey We would charge £11200 Not including scaffolding
Weebles Posted September 13, 2018 Posted September 13, 2018 3 hours ago, Gary G said: Hi all, My original drawings (attached) show Marley board to first floor and render to ground, however, I've had a quote for this come in and its eye watering! £42,000 to be precise. That is supply and fit of Marley lap and K Rend onto Aqua panel. Any suggestions for cheaper alternatives? Regs_Grey_B_L02_(1).pdf Our first quote (the finished look is part render, part Cedral vertically mounted) came in at £80K. Your 42K looks like a bargain to me ? Got some guys coming out tomorrow from Cedral, the render company and the installing company to see how they can make it all fit cleanly together and what battens need to be used. Not the guys who quoted £80K! Would be simple if the total depth of finish was the same or similar. But it is not. Will see what the outcome is and post an update.
Mr Punter Posted September 14, 2018 Posted September 14, 2018 Brickwork often works out a much cheaper option for external skin. 1
Dreadnaught Posted September 14, 2018 Posted September 14, 2018 13 minutes ago, Mr Punter said: Brickwork often works out a much cheaper option for external skin. Might that include brick slips (an option I am considering)?
vivienz Posted September 14, 2018 Posted September 14, 2018 The Tier stone cladding system I'm using on my ground floor and stairwell comes as stone slips on a z-shape board. The best price I got was just over £47 ex VAT per square metre, from Sydenhams.
Pete Posted September 14, 2018 Posted September 14, 2018 23 hours ago, Triassic said: I must admit I was somewhat taken aback by the price! That's the going rate. Had 5 quotes and all around same price. Not a DIY job and it is a timber frame so cannot use traditional render. Looks good though. Scaffold down this week so may have some pics
ProDave Posted September 14, 2018 Posted September 14, 2018 My house is about 140 square metres over 1 1/2 storeys. I have never worked out the external wall area. It is clad in 100mm thick wood fibre board and rendered with the Baumit.com thin coat render system. I can't give a cost for the wood fibre board as that was lumped in with the build and erect of the timber frame so I don't have an itemised price. The render material cost £4397 and the labour for the renderer cost £4750 Scaffold (my own) was already in place. This is the wood fibre board we used chosen from the first supplier I could find just now doing a quick search https://www.insulationsuperstore.co.uk/product/diffutherm-external-woodfibre-insulation-for-render-100mm-080m2.html I am absolutely certain our builders paid a lot less than that price for it. The base coat render is mixed from a powder https://www.baumit.co.uk/products/external-insulation/starsystem-nature/multi-contact-mc-55-w.html And this is the top coat render ready mixed https://other.baumit.com/products/exterior-insulation/starsystem/baumit-silikontop.html The whole point of doing it this way, is you are paying for a board to clad the frame with to apply the render, so it might as well be a board that adds a bit more insulation to the building.
Pocster Posted September 15, 2018 Posted September 15, 2018 Cedral is expensive- and can be time consuming to install ( especially on your own ). That price seems well over the top !!
