bit dizzy as you're working?  Looks a bit too late for the stand....
I just point mine away from any walls etc
32 minutes ago, pocster said:
Only just discovered this ! Dead handy !!
How do you put stuff in there!
Far easier not to overload the mixer, and put it on a square of membrane.
In theory
I’ve had the mixer facing away from a wall . Bit splashes out into the floor - some of it went behind and hit the wall
Use to put a sheet down and not overload . Still get splashes on things you don’t want splashed . This does the trick !!! ?
Just now, pocster said:
In theory
If you stand in front of it and stare into it like it's a black hole abyss then the wall won't get hit. This might be a bit of an issue for you in your normal state of undress but am sure you would get used to cement burns on your delicate bits.
  • Haha 1
Soon I’ll be doing the block paving which has to bedded in concrete .
Needless to say ; I need to mix concrete and not have it splash over my paving , or wall , or cladding , or fence !!
plastic sheet on floor and ‘magic lid’ seems good.
You are all obviously tidy and make no mess . I function differently ??
Edited by pocster
Cant fucking type !
43 minutes ago, Russell griffiths said:
Bugger me I’ve never seen one of them. ??
Ahhhhh ! Then it was worth the post to find an accomplice! eBay is your friend !
Does it just wedge in tight and can you take it off easily enough??
Most mixers I ever used had been on the end of quite a few bangs with hammers and shovels so the front was more egg shaped.
Lol !
i had to bang quite a bit of crud off for it to fit . Not tight at all ; but doesn’t fall out either !
