Big Jimbo Posted Tuesday at 18:32 Posted Tuesday at 18:32 @SteamyTea Will you still do me a Dirty Donna, if i am ever down your way ?
SteamyTea Posted Tuesday at 18:39 Posted Tuesday at 18:39 4 minutes ago, Big Jimbo said: @SteamyTea Will you still do me a Dirty Donna, if i am ever down your way ? Donna Donna still got no knickers on er. (I can't look at Christmas reindeers without saying that out load when children are about) 1
SimonD Posted Tuesday at 19:37 Posted Tuesday at 19:37 1 hour ago, JohnMo said: That maybe the issue (haha) - technician, not an engineer. 1 hour ago, SteamyTea said: Chartered Engineers are what are really needed. 1 hour ago, JohnMo said: had zero idea how to manage drawing revisions. 1 hour ago, SteamyTea said: The problems usually arises 'on the shop floor', not in the drawing/engineering office. Engineers not needed at all. 😉 A long long time ago in what feels like a galaxy far far away, I used to run document control for projects building anything from oil rigs and oil refineries to pharmaceutical plants all over the world. The engineers used to come crawling to us to ensure the right drawing versions were in the right place and the right time, especially when we got to construction drawings and sub-contract tender and issue. Nowadays, unless you've got good prior experience, some companies like the one I worked for ask for a Masters in Library Science for senior roles doing this.
SimonD Posted Tuesday at 19:52 Posted Tuesday at 19:52 On 16/03/2026 at 19:16, flanagaj said: Would you still check even though it was set out with a total station? In case it helps you to feel better, we had a full topographical and lazer scan of the existing building to provide base dwg files as most of this was staying in place, then had a measurement survey by an architectural technician and again by an architect. I had to admit I thought we had it covered until a Polish brick layer kindly informed me that the back of the existing house was 120mm longer than the front. Cue a run to the phone to stop production of the curved glulam beams all ordered at the same length. In the end the glulam company did a fantastic job of manufacturing 3 different length curved beams for the main structure. The only pain for me was laying the metal standing seam roof onto a not square roof and hiding that it's not quite square! As lesson learned in not demolishing and starting again, but I do wish professionals could measure properly 🙄 1
SteamyTea Posted Tuesday at 19:55 Posted Tuesday at 19:55 2 minutes ago, SimonD said: but I do wish professionals could measure properly Maybe @craig can shed some light on this, he has people out measuring I think.
JohnMo Posted Tuesday at 21:23 Posted Tuesday at 21:23 My guy (arranged by our ground workers) came with drawings loaded into his computer, tied into GPS, then using another bit, just picked the points of one by one, even told me exactly how much higher the site was to the plan. Marked out the foundations, once foundations were done, can and marked out for the blocks. Spent an hour or so at site in total. Technology working. Check measured it all and couldn't find an issue and foundations are pretty complex, compared to anything else I've seen.
ToughButterCup Posted Wednesday at 08:33 Posted Wednesday at 08:33 13 hours ago, SimonD said: .... some companies like the one I worked for ask for a Masters in Library Science for senior roles doing this. Now thats both interesting and reassuring.
craig Posted Wednesday at 10:02 Posted Wednesday at 10:02 (edited) 14 hours ago, SteamyTea said: Maybe @craig can shed some light on this, he has people out measuring I think. Ya think? My last project (Passive House), was a ****ing nightmare. Every opening was in the region of 5mm to 30mm out in height/width (100mm inner block, 120mm xps, 100mm compacfoam, 30mm cavity, 100mm outer block). So every opening was a shambles, the cavity which was 30mm, was if you were lucky 30mm at the bottom, and up to 60mm at the top. Most openings the cavity ranged from 10mm to 70mm at the bottom. Measure? Are you joking? Build? are you joking? It's very, very rare things are spot on and folk wonder why the tolerances on things are big. A Passive House care home I worked on with a very large developer. The building was in the wrong position by 20mm, throwing out all the brick work for the facade, all the floor levels were wrong (5 stories), resulting in mat wells at all doors. I wish I had a magic wand. A "Grand Designs The Street" project, resulted in the window having to be adjusted (on air) because the kit tolerances were maxed out and coupled window frames were maxed out, meaning the 20mm tolerances in width we had for the opening no longer existed and the units were now too big. Edited Wednesday at 10:06 by craig
Oz07 Posted Wednesday at 10:16 Posted Wednesday at 10:16 12 hours ago, JohnMo said: My guy (arranged by our ground workers) came with drawings loaded into his computer, tied into GPS, then using another bit, just picked the points of one by one, even told me exactly how much higher the site was to the plan. Marked out the foundations, once foundations were done, can and marked out for the blocks. Spent an hour or so at site in total. Technology working. Check measured it all and couldn't find an issue and foundations are pretty complex, compared to anything else I've seen. They are good. What did he charge per visit? Do you have to have 3 visits including initial topo of site?
JohnMo Posted Wednesday at 16:08 Posted Wednesday at 16:08 5 hours ago, Oz07 said: They are good. What did he charge per visit? Do you have to have 3 visits including initial topo of site? Architect did the topo as part of the initial planning. Cost me nothing for the GPS mark out, the ground workers included in the costs they quoted me, GPS is part of the base scope.
Oz07 Posted Wednesday at 18:25 Posted Wednesday at 18:25 2 hours ago, JohnMo said: Architect did the topo as part of the initial planning. Cost me nothing for the GPS mark out, the ground workers included in the costs they quoted me, GPS is part of the base scope. There's no such thing as a free lunch you're always paying someone to do it. I get your point though if groundworkers quoted you a package with it included. Every time ive built ive got away with an os map on the planning and heights being marked on elevations. Never needed a topo upto now so have always marked out with lines and profiles. I accept its probably not cost effective on a more complex layout though. Particularly if there's other paid work you could be doing. I suppose like all self build its a trade off of time for£
SteamyTea Posted Wednesday at 19:32 Posted Wednesday at 19:32 @saveasteading and other interested parties On 17/03/2026 at 17:59, SteamyTea said: Somewhere at home, in my vast library of mathematic's books Here is part of it, no tape measure needed ( @Pocster ).
saveasteading Posted 15 hours ago Posted 15 hours ago On 17/03/2026 at 19:52, SimonD said: but I do wish professionals could measure properly 🙄 Good professional measurers can, and do. Some people charge money and think they can do it. Once they've been charged consequential costs a few times, they'll stop offering it. Hence back to my mantra.. after they've gone, check the fundamentals with tapes and a level, however primitive and mainly stand back and consider if it looks right.
SimonD Posted 14 hours ago Posted 14 hours ago 58 minutes ago, saveasteading said: Good professional measurers can, and do. Yeah, but like with just about everything we see on here at BH, we have a magnifying glass on the poor experiences of self-builders which shows it's incredibly difficult to find good professionals in just about every area of domestic building in the UK. E.g. I paid 3 sets of professionals and all three made fundamental mistakes and it was a humble bricklayer who knew how to use a tape measure and square properly in the end. And then the glulam manufacturer sent out a surveyor to confirm measurements before commencing production. All good then. 1 hour ago, saveasteading said: Hence back to my mantra.. after they've gone, check the fundamentals with tapes and a level, however primitive and mainly stand back and consider if it looks right. Yes, totally. I got laughed at when I was seen with my own home made water level fixed to a datum point on my steel frame with more than 25m long tubing, going round the house to check my levels on the rebuilt brick walls, wall plate and glulam ring beam. Why not use a lazer level they said and I showed them than it some critical areas there was no line of sight and a water level was more accurate because of it. In the end, I think I had a deviation on one corner to corner level of 3mm thanks to this. It was brilliant also for measuring trench depths and topographical measurements as you don't have the issues with sight of lazer in sunshine, even when you use a green lazer and sensor. I still have it coiled away for the landscaping to come. 1
saveasteading Posted 13 hours ago Posted 13 hours ago 1 hour ago, SimonD said: home made water level I've never known a faulty one. The other huge advantages are in being a one person operation and bypassing obstructions. I think it's cheap to buy one to reduce amusement.
ToughButterCup Posted 12 hours ago Posted 12 hours ago On 18/03/2026 at 10:02, craig said: Ya think? .... Measure? Are you joking? Build? are you joking? It's very, very rare things are spot on and folk wonder why the tolerances on things are big. ... And yet.... and yet... houses do get built. I think this thread is another data point underscoring the aphorism that; Systems and people show themselves for what they really are when -not if- things go wrong 1
SteamyTea Posted 12 hours ago Posted 12 hours ago 29 minutes ago, ToughButterCup said: Systems and people show themselves for what they really are when -not if- things go wrong I work at a place that refuses to have systems in place. The rule seems to be to use any exceptions as the normal practice. It's a (expletive deleted)ing disaster. Took me 2 years, bollockings and general tantrums to get a drip tray emptied every day. Takes about 20 seconds to do it. The reason given for not doing it was generally 'it was not full yesterday'. (expletive deleted)ing overflowing onto the floor now though, isn't it.
Iceverge Posted 11 hours ago Posted 11 hours ago 2 hours ago, SimonD said: Yeah, but like with just about everything we see on here at BH, we have a magnifying glass on the poor experiences of self-builders which shows it's incredibly difficult to find good professionals in just about every area of domestic building in the UK. E.g. I paid 3 sets of professionals and all three made fundamental mistakes and it was a humble bricklayer who knew how to use a tape measure and square properly in the end. And then the glulam manufacturer sent out a surveyor to confirm measurements before commencing production. All good then. Yes, totally. I got laughed at when I was seen with my own home made water level fixed to a datum point on my steel frame with more than 25m long tubing, going round the house to check my levels on the rebuilt brick walls, wall plate and glulam ring beam. Why not use a lazer level they said and I showed them than it some critical areas there was no line of sight and a water level was more accurate because of it. In the end, I think I had a deviation on one corner to corner level of 3mm thanks to this. It was brilliant also for measuring trench depths and topographical measurements as you don't have the issues with sight of lazer in sunshine, even when you use a green lazer and sensor. I still have it coiled away for the landscaping to come. And it accounts for the curvature of the earth.
Oz07 Posted 10 hours ago Posted 10 hours ago 1 hour ago, Iceverge said: And it accounts for the curvature of the earth. How big is this house 🤯 1
craig Posted 9 hours ago Posted 9 hours ago 3 hours ago, ToughButterCup said: And yet.... and yet... houses do get built. I think this thread is another data point underscoring the aphorism that; Systems and people show themselves for what they really are when -not if- things go wrong I tend to go with adapt and overcome. 1
saveasteading Posted 8 hours ago Posted 8 hours ago 30 minutes ago, craig said: I tend to go with adapt and overcome. Our patio doors started going in today.... and the threshold levels were wrong, or incopmpatible...it doesn't matter except that they didn't fit. That's with me and mine being perfect, remember. It's sorted now, due to collaborative working...and us paying a daywork guy to sort it instead of the intended work. It will always happen.
ToughButterCup Posted 4 hours ago Posted 4 hours ago 7 hours ago, SteamyTea said: I work at a place that refuses to have systems in place. The rule seems to be to .... I learned that the hard way too. For me the rule has become: work with people who raise my game: as well as force me to think hard, but laugh harder.
