3 hours ago, SteamyTea said:
Absolutely, I played a small part in the magnox life extensions (Wylfa in particular)
I'm sure the reactors will be kept running well beyond 2060 - which only compounds the uncertainty that EDF or it's successor will be around to honour it's commitment to decommissioning.
There is a huge list of giant engineering companies that were around 50 years ago and aren't now.
1 hour ago, scottishjohn said:
hydro scheme on the river Dee in s.w scotland -uses same water 3 times
Interesting. Does this mean there are three dams of relatively low output rather than one huge one?
Like in earlier centuries,  having several flour mills along a stretch of river?
3 minutes ago, saveasteading said:
I hadn't heard of that. Do you know why it can't remain as a base
Possibly because when a windfarm is retooled, they put larger turbines on them.
Or it is just made up, like the 'million pounds of concrete needed'.
Offshore turbines use a lot less concrete and they drill a large hole and grout a steel base in (there is a company down here that makes the rigs to do this).
Maybe @Gus Potter can give some insight as to the design.
I get a bit stuck when converting the forces for, say, a 5MW turbine that is 125m heigh.  I think 1 Nm.s-1 = 1W.
The diameter of the base will make a difference.
3 hours ago, -rick- said:
Well quite, it's why I'd expect a new plant to be designed to last at least as long without the expensive life extension.
Obviously maintenance, even fairly expensive maintenance, will be required to last that long. But if planned for upfront it's a lot cheaper than just building for 30 years and dealing with extension at a later date.
You don't want to know how little planning for decommissioning was done for the early reactors (magnox, agr etc).
Lots of stuff inaccessible, an unbelievable amount of stuff undocumented or not to the plans!
We did design work for robotic decommissioning - really expensive special purpose robots and manipulator ms to go in and undo a nut or grind off a weld. The sort of thing a man with a spanner or grinder could do in an hour - which I think was the orginal plan when they designed some of these in the late 50's and 60's!
2 hours ago, -rick- said:
Sure. I would expect that for a plant opening today that very few of the components would be original in 30 years time. But that to me is maintenance. If our existing fleet is running for 50 years, it just seems like we should design new plant to have the same life (with the expected maintenance).
It's the parts that can't easily be swapped out that need to be designed to live the longest. And if we have managed to get parts that we built 40-50 years ago to live until today then we should be able to design the new parts to do the same. Not maintenance free for 50 years, but to last 50 years with planned and scheduled maintenance. Most importantly with a design that allows for all the maintenance tasks we have found necessary on the old plant to be possible and planned for on the new plant.
This is part of thr high running costs.
Nobody can design such a critical bit of equipment not to fail ever. What we can do is have an inspection and testing regime to catch any failure before it is catastrophic. So when they design a weld or a pipe or a valve, it's limits for fatigue, temp cycling, corrosion, embrittlemnt etc are all calculated and an inspection regime is decided. Then the item is inspected to make sure it is to spec, then it"s inspected using all sorts of expensive stuff and the results fed back into the simulations to check it's "on track" and adjustments to inspection regime made on light of the actual performance.
It's a huge undertaking
Did you have a hearty breakfast to start the day.
Edited by SteamyTea
2 hours ago, scottishjohn said:
wind power --who in their right mind would sign a contract that says they get paid if they turn them off
I would love to have run a company  where i got paid if I did not produce anything
If you were contracted to produce cakes for wedding, you produced them and the customers courier couldn't make the lick uk because their vans were all busy - would you want to be paid? I suspect yes.
The curtailment payments are due to the grid not being able to transport the contracted for power - which is a separate issue that is being addressed - and happens to gas (and once upon a time coal) plants as well
if you work out how much pollution is caused making the things and the amount of c02 in the huge concrete bases
and when they get replaced they need a new base --it just don,t stack up
This is false. The meme was popularised by the series "landman" where billybob Thornton goes on a (wrong) rant about wind turbines.
The carbon payback for wind turbines varies from 6-18months.
The bases vary depending on ground conditions but typically 100m3 per MW - so between 100-600m3 per turbine.
But concrete is not unique to wind turbines. Hinckley C has over 40,000m3 in just one of the two reactor foundations.
The turbine blade problem is real but more a function of composites not yet generally being recycled. This is changing but the current best practice it to recycle the blades by grinding them into particles and (you'll like this) using them in concrete..... 😁
I suppose anybody who wants wind turbines to be built and for the electricity they produce to be affordable. CfDs reduce risk for the generators. Without them, generators would be asking higher prices for their electricity to reflect the risks they would be required to take on.
and if you work out how much pollution is caused making the things and the amount of c02 in the huge concrete bases
Yes, it does stack up, hugely. The parameter you need to look at is the life cycle greenhouse gas emissions, measured in grammes of CO2e, per kWh of energy produced over the life of the asset. Results as follows (median values of the assets they studied):
  • Coal: 1004 g
  • Natural Gas: 458 g
  • Solar PV: 53 g
  • Offshore wind: 18 g
  • Onshore wind: 12 g
  • Nuclear: 6 g
(Clearing the Air, Hannah Ritchie, data source UN Economic Commission for Europe, 2021)
we have hydro scheme on the river Dee in s.w scotland -uses same water 3 times and was built in1937
 still running now --that is the right way
hydro and tidal barages
According to Drax Group who operate the Lanark and Galloway run-of-river hydro schemes, located in south-west Scotland, it generates 126 MW. Yes, that's nice but it's not going to get us far in the energy transition. The latest allocation round for offshore wind (AR7) procured 70 times that capacity, 8.4 GW.
the desert in america is full of old wind turbine blades that they cannot recycle economically - so they just lie there
So what? The embedded CO2 in the blades is taken into account in the above life cycle numbers. It's just a waste disposal issue. Same or worse for end of life fossil assets, many of which contain far worse materials - asbestos, mercury and other heavy metals, spent catalysts, etc.
Ha! 😁
No but I did have to "bunny suit up" amd wear a dosimeter for working on the lab and go through a radiation scanner on the way out each shift. Was an interesting job.
4 hours ago, SteamyTea said:
There must have been times during the day that you did not close a sale. But you still got paid at the end of the month.
There are many different business models, the energy market is not the same as secondhand car sales.
only if i sold osme -wind men get money when the turbines are sitting doing nothing --thats the difference
2 hours ago, saveasteading said:
I hadn't heard of that. Do you know why it can't remain as a base?
stress over time on the fixings etc -so they dig it up and start again
Aye and no. Below is a good photo of a small turbine base.. I'm the (expletive deleted)wit on the far left. Doing the corporate stuff but thinking.. this is not maybe that good for the enviroment and creating jobs as puported.. But I've got much better looking as I've aged, taller also! Every cloud has a silver lining.
I can't remember the output of the turbine, tall from memory, but not that big, just a farmer getting some extra income. I think you can see it from the M8 motorway in Scotland.
What it does show is the amount of rebar that goes into something like a modest wind turbine base. It's practically there forever pretty much.
It does as the more you increase the height the larger the base needs to be to resist the dynamic wind forces. It's not just the over turning effect it's the constant variation in dynamic loading. Mother earth does not often appreciate this kind of "vibration" and load change.
We need mass concrete.. when poured it gets hot! It cracks and shrinks and curls up like fury and part of all that rebar you see is to control that cracking and curling effect. If you put a pork chop in a frying pan it often curls.. same to some extent happens with concrete.
Technically concrete has two dominant forms when it is cast. One is plastic shrinkage.. that is when the chemicals in the concrete are busy creating the concrete we see.. this can apply to  raft floors in self builds. The other is drying shrinkage, less dominant in turbine founds in say CLAY soil.. but in SANDS in England drying shrinkage is a consideration. Drying shrinkage is probably the dominant factor in self build rafts / screeds and so on.
If you look up the construction videos of the Hoover dam this is well explained about how you need to control the heat in mass concrete.
Now you don't have to be an SE to figure out that wind turbines are maybe not as eco friendly as at first glance?
Below is the bit in the middle that the concrete ring sits onto.. to which the nice bit of steel turbine gets attached to. That's the bit you see above ground.
Now it's almost impossible to upgrade a turbine base.. unless the tax payer is footing the bill. In that case it all hands on deck for a great design fee.. all paid for by the public of course.
I'd be very surprised if there isn't a way. Needs some early collaboration between the parties rather than a linear design process.
Having spent a lot of time in such cages, doing qc, I'm left wondering how the steelfixers got out.  And how the concrete got to the bottom... how do we know it is well compacted?
Doing the site inspections was much easier than the fixers job so it breeds respect for them and the detailer (both the Engineer and their draughts- person)... and my own designing for ease (feasibility) of construction.
Nice post and I love the pictures but please can we kill the myth that renewables are not eco friendly because of the materials used in their construction. The data speak for themselves. See my earlier post. CO2e, per kWh of energy produced over the life of the asset for your onshore turbine is 12 g CO2e and to produce the same energy from e.g. natural gas it's 458 g. That includes the embedded carbon in the concrete.
I'm all for renewables and a full supporter that we need and must go in that direction. I remember having coffee with a friend about 20 years ago while I was doing a post grad certificate in renewable engineering and technology, telling him that renewables are a no brainer - he thought I was a bit mad. However, like my earlier post, we've got to be very careful about how we measure and assess the environmental impacts of what we're doing. I, personally, have long been a critic of the singular approach using Carbon and rather prefer a measure that takes a much wider approach to consider overall environmental impact. Concrete unfortunately is one of those materials that is made up of non-renewable resources and the extraction of the sands and aggregates are causing widespread environmental damage right across the world - and we know the availability of the raw materials is in decline. What we need to be doing is finding alternative materials that are not single use, but also renewable in their own right, which we know concrete isn't at least not at the same level of 'value' - e.g. it can only be re-used for lower value purposes when recycled. This is a big problem, mostly overlooked.
The argument about what is eco friendly is as all these things more complex and nuanced than oft portrayed. I wonder whether this is what @Gus Potter is referring to?
I'd say so.
Most people just see what they see and won't be aware of the other issues.
Filling a hole with concrete and steel is the obvious thing to do so that's what happens.
They could be bolted down to exposed rock, use piles as support, include voids or mass materials in lower stress areas, reuse the excavated material  include recycled aggregate.  But with concrete readily available  then that's what happens.
Actually I don't know. Maybe other methods are already utilised.
Same here, I'm too far out of the game to know what's at the forefront. But I do know some people at the research end doing some fascinating work on the renewables side, which if implemented will be both much more environmentally friendly and provide more guaranteed output around the UK - but like all these things the struggle seems to be taking these things from research to implementation.
That is how we end up with golf courses claiming good environmental and sustainable credentials when compared to a farmed field.
I want a farmed field to have low biodiversity, I don't want slugs, rabbit's feet and deadly nightshades in my cornflakes.
There is an economic model to help value nature, been a while since I used it, but was interesting research.
Could larger turbines fitted to existing bases not be fitted with radial anchor cable supports like communication masts?
As for the blade recycling issue this is well wnown and is mainly due to the recycling facilities not being available rather than it not being possible.
Some companies are experimenting with LVL blades, and the  company I work for has also provided LVL and technical assistance for another experimental build with a wooden tower and nacelle too.
We just need a paradigm shift in foundation design as well (for general building as well as large projects since most house foundations are vastly overspecced).  But we are getting there.
Of course the major plus point with renewables is that we can deal with any waste at leisure (except perhaps some solar panel components) - we don't have to carefully dismantal and lock the materials away for millions of years and trillions of quids
'World's first' wooden wind turbine blades installed in Germany
