Mr Punter Posted August 12, 2022 Posted August 12, 2022 I am not sure what the point is. I ca see a hole in the outer leaf of a wall and a lintel or floor plank where it looks like someone has tried to core through?
markc Posted August 12, 2022 Posted August 12, 2022 Oops, someone fitting an extractor and didn’t think to keep it away from a door or window
Radian Posted August 12, 2022 Posted August 12, 2022 When I first saw the photo I thought someone had fired a cat at hypersonic speed at the wall. Like you do. 1 6
Canski Posted August 12, 2022 Author Posted August 12, 2022 2 hours ago, Mr Punter said: I am not sure what the point is. I ca see a hole in the outer leaf of a wall and a lintel or floor plank where it looks like someone has tried to core through? There was an extractor fan 'fitted' there. I guess whoever tried to core drill for the extractor hit the lintel then decided to fit it anyway. 1
Mr Punter Posted August 12, 2022 Posted August 12, 2022 I still don't get it. The bit with the motor is normally inside. Was this just a plastic vent, or a fully wired in mechanical extract?
Pocster Posted August 12, 2022 Posted August 12, 2022 (expletive deleted)ing amateurs - makes my blood boil !
MikeSharp01 Posted August 12, 2022 Posted August 12, 2022 It looks like they drilled some small holes to let a bit of air through - still a bodge of the first water.
Nickfromwales Posted August 12, 2022 Posted August 12, 2022 4 hours ago, Mr Punter said: I still don't get it. The bit with the motor is normally inside. Was this just a plastic vent, or a fully wired in mechanical extract? Yes, and the cocks fitted that on the internal wall........presumably after coring out and realising there was a Catnic in the way! The round hole in the outside skin of brickwork is where the 100mm through-wall vent duct and plastic grille were then fitted ( doing the square root of SFA ) to hide the fcuk up. They clearly knew they'd dropped a bollock as there are some small holes drilled so they could get a whiff of air through, plus what looks like a failed ( or more likely abandoned ) attempt to drill a 50mm hole with a bi-metal holesaw. Probably limited to the number of tools they could fit in the saddle-bag 1
MikeSharp01 Posted August 12, 2022 Posted August 12, 2022 15 minutes ago, Nickfromwales said: number of tools they could fit in the saddle-bag Looks like they had a couple of tools on the front seats of the van. 1
PeterW Posted August 12, 2022 Posted August 12, 2022 1 hour ago, Nickfromwales said: Probably limited to the number of tools they could fit in the saddle-bag its usually because the spurs stop them climbing the ladder ….
Nickfromwales Posted August 12, 2022 Posted August 12, 2022 We're really not helping are we?!? LOL Apologies, I'm stuck in a hotel, arrived back late, and am now drinking to catch up ( under duress of course ).
Canski Posted August 12, 2022 Author Posted August 12, 2022 3 hours ago, Nickfromwales said: Yes, and the cocks fitted that on the internal wall........presumably after coring out and realising there was a Catnic in the way! The round hole in the outside skin of brickwork is where the 100mm through-wall vent duct and plastic grille were then fitted ( doing the square root of SFA ) to hide the fcuk up. They clearly knew they'd dropped a bollock as there are some small holes drilled so they could get a whiff of air through, plus what looks like a failed ( or more likely abandoned ) attempt to drill a 50mm hole with a bi-metal holesaw. Probably limited to the number of tools they could fit in the saddle-bag Great post and I really couldn’t have worded it better. Exactly that. I think they glued the 2 grills on and ran. 😂😂
Canski Posted August 12, 2022 Author Posted August 12, 2022 To be a little bit fair. The lintel had about 450 mm bearing so when they started drilling they wouldn’t have expected that. This highlights the need to have accurate plans on new builds. And the golden phrase ‘every action has a reaction ‘
Nickfromwales Posted August 13, 2022 Posted August 13, 2022 7 hours ago, Canski said: To be a little bit fair. The lintel had about 450 mm bearing so when they started drilling they wouldn’t have expected that. This highlights the need to have accurate plans on new builds. And the golden phrase ‘every action has a reaction ‘ Nah, you always stick a skinny 6 / 8mm drill bit through before coring out, through the repairable cement ( pointing ) to see if the lintel fitted was oversized. Some lintels are ‘too big’ because that was the one that was available on the day of purchase. Always mark the hole out but then, first, drill a test hole the side nearest the opening to ascertain that you’ll defo miss the end of the lintel. 2nd year apprentice stuff tbh. 1
ProDave Posted August 13, 2022 Posted August 13, 2022 The house next to us, the owner / builder realised on the morning BC was coming for final inspection, that he had not fitted an extractor in the utility room. So he quickly cut a hole in the plasterboard and fitted a fan. It is not wired and not connected to outside. BC did not notice and it has been like that for 19 years through 2 changes of owner and still doing nothing. 1 1
saveasteading Posted August 14, 2022 Posted August 14, 2022 On 12/08/2022 at 13:10, Canski said: decided to fit it anyway. Those of us who can handle a tape measure, don't always appreciate that transferring a position from inside to outside ca be tricky, involving logic and sums. and then a cautious pilot hole. That is my guess of the issue that was then abandoned.
Pocster Posted August 14, 2022 Posted August 14, 2022 4 minutes ago, saveasteading said: Those of us who can handle a tape measure, don't always appreciate that transferring a position from inside to outside ca be tricky, involving logic and sums. and then a cautious pilot hole. That is my guess of the issue that was then abandoned. Measuring is the most complex task for sure . Transferring a measurement for outside to inside is indeed impossible. I know I’ve tried it . 1.2m on the outside ; inside it becomes 1.5m . It’s an impossible task 😞
Mr Punter Posted August 14, 2022 Posted August 14, 2022 I often see plumbers who drill from the inside. No pilot or careful drilling, just straight through for an overflow, condense or blow off pipe, spalling the brick face or render as they go.
Pocster Posted August 14, 2022 Posted August 14, 2022 9 minutes ago, Mr Punter said: I often see plumbers who drill from the inside. No pilot or careful drilling, just straight through for an overflow, condense or blow off pipe, spalling the brick face or render as they go. Thanks for at least calling me a plumber ! 1 1
Temp Posted August 15, 2022 Posted August 15, 2022 On 14/08/2022 at 17:18, saveasteading said: Those of us who can handle a tape measure, don't always appreciate that transferring a position from inside to outside ca be tricky, What you need is a small directional radioactive source and stick it to the wall, then go outside and find it with a Gieger counter 🙂 Or perhaps not.
Simplysimon Posted August 15, 2022 Posted August 15, 2022 On 14/08/2022 at 17:50, pocster said: Thanks for at least calling me a plumber ! well we sure as hell ain't going to call you a glazier 😂
puntloos Posted August 15, 2022 Posted August 15, 2022 21 minutes ago, Simplysimon said: well we sure as hell ain't going to call you a glazier 😂 He's kind of a b*llocks glazier. Which sounds.. painful but artsy.
Radian Posted August 15, 2022 Posted August 15, 2022 3 hours ago, Temp said: What you need is a small directional radioactive source and stick it to the wall, then go outside and find it with a Gieger counter 🙂 When we were looking for the position of a blockage in an underground storm water pipe I made a gadget that created a really big 1mHz magnetic field and a tuned receiver with an LED crossbar display. It could pinpoint the end of the drain rod we taped it to to within about 75mm when the vertical separation was around 0.75m. The error through a wall at half that depth would surely be small enough for this kind of thing. I must dig it out and test it properly. I did originally try it out through walls inside the house including one that had a steel radiator on one side. Against my intuition it still worked in this situation although I didn't pay attention to accuracy. 1
saveasteading Posted August 15, 2022 Posted August 15, 2022 2 hours ago, Radian said: It could pinpoint the end of the drain rod So can a piece of tape on the rod, and lay the rod on the surface over the drain run...but yours is more fun.
