Construction Channel Posted April 13, 2018 Share Posted April 13, 2018 2 pockets would be an extravagance! Link to comment Share on other sites More sharing options...
Onoff Posted April 13, 2018 Author Share Posted April 13, 2018 23 minutes ago, Construction Channel said: 2 pockets would be an extravagance! There will be two pockets, just the one on the right will be a bit shallower: Link to comment Share on other sites More sharing options...
Construction Channel Posted April 13, 2018 Share Posted April 13, 2018 you extravagant bugger, but only 2 you say......... it's on! Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 (edited) 8 hours ago, Construction Channel said: you extravagant bugger, but only 2 you say......... it's on! It's 3 actually, one over the wall hung wc. Slight faux pas there as I brought the wc boxing in a bit high for this tile layout! Just dawned on me actually that SWMBO possibly wants the pockets done in mosaics. So is that just the rear of the pocket or the sides too? I'll have to ask her but she does dither! Other than multi tooling out that bit where the lhs Cobra is sitting I might just go with a two tile high pocket rather than 3. Make that FOUR pockets as there's the bfo one alongside the bath! Edited April 14, 2018 by Onoff 1 Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 I need to cut this Aqua Panel into long strips, smallish rectangles etc. Scoring and breaking is a no no. Even outside I don't fancy using a grinding disc because of the dust. The ideal would be a circular saw with appropriate blade. In the absence of that thinking these jig saw blades @Nickfromwales put me on to. Used them so far only to cut out for the flush box. https://www.toolstation.com/shop/Power+Tool+Accessories/d80/Sabre+%26+Jigsaw+Blades/sd2581/Tungsten+Carbide+Grit+Jigsaw+Blades/p67688 Against a fence I guess and have at it! Link to comment Share on other sites More sharing options...
PeterW Posted April 14, 2018 Share Posted April 14, 2018 Cheap handsaw does it for me. Or a gumtree circ saw that is bought for the job and binned as the bearings will be munched by the end of it ..!! Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 (edited) 8 minutes ago, PeterW said: Cheap handsaw does it for me. Or a gumtree circ saw that is bought for the job and binned as the bearings will be munched by the end of it ..!! I've a "used once to try" circular bought from Makro for peanuts many moons ago, £9.99 rings a bell. It was so live and springy I just never touched it again. Maybe press that into service...though it was for a "one day" table saw project. Edited April 14, 2018 by Onoff Link to comment Share on other sites More sharing options...
Nickfromwales Posted April 14, 2018 Share Posted April 14, 2018 8 minutes ago, Onoff said: though it was for a "one day" table saw project. ? ???????????????????????????? Link to comment Share on other sites More sharing options...
ProDave Posted April 14, 2018 Share Posted April 14, 2018 21 hours ago, Onoff said: Got to decide whether to have the 3-way valve central to one tile or on the centre of two (not that it's going on the mitred bit): As the hose outlet is coming out centre of a tile it might pay I think to go with the second option and line up the centre control with the hose outlet. It'd put the centre control at about 1m from the floor which "feels" alright (along with thinking ahead ). You are missing the whole point of a separate valve. Put it there and when you turn it on your arm gets drenched in stone cold water before the hot reaches the shower. You want the controls on a different wall so you can turn it on, dry, and not get wet until it is warm water flowing Don't forget to drill a BIG hole for the thermostatic mixer, so big the plate only just covers it And for access to the filters I am going to have to cut between the big hole and the smaller holes with the multi tool 1 Link to comment Share on other sites More sharing options...
bassanclan Posted April 14, 2018 Share Posted April 14, 2018 Why is scoring a no no? If you repeatedly score the same line 10 times you effectively cut through it, but other than that an old handsaw is the way forward Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 1 hour ago, ProDave said: You are missing the whole point of a separate valve. Put it there and when you turn it on your arm gets drenched in stone cold water before the hot reaches the shower. You want the controls on a different wall so you can turn it on, dry, and not get wet until it is warm water flowing Don't forget to drill a BIG hole for the thermostatic mixer, so big the plate only just covers it And for access to the filters I am going to have to cut between the big hole and the smaller holes with the multi tool Read the first paragraph! It's going WAY over to the right near the window. Just showed it there as it's the only place I've a representation of tiles! Don't delete any photos - I'm shamelessly copying you! Link to comment Share on other sites More sharing options...
Ferdinand Posted April 14, 2018 Share Posted April 14, 2018 (edited) 22 hours ago, Construction Channel said: 2 pockets would be an extravagance! If people insist on bathrooms that look like the inside of an Elizabethan Dovecote, then there is price to be paid in blood and treasure... Edited April 14, 2018 by Ferdinand Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 2 minutes ago, Ferdinand said: If people insist on bathrooms that look like the inside of an Elizabethan Dovecote, then there is price to be paid in blood and treasure... I bet an Elizabethan Dovecote hasn't got a magazine loading loo roll holder! (Mind you, nor have I yet...) 1 Link to comment Share on other sites More sharing options...
Ferdinand Posted April 14, 2018 Share Posted April 14, 2018 (edited) 24 minutes ago, Onoff said: I bet an Elizabethan Dovecote hasn't got a magazine loading loo roll holder! (Mind you, nor have I yet...) (Lowered tone warning to delicate blossoms) Magazine loo roll dispensers - presumably something like the LRB - were not necessary in a pre-loo-roll era when no one wore knickers or underpants. In 1562 your bathroom would have been finished by now since it would comprise a duckpond and a wall. I just managed to lower the tone on @Onoff ! Woohoo. Edited April 14, 2018 by Ferdinand Link to comment Share on other sites More sharing options...
Construction Channel Posted April 14, 2018 Share Posted April 14, 2018 11 hours ago, Onoff said: Make that FOUR pockets as there's the bfo one alongside the bath! 4 you say...... easy Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 6 minutes ago, Construction Channel said: 4 you say...... easy Boring old rectangular ones mine are. Nick dissuaded me from doing them arched! Link to comment Share on other sites More sharing options...
newhome Posted April 14, 2018 Share Posted April 14, 2018 17 minutes ago, Ferdinand said: In 1562 your bathroom would have been finished by now since it would comprise a duckpond and a wall. If @Onoff doesn't have a loo in his bathroom maybe he's already using the duckpond? Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 7 minutes ago, newhome said: If @Onoff doesn't have a loo in his bathroom maybe he's already using the duckpond? I have another two loos I'll have you know! Both working as well! 1 Link to comment Share on other sites More sharing options...
Ferdinand Posted April 14, 2018 Share Posted April 14, 2018 5 minutes ago, newhome said: If @Onoff doesn't have a loo in his bathroom maybe he's already using the duckpond? Unfortunately I have been reading Shakespeare quotes on bathrooms: Quote I wasted time, and now doth time waste me. Link to comment Share on other sites More sharing options...
Construction Channel Posted April 14, 2018 Share Posted April 14, 2018 12 minutes ago, Onoff said: Boring old rectangular ones mine are. Nick dissuaded me from doing them arched! I hope he did, Arches are officially a waste of space Link to comment Share on other sites More sharing options...
newhome Posted April 14, 2018 Share Posted April 14, 2018 18 minutes ago, Onoff said: I have another two loos I'll have you know! Both working as well! Is that like Toulouse Lautrec? 1 Link to comment Share on other sites More sharing options...
ProDave Posted April 14, 2018 Share Posted April 14, 2018 1 hour ago, Onoff said: I bet an Elizabethan Dovecote hasn't got a magazine loading loo roll holder! (Mind you, nor have I yet...) For some reason I read that as a magazine dispenser by the loo. Link to comment Share on other sites More sharing options...
newhome Posted April 14, 2018 Share Posted April 14, 2018 6 minutes ago, ProDave said: For some reason I read that as a magazine dispenser by the loo. Here you go Link to comment Share on other sites More sharing options...
Ferdinand Posted April 14, 2018 Share Posted April 14, 2018 (edited) 30 minutes ago, newhome said: Here you go It’s like a 70s porno mag updated for the Waitrose Generation: picture features of Readers’ Homes. Edited April 14, 2018 by Ferdinand Link to comment Share on other sites More sharing options...
Onoff Posted April 14, 2018 Author Share Posted April 14, 2018 How soon you forget! Link to comment Share on other sites More sharing options...
