recoveringbuilder Posted October 3, 2020 Posted October 3, 2020 Sitting around doing nothing all day, horrible wet misty day and as the day has progressed I’m feeling a bit cold, quite often think that as it gets later the cold seems to come down into the lounge from the mezzanine which is above and has the cathedral ceiling, we do have the radiators up there on later in the evening which appears to solve the problem but we’re wondering if we ran the ufh downstairs and particularly in this room at a higher temperature if we would benefit from that, currently it’s set at 19 degrees as is the kitchen and small sitting room which are always warm but they have proper ceilings, what would you all have yours set at?
ProDave Posted October 3, 2020 Posted October 3, 2020 We only have UFH downstairs, and in the bathrooms upstairs. Thermostats currently set to 20 degrees, currently rooms sitting at 21, it has overshot a bit and all thermostats off. it's only about 8 degrees outside. But this is the sort of grey, miserable day, when regardless of what the thermometer says, you "feel" cold and when like this we tend to light the stove and get the whole house up to 24 degrees or so. That stops us "feeling" cold. 1
nod Posted October 3, 2020 Posted October 3, 2020 We have ours at 18 The default is 21 which is far to hot 1
Gone West Posted October 3, 2020 Posted October 3, 2020 Our thermostat is set at 23C. Anything below that is just unpleasant. 2
nod Posted October 3, 2020 Posted October 3, 2020 22 minutes ago, PeterStarck said: Our thermostat is set at 23C. Anything below that is just unpleasant. Wow! ?
newhome Posted October 3, 2020 Posted October 3, 2020 20 degrees downstairs and 18 degrees in the bedroom. I haven’t switched the heating on yet though so it’s a bit cooler than that but not that bad. 1
AliG Posted October 3, 2020 Posted October 3, 2020 We are set at between 20 and 22 depending on the room. My wife was complaining that the kitchen was cold even though it was 22 the other day and the heating was off. I think that at this time of year the issue is that it starts to get colder and darker outside, but it often isn't cold enough inside for the heating to kick in. Thus you don't get the radiant heat that helps you to feel warm irrespective of the air temperature. Once it gets colder and the heating kicks in more it feels warmer even at the same air temperature. 1
recoveringbuilder Posted October 3, 2020 Author Posted October 3, 2020 24 minutes ago, newhome said: 20 degrees downstairs and 18 degrees in the bedroom. I haven’t switched the heating on yet though so it’s a bit cooler than that but not that bad. Wow! Our heating has been on for 3 weeks although not upstairs, weather must be better in the borders!
AliG Posted October 3, 2020 Posted October 3, 2020 My heating wouldn't be on yet if it was set at 18-20C. I wouldn't be married either! 2
nod Posted October 3, 2020 Posted October 3, 2020 8 minutes ago, AliG said: My heating wouldn't be on yet if it was set at 18-20C. I wouldn't be married either! I think with us it’s our jobs I’ve always worked on sites in all weathers My wife works in a cold operating theatre wearing scrubs I think your work environment does effect what you are comfortable with
ProDave Posted October 3, 2020 Posted October 3, 2020 25 minutes ago, Christine Walker said: Wow! Our heating has been on for 3 weeks although not upstairs, weather must be better in the borders! Been on for 1 week here. Today topped out at 8 degrees outside but more like an average of 7. And 0 sun so no solar gain. You would be doing very well indeed to not need any heating with that outside temperature. I would say it is colder than normal, in previous years I have not turned it on until November. Perhaps I just lit the stove instead.
Cpd Posted October 3, 2020 Posted October 3, 2020 12 minutes ago, nod said: I think your work environment does effect what you are comfortable with Totally agree, i am outside from 7.30am to 5,30pm and then often pottering in the garden / walking in the evening. I set my electric heating to 16c and am happy at that as I can’t sleep comfortably with it much hotter, If the weather is great then I don’t mind it hotter as long as the windows are all open. I’m sure I could get used to it hotter but need to constantly watch my electric usage......
nod Posted October 3, 2020 Posted October 3, 2020 I’ve stated before that we have never had the heating on in the bedrooms or bathrooms I used insulated boards on all the exterior Block walls Perhaps a bit of overkill But for a small amount of money that it cost Keeps the whole house warm
epsilonGreedy Posted October 3, 2020 Posted October 3, 2020 33 minutes ago, nod said: I’ve stated before that we have never had the heating on in the bedrooms or bathrooms I used insulated boards on all the exterior Block walls Perhaps a bit of overkill But for a small amount of money that it cost Keeps the whole house warm Are these boards PIR backed plasterboard? i ask because in another BuildHub thread someone said they are a pain to fit.
AliG Posted October 3, 2020 Posted October 3, 2020 The entire outside of our house has these, they are dot and dab on the block walls and screwed in timber areas. No issues at all.
nod Posted October 3, 2020 Posted October 3, 2020 10 minutes ago, epsilonGreedy said: Are these boards PIR backed plasterboard? i ask because in another BuildHub thread someone said they are a pain to fit. Yep They have pink backed insulation 40 mill in total Just D&D like normal Great to dab with You can usually use around 7 per hour One man So only about 3 behind using wallboards
PeterW Posted October 3, 2020 Posted October 3, 2020 23 minutes ago, epsilonGreedy said: Are these boards PIR backed plasterboard? i ask because in another BuildHub thread someone said they are a pain to fit. They are for mere mortals, but @nod is a plasterer with god like standards ... so it’s his bread and butter !
SteamyTea Posted October 3, 2020 Posted October 3, 2020 How good is the correlation between thermostat settings and actual room temperatures? At my mother's at the moment and it is sweltering. 1
joe90 Posted October 3, 2020 Posted October 3, 2020 (edited) My wife complained this evening about it being cold (I am sat in a t shirt), heating is set to 20’ and not come on yet (I think it may be altered soon ?). edit to add,,,, she has just asked me to light the woodburner ?♂️ Edited October 3, 2020 by joe90
nod Posted October 3, 2020 Posted October 3, 2020 Ours is very warm also Still no heating on this year
Ferdinand Posted October 3, 2020 Posted October 3, 2020 (edited) We had a cold snap with autumn arriving about 10-12 days ago - where the high temperatures were below about 10C for 3 or 4 days in a row. Mine went on then, and it took a few days to warm it all up. It is now running at 18-20C. Display on downstairs heating controller seems to have half died, so I am playing jigsaw-deducation games with the segments in the LCD until fixed. Upstairs is off apart from the rad in the downstairs bathroom which is connected to that half of the system - presumably as it is rads upstairs and ufh downstairs, as I am still 95% downstairs including sleeping. F Edited October 3, 2020 by Ferdinand
Thedreamer Posted October 3, 2020 Posted October 3, 2020 Still to use any heating. Put on the stove a few times in the evening, working well, heating the house into the morning. No sun today, but the house has been 19.5C. Ideally I like it when we are 20C
recoveringbuilder Posted October 3, 2020 Author Posted October 3, 2020 I think not having a stove or some other form of quick heat has been a mistake, in our last house we had a wall hung gas fire in the kitchen/ sunroom 54m2 and that wee fire could raise the temperature a good 2 degrees and because we more or less lived in that space we didn’t put the ufh on until usually end of October beginning of November.
ProDave Posted October 3, 2020 Posted October 3, 2020 We were away for a couple of weeks only returned at the beginning of this week. the weather turned cold while we were gone and averaged around 10 degrees. So when we got back the house was cold, so we put the UFH on and lit the stove. that warmed things up quickly. Now the house is back up to temperature the heating is not coming on much. I think what this shows is how much the house keeps warm due to incidental heat of us just living in it, but of course with 2 weeks with no people, no cooking etc allowed it to cool down.
newhome Posted October 4, 2020 Posted October 4, 2020 19 hours ago, Christine Walker said: Wow! Our heating has been on for 3 weeks although not upstairs, weather must be better in the borders! Not really. It’s 17 degrees in here today but the electric is going off on Tuesday all day for emergency repairs up the road or something. I wasn’t going to put on the UFH for the heating to then be off for ages and have the temperature drop down again. They are supposed to be lending me a generator but god knows how that will work out. I need to power the router and the laptop so that I can work from home. If it can also power a 3kw heater I may put that on. 1
