I’ve just started getting prices for plastering and they vary A lot.
What sort of price per square metre have you been quoted?
Most have quoted a day rate, rather a total price for the whole job, it this normal?
1 hour ago, dpmiller said:
on his own or does he bring someone/ use you as labourer?
Plasterer and labourer.
He’s quoted plasterer at £26/ hour and £15 for the labourer.
Quote
... on his own or..
On his own.
I was Tea-Boy-Extraordinary. I unlocked the HERAS gates every day. Ooooh, and one famous time I remember, I turned the hose on for him - just the once I think.
@Triassic, he is local to you...... Want his number?
May be I’m focusing on the wrong aspect. How much (m2) should a good plasterer be doing in a day?
Has anyone plastered their own home? How difficult can it be?
4day plastering training course for two people £500!
Edited by Triassic
11 minutes ago, Dreadnaught said:
Have you considered spray plastering? I have been offered £220 a day for spray plastering in Cambridgeshire.
Hmm.. bit of a gimmick tbh as it just gets the plaster on the wall quicker, they still need to know how to flat it and work it up.
Yes I’ve skimmed a few walls in my time, but can’t do ceilings and for what I pay a day (£160) I don’t even bother. You can get the training in a few days, the experience takes years. Add on decent tools and you’re upward of £8-900 and then you start to ask the question how much can you do in a week vs a skilled plasterer ..?
So £200/day for a spreads is not bad, £120 for Labourer is a bit steep - depending on what they are doing I would be looking at £80-100 tops.
Most have quoted a day rate, rather a total price for the whole job, it this normal? We
A reasonable plasterer would cover 30 boards per day 80m2
7am to 230pm Three mixes
A quick one will do 100
3.25 m2
The baring rates are just behind the skimmers and a day per house quicker
 Forget plastering courses
I’ve taken lads on that have done 12 months corses Not always neat enough for sight work and far to slow
You need to be careful that your not paying day rate for someone doing 40 M2 per day
You don’t need to pay out for a labour
We just pre fill all the joints and beads then tip four or five bags into a tub three times a day
30 minutes of mix 15 washing out
Stood watching for the rest of the time
I do have a gang that load PB £1 gf
1.5 1st floor They often out earn them plasterers
Peters spot on with spraying
You still need to finish the plaster
But also not worth the masking up on something like a house
  • Thanks 2
Most day rate plasterers round here do 2 sets a day. Usual knocking off by 3 latest. Not to say they don't graft though
Also don't cut this trade to the bone if they quote you fair rate then pay it. Nothing worse than crap walls after its plastered because the guy is unhappy and/or having to get loads on to make it pay.
A 4 day plastering course for £500 for two people.....will just about give you the confidence to mix the plaster properly.
Absolute total waste of £500.
Same as driving lessons, some need less, some need more, and sometimes you still don’t get how they were given a license at the end ‘COS THEY STILL CANT BLOODY WELL DRIVE!!
I’ve had spreads in and on the first set I’ve told them not to come back tomorrow. If it’s not like a sheet of glass, you’re out on your ass. Don’t put up with a crap spread, bin them immediately and go onto the next one.
  • Haha 2
We saved a big chunk of cash by fitting our own boards to the stud walls and ceilings (we left them to dot and dab)
I don't like it when the surface is too polished.  It doesn't take paint well.
Flat, not shiny.
I’d have said mirror otherwise ?
Big walls will always have some kind of undulation, but for every 2.5m run @ 2.4m high you should be expecting a very good finish over the given area.
Beware the spreads that don’t lay opposites on and let them go hard before then laying adjoining, eg spreads who put a whole room on ‘wet on wet, and then there is very little they can do to get all the internal angles and lines crisp and straight. Yes, they do make internal corner trowels, I own one, but not many people can use one without doing more harm than good.
3 sets a day is good going, just depends how old your spread is ?
On 22/08/2020 at 18:25, Nickfromwales said:
Flat, not shiny.
Could not agree more, opposite walls and never wet corners.
  • 7 months later...
gonna bring this back from the dead. Just got some guys that have done some for me previously to price a bigger amount of work- looks like about £10/m2 inc scrim and beads, I'm supplying the skim. Reasonable?
Hi dpmiller
I'm doing a DIY extension in between the day job. Have done a bit of plastering years ago but I have lots of corners and want to get some detail.
I want to have a play with some shaddow gaps. Also, I have a nice set of Aluminium windows and doors, don't want them scratched so want to do it myself, although it will take me longer. I have got some 2.0mm stop beads for the window ingoes. I think I'll set them back about 3.0 - 4.0mm from the window frame then mastic to try an avoid that hard to paint / wall paper bit between the window frame and the plaster / ames taping that tends to shrink away over time. I'm not sure how this will all pan out but I want to experiment.
Once you get into this type of work then you can't really go on a sq metre price.
I'm aiming to start the plastering next week so will try and post some photos etc. and a time / material log on a DIY basis for comparison.
Has anyone tried am OX Speedskim? I've only done a small amount of rough plastering in the past, but have ordered one to try
Yeh - it went in the skip
lol what did you find so bad about it? Reading reviews, it seemed there's the learning curve with it, so seeing as I can't plaster great with a trowel, there's a learning curve for me anyway :D
1 hour ago, Oz07 said:
Re speed skim. Plasterers I know love it for flattening off. @nod?
Exactly what I read
Flatting off is only one part though. Then set the surface and polish it up - that’s the bit that takes skill.
