Hi - Help for studies
SimDav
Good afternoon all, I'm Simon.
I'm currently studying an HNC in Construction and am after some help and information from the wise people on the forum.
I posed a difficult question to myself for my current project. I asked if ICF house construction could replace traditional methods and help solve a housing shortage issue in the UK whilst addressing some sustainability issues.
I realise this is a really complex task and has many variables. My first plan is to compare the costs associated with both methods to build a set size house and the time it takes to get each to a completed shell state. (Unfinished exterior)
The building size is a 3 bed, 2 storey, 150m2 useable space, detached property with 15% openings. The foundations are complete and the costing's are just for a building shell, unfinished exterior, without a roof. I have a few good comparisons of cost from some of the ICF manufacturers (Durisol, Polysteel Warmwall) who have sent me quotes and comparisons of what their costs and timings would be. Some of them have given a comparison of theirs vs. traditional methods but I am trying to get as many other opinions/quotes as possible so I can average them out and give a fair representation of how much and how long this will take.
Can anyone offer any advice, help of how best to achieve a good comparison? Are there any builders using traditional block/brick cavity walls out there that could give me rough quote?
Thanks for reading and your time
Simon
I don't see how choosing a different construction method could solve a housing shortage?
Any housing shortage is the result of planning policy, and / or the way large house builders land bank land and only develop it when they believe they will be able to sell the houses quickly.  It has little to do with the time it takes to build a house.
  • Like 3
Welcome, @SimDav.
Sustainability really means getting away from energy and CO2 intensive construction materials, IMHO.  I'm not sure how ICF really meets that requirement, as many forms of ICF use plastic insulation, plus ICF uses fairly large amounts of concrete, which is very energy and CO2 intensive, both in manufacture and transport.
Probably the best approach to sustainable housing, and one that meets the requirement to build houses quickly, would be timber frame construction.  The ability to manufacture closed panel timber cassettes, in a controlled indoor environment, and quickly erect them on site meets the need to build houses rapidly.  The relatively low CO2 involved in felling and processing timber, plus the carbon that remains sequestered in the timber itself, makes this about as low a carbon construction method as there is.  This sort of construction method also fits well with the use of low CO2 insulation materials, like wood fibre or blown cellulose, so reducing the carbon footprint still further.
Coupled with a foundation system that uses only modest amounts of CO2 intensive material, it's perfectly possible to get a house that goes from bare ground to watertight, insulated and airtight shell inside two or three weeks, something that is a useful attribute given the variability of the weather here in the UK.
It could. But it won't.
The building sector has no incentive at all to make substantial change. The training infrastructure isnt there, the political will isn't there, developers have a strangle-hold on the supply chain.
I am building an ICF house. Locally the level of disbelief in anyone building something other than entirely traditional house is substantial.
Agree with dave, building mass housing is not hard, you can choose any method and get a house up in about 14-16 weeks and habitable, it’s getting the councils to release the land and removing the profits from the developers that put a stop on things.
Why are councils not making available serviced plots, ready to go with a small mark up on them.
A comparison between traditional and Timber Frame isn’t always easy The TF is always more expensive
As I Plastering contractor just before we started our build I was asked by an old friend to quote for his self build in the Lake District
There were three others on the site
I was asked to quote for the others also
One was identical style to his But TF
I was quite surprised that  he was up to £64000 watertight no first fix plumbing or electric While the TF was at £108000 But started three months after his
I would guess that  the costs from that stage on would be identical
I guess it depends on the TF manufacturer, and the time it takes to erect, but for us TF was a LOT cheaper than traditional construction.  The initial quotes we had for traditional construction were over 50% higher than for TF, and also had no airtightness guarantee, and slightly worse insulation levels.
Simon
I family company that I have done a lot  of work for over the last twenty years build several hundred student accommodation in various locations All in TF
The Timescale for completion would be impossible in traditional
Back in 2008 just as the recession hit They started a site by Preston docklands All TF With running costs a fraction of local sites which had all but ceased du to the recession kicking in
They houses sold like hot cakes and kept us flat out til 2009
These houses were heavily subsidised by central government
When we left the site there  was about a dozen unsold
This company has four housing site at the moment
All traditional
The government has to make it cost effective for companies to change
up here tf has been the traditional method for years, i cannot see how b&b can be faster and cheaper than timber. the weather is less of a hinderance and the house wind and water tight faster, the insulation is in the inner leaf as opposed to on its face so more floor space and easier fixings for the householder in the future.
25 minutes ago, Ferdinand said:
It's really nice to see someone working on an HNC not a degree !
if he's in the trade and doing it in his own time he may yet go on to uni and go into management.
housing shortage is also due to firms building detached houses with a few semi-det. what is required are more terraces/four in a block, however, these won't sell well nor will they sell for a premium. the article recently about people having to live in shipping containers and how bad it is, contrast this with the grand design in NI where an architect was happy to use this method to build with and live in. if you wish to cut build costs and cut housing waiting lists, we need more container living, it does need to be insulated properly and well designed though.
I....
All traditional
By what mechanism were they subsidised?
They do in some areas, albeit in a small way.  The one's I have seen have formed part of a wider development site that includes social housing, something that does put some buyers off / may limit the market.
It’s great to somebody with background and hinterland working through the structure, to get real valuable experience rather than just dry academic qualifications!
The heating system was a big thing either air-con type unit in the back garden Water harvesting That sort of thing They were  able to keep the price down with a promise of a couple of hundred quid per year energy bills
I know the criteria was quite strict
We did a large village pub conversion for the same company
He spent 70 k on a bio boiler
with a 6k per year subsidy over ten years
He’s quite clued up
We’re we have built The house across the road has been knocked down and 150 built in its place Though most are detached
I worked this house for a year when I left school
But it will take a massive change in attitudes from the mortgage companies as paddy Bradley explained on the show. They won't touch that type of build.
+1 to this one. VERY MUCH a planning /land issue
I wrote, rather sarcastically, about the difference between cars and houses a while back.
I will come clean, it was not my idea, but one from @Ed Davies a few years back.
But here is the link anyway.
Building Cars and Houses
I do think that we have to seriously reform planning and all the professional fees we pay to build.  An old work mate was building two identical houses, so had to pay the timber frame company two lots of fees for architectural and structural work, just imagine if you had to pay the full development costs of a tire for each corner of your car.
Simon
You could do worse that get hold of a copy of SPONS for some basic comparisons.
Edited by Ferdinand
9 hours ago, Sensus said:
This is at least partly down to the current Planning system with regard to affordable housing: if you're being forced to build every third house at no profit, you make damned sure that the other two are as big, expensive and profitable as you can, to cover your costs.
is that correct? I thought that numbers for compulsory affordable housing had a profit element built in.
And that the mix required is actually set by the  Local Plan d/ housing needs sssessment.
Ferdinand
Take a look back at the wartime prefabs (pre fabricated houses). They came in kit form, were all identical, and people loved them! There are some, I believe, still around. It is communities that make people happy :)
On the planning side of things there are sites around here that have been held up for years while developers and planners wrangle over "section 106" agreements. Planners say they want x number of affordables, a green space, a contribution to the village hall etc. The developers just say the site is not viable and it goes on and on. As our Local Authority has not met its housing targets they are having to back down and allow developers to get away with building with no planning gain. The community loses out as we are being saddled with soulless estates of identikit houses with no green space or other amenities.
