Everything posted by ProDave
I'm going to make a shed out of pallets.....
ProDave replied to ProDave's topic in General Self Build & DIY Discussion
Yes it is very solid. the pallet planks that make up the cladding are about 3/4" thick. The frame is quite sturdy and has diagonal bracing on all sides so it won't start leaning when the wind blows. It's staked down to the ground so it won't blow away. It's all been painted with the modern version of creosote. the lighter brown on the rear was the first to be done and the front, looking darker was the most recent. I suspect it will all lighten up fairly quickly. I like creosote for stuff like this, so easy to apply (and re apply) and effective at repelling water and preventing rot. I forgot to say, the roof timbers are 6 X2 and 4 X 2 timbers that have previously been used as shuttering for a concrete slab, so again, re using previously used timber. -
I was in town today and called in at the big orange shed. Out of curiosity I had a look at the sheds they had on display. To get a shed the same size as my pallet shed, would have cost £400 all bar a few pence. I wasn't expecting it to be wonderful, but it was far worse than I had expected. The cladding timber was probably little over 1/4" thick. The frame appeared to be little bigger than 1" square sections. There was no diagonal bracing relying on just the nails in the flimsy planks to give it rigidity. If you leaned on one corner of it, you could flex the structure and make it wobble. If I bought one of those and put it up in my garden, I would be amazed if it lasted one Highland winter without collapsing in a pile.
It's just about finished. I went into town today and bought the roofing sheets, a cost of about £100 so that's the total spend on this shed. -
The 12KW will give you a better shower than any electric shower will.
Stage 1 Is Very Nearly Complete :)
ProDave replied to Construction Channel's topic in General Self Build & DIY Discussion
Great video Ed. But that drone footage. Are there NO hills where you live? that really re defines a flat landscape where you are. -
Heating Oil up 24% in 17 days
ProDave replied to Temp's topic in General Self Build & DIY Discussion
I filled mine in August (it's large enough to last a whole year) Traditionally that has always been the cheapest time to fill it, I usually use Boiler Juice to look at the price and decide just when to order a fill. I hope this is the last time I will fill it (hoping it will have sold before the tank is empty) but I said that when I filled it last year....... -
Reduced Energy Bills Achieved
ProDave replied to Ferdinand's topic in General Self Build & DIY Discussion
What I want to know though is the cost per unit of electricity and gas from each supplier? THAT is what is important. Could it be you have just been over paying and built up a large credit with them so they are reducing the monthly amount to slowly pay down that credit (i.e no REAL saving?) I plot the weekly electricity and solar PV meter readings so I know how many units I use and generate each week, and there is a definite correlation, good week of high solar PV = reduction in usage reading for that week.- 8 replies
- energy bills
- energy efficiency
- (and 4 more)
How to value overgrown, unused, "garden" land.
ProDave replied to K78's topic in Landscaping, Decking & Patios
I take it from the pictures that your plot is the last picture that has had extensive ground work and the bit you would like to buy is the overgrown similar strip to the left in the last picture? The fly tipping can be dealt with by a decent fence along the top of the stone wall, and I can see with relatively little work it could provide an interesting shaded bit of garden just be thinning the lower branches of the trees and creating a path through, perhaps to a shed / summerhouse at the end? My guess is, that seeing your house being built by digging into the steep bank, the neighbours may view their bank as another potential building plot. -
Setting up our new build for PV in the future
ProDave replied to JanetE's topic in Photovoltaics (PV)
The voltage drop issue is nothing to do with fooling the metering. It's that inverters are set to trip or limit output at 253 volts. With many UK supplies being 245V there is not much headroom for volt drop (which perversely is voltage "rise" in this case) before the inverter trips. So although a 2.5mm cable will handle the load, it is wise to fit a much larger cable to minimise the risk of voltage issues. -
You can buy coffee tables made out of pallets. When I suggested that for the left overs............ NO -
Vent Axia Sentinal Kinetic Plus
ProDave replied to a topic in Mechanical Ventilation with Heat Recovery (MVHR)
I see a bottle of beer is now the standard forum yard stick to show somethings size. -
Making progress. All it wants now is a roof (I am going to have to spend some money) then I can put the OSB floor panels down. The windows are some secondary double glazing units I have had for ages, just a single pane of glass set into a plastic frame. We used to use them as cloches for growing vegetables. SWMBO came to have a look at this creation, and she has named it the "Steptoe Shed" -
The inverter might as well go in the services room in the loft. Provision for a conduit to take the dc cables from the inverter onto the roof. Include a dedicated cable from the inverter to the consumer unit, 2.5mm is okay as long as it's not a very long run but no harm in putting a 4mm or even 6mm twin and earth in for it. When you chose your consumer unit, get a "high integrity" one. This usually has two banks of mcb's each covered by an rcd and a couple of ways not covered by an rcd. Feed the inverter into one of the non rcd protected circuits via an rcbo. What you do NOT want is the inverter feeding into an ordinary mcb fed as one of a bank from an rcd. -
It would be very hard to get to to fit something to this one, it's more about knowing what to fit in the new house to make all things water work quietly.
I don't think there is one in the cistern? If there is point to it. Part opening the ballofix valve just makes the noise from a different place.
That's been my findings with bought sheds. As well as being flimsy, they never incorporate any diagonal bracing whatsoever into the frame. We do have 2 shop bought sheds but both have had the frame upgraded. See my Pallet shed thread, that has a far more substantial frame and thicker cladding than a bought shed. It might not look pretty but it is far more robust. My other pet hate is a felted roof. Absolutely the last thing I would put on a shed roof. If you don't like Stone's container idea, how about a static caravan? Our local dealer will sell you a "worn out" one for £500 that's suitable as a shed or storage or workshop and you can sell it on when you are done.
NOT my experience. I didn't know such things and the concealed cistern in the next door en-suite is screwed to the studwork of the wall. the flushing noise is not to bad but it's the 10 seconds of "WOOOOSH" as the cistern fills up that is the irritating noise. We have very high water pressure and no flow restrictors. Is there anything EASY I can retro fit to make this silent?
Actually there IS already a solution to kettle energy usage and we have one. It's called an ECO kettle. It has two water chambers, a reservoir and a boiling chamber. So you fill it whenever it is empty from a tap in the normal way. Then when you want to make a cup of tea, you press a plunger to allow water to flow from the reservoir chamber into the boiling chamber, you let in just as much as you want to boil, then turn it on. It boils quicker and just boils what you need. Of course you can do that with an ordinary kettle (just put in as much as you need) but people are to lazy and it means a trip to the tap every time you want to make a cuppa. https://www.amazon.co.uk/Eco-Cordless-Kettle-White-3000W/dp/B000XJ1OAS
But by then we all all be using kettles with a 100W element because that "saves energy" Even more cynical me.
I might add some extra planks to make it hit and miss. But probably only on the south and west more exposed walls, and when I have dismantled some more pallets. -
And what happens to the water heated by the quench coil? does it just go down the drain? How would that work with a ST or treatment plant? What if there's a water cut (rare but possible) so shouldn't it come from a tank?
Health risks associated with passive houses
ProDave replied to K78's topic in Energy Efficient & Sustainable Design Concepts
Internal Vs External temperature. -10 outside for a couple of weeks is not uncommon up here, but then I accept out climate is a bit harsher than other parts of the UK. And empty houses. I guess it depends on why they are empty. The one that bugs me is an empty house that's empty because it is for sale, gets "penalised" with double council tax after 2 years, to "punish" you for the housing market being slow and you being unable to find a buyer. I know a familly in that situation and they say in December when the "penalty" kicks in they are going to take their house to auction to dry and shift it. -
Yes I have no doubt some rain will get in. But it's only a garden store, not a workshop so not after air tightness and insulation. I have a wood shed with deliberate big gaps left to ventilate it well to dry the wood and it's surprising how little rain comes in through that. -
It's got 3 sides and the start of the roof frame now. That's the last of the pallet planks, different wood for the front. -
Re the "houses are too expensive, tell the agent to lower the price" thing. Houses are NOT too expensive everywhere, in fact I would argue they are too cheap up here. i am building a bew 3 bedroom detached house, and by the time it is finished including the cost of land, it will have cost about £250K My present 5 bedroom house is on the market for £285K (having been valued at £300K) So it looks pretty damned good value for money. Some people tell me the old one has not sold yet so it "must be over priced" and I need to drop the price. but I can't drop it much or it will be on par with the cost of the new one. Downsizing was supposed to release a bit of the equity in the property. It will be a bitter bitter pill to swallow if I eventually only sell the old 5 bed house for the same as it costs to build the new one (downsizing without being able to release any equity) and I can tell you it will NOT under any circumstances happen that we sell the old one for LESS than the cost of the new one. So what is that ramble all about? well the dominant cost of building the new one is building material and labour. It is only going to be as cheap as it is because I am doing so much myself. In the present market, if you paid a builder to build your house and did not save money by doing some yourself, you would have a house that cost more to build than it's market value. so I can only drop the price of the old one if building materials and labour to finish the new one plummet in price as well. I can't see that happening?
