ProDave
    427
Everything posted by ProDave
  1. Post a picture of the other nut. It will be possible to buy another one (probably sold as a pair)
  2. Yes LPG gas. Turn off at the bottles. Back to the subject of isolator switches for kitchen stuff. I put mine in the back of the cupboard above the ovens. I can inform our learned readers, it is an absolute mare terminating cooker sized cables in a switch box at the back of a cupboard when you are working on a step ladder reaching into the back of a cupboard so working at arms length. I do question is it really necessary, particularly for an oven. If there was a fault is is probably quicker to go the consumer unit and turn off the clearly labelled Oven rcbo than pull the stuff out of the cupboard to get to the switch.
  3. Water and gas off when we go away. Leccy stays on for the fridge, and for the PVR to record stuff while away.
  4. Make the plywood a very snug fit and glue the edges to the walls of the cabinet frame as well.
  5. Good call. My neighbour had a huge tree right next to his bungalow, it would have flattened the bungalow if it had fallen onto it, and if you were in the bedroom next to it, it might be your last nights sleep. But also across the road was the 11KV overhead line. SSEN removed it for free when he pointed out if it fell down it would break their overhead line.
  6. I would cut a sheet of 10mm ply to be a snug fit in the recess behind the cabinet, fixed there with your favourite gap filling adhesive. Fix the cabinet with the official fixings into plasterboard fixings, then two screws through into the studs one top one bottom, going through the flimsy back and your 10mm ply
  7. If the flimsy back it recessed a bit as is often the case, fix a more substantial backing board behind it.
  8. Just an example of my inventive DIY tree felling. These 2 trees, the right hand one had failed at the roots and was leaning over onto it's neighbour. All the tree men that looked seemed to suck air through their teeth, but all agreed both need to come down. I suspect none really knew how to do it. To fell them in one go, it was likely the tops would reach the house or static caravan. I suspect nobody wanted to climb a compromised tree to take the tops off. My inventive solution was put up a scaffold tower next to the trees and working from that with my extended pole saw I cut the tops off. That now just leaves the two mostly bare trunks to fell. Now short enough that they won't reach anything they can harm. Again not advice, just how I did it myself. I would really really love a mini spider cherry picker for this sort of work, but silly money for something I would use once in a blue moon, so the scaffold has to do, even though it is a lot of work to put up for a 15 minute job then take down.
  9. Find the location of the studs. Unless it is a very small cabinet, it is very likely at least one stud will be behind the cabinet. So I would fix the cabinet with plasterboard fixings, AND one or 2 screws directly through the cabinet (additional holes drilled for this) straight into a stud. I have done this for kitchen cabinets and they have not fallen down yet.
  10. Must check to see if Artemis is really going to launch today or is that a victim of the date?
  11. Best of luck finding a tree man. I had 4 look at mine, all gave a price and then did not answer their phone again or one kept giving a date to come and do the work and cancelled. I am doing mine myself now. With an 8" single handed electric chainsaw with extending pole to strip the upper branches off, then felling the now mostly bare trunk. It's easy if you have somewhere for them to drop, you can fell them whole. The tricky ones were the ones without room and had to be dropped in sections. Only do this yourself if you are comfortable, or as I was, desperate. Best of luck finding a tree man. As I gave a WBS none of it goes to the chipper. Everything larger than a finger diameter gets used for burning or the thin stuff for kindling, only the really small stuff got burned on a bonfire.
  12. I am sure the plan is frame to both side walls, AND further timbers spanning between these at no more than 600mm centres or better still 400mm centres.
  13. With controls remote from the shower, I would (I did) put the controls on the left hand wall, so you can reach in and turn the shower on without the cold water in the pipes spraying on you.
  14. Riser rail for me, that is more obvious if not centred.
  15. So you also need to box in the bit up the stairwell where the pipes go up, but only that bit otherwise you will narrow the stairwell. Up to where the newel post would be my suggestion.
  16. From that link the best bit is Implications for the customer If the DNO or MOP need to attend a domestic or similar premises and encounter equipment other than that used for supply or metering purposes within an approved meter enclosure, this may prevent work activities such as: ● the replacement of lifetime-expired equipment; Great way therefore if you don't want a smart meter, to make sure there is no free space to fit one.
  17. Another +1 for Click Mode. Good quality, well built, versatile, reliable and cheap. What is not to like.
  18. As it's only supporting plasterboard I would construct a false ceiling using 38mm by 89mm CLS timber supported just from the walls with a similar sized CLS fixed to both walls. That then gives you plenty of room to accommodate the wiring for the lighting changes. You could probably do it in a thinner size using metal framing, but someone else would have to advise on that, I have not used it.
  19. I was going to ask that. A meter box is a cabinet that needs a key to open it. That does indeed seem to meet the description of an electrical enclosure. After all you can have single insulated cables and even bare terminals in a junction box with a clip on lid. I agree it is poor work and it's not as thought it would have been difficult to do it properly in the first place. But a waste of time trying to complain to the competent person schemes, history seems to show they will be quick to fine someone who uses their logo if not a member, but taking action against a member who does poor work seems incredibly rare.
  20. That's more for an 850W system than it cost me for my original 3.68kW system. No wonder there is interest in selling this plug and play kit, it allows suppliers to charge a lot for a small system just for the users that think they are getting something special.
  21. We were first told that 40 years ago.
  22. Didn't spot those. Definitely lots of shoddy work.
  23. But it is also oh so simple to put right, I would not even trouble the developer. Turn off the power to the boiler, unscrew the outer cap, push the cable further in so the sheath is completely inside and put the cover back on and tighten it. Check there is a rubber bush in there somewhere, that is what compresses to clamp it in place.
  24. Rip it off and plasterboard. If you have ANY electrical alterations to do, your electrician will hate you for keeping the lath and plaster. Just my preference.
  25. I have seen a video of a submerged EV still burning underwater. So that won't extinguish the blaze buy might keep it cool enough to limit the spread until it has burned all it's fuel.
