Everything posted by ProDave
Posi joist - This install feels rubbish, thoughts?
ProDave replied to boxrick's topic in Roofing, Tiling & Slating
Post whatever drawings of the roof that you have, that they should be working from. -
Yes but I still have some unresolved issues with the render so I cannot recommend it at the moment and certainly not if you intend using Baumit render.
Done 2 self builds and not a single objection to either.
Can't connect the SWA cable. Practical help please.
ProDave replied to saveasteading's topic in Power Circuits
MCB or RCD tripping. If RCD you need some test gear like an insulation tester. -
Run joists end to end of the house, supported on sleeper walls aligning with each of the internal walls. Repeat for upstairs (so internal walls made structural) with stair hole. Your widest span will be the kitchen / diner, the joist supplier will size them for that span. I am surprised at the posi joist sizes you quoted. My longest span id 5M and my joists are 300mm deep. The narrow joists you quote won't leave much room for 110mm waste pipes for instance.
Thoughts on proposed layout for self-build
ProDave replied to Ben Brewin's topic in New House & Self Build Design
Looking again at your plans, is there any scope for getting access to your plot from Priory Lane? If you could then the SW bit of your garden currently where you drive to get into the plot, could be a nice bit of an evening sun trap garden. Is the "existing outbuilding" in the top left by any chance a single garage? If so it will have vehicle access rights to Priory lane. That certainly looks like a driveway entrance in front of it. -
Most of our external doors are inward opening, except the one to the balcony which opens out. I can't recall the logic of why we chose that. As others have said, outward opening needs care in wind but we are unlikely to use the balcony when it is windy. But outward is way better in terms of keeping the weather out. Our balcony door is very exposed and not a drop of wind driven rain has got in. The other "normal" back door downstairs opens in and is exposed to wind driven rain from the west. It does not leak when shut, the seals do a pretty good job of keeping the rain out. But it is inevitable with the geometry of an outward opening door that it relies 100% on the seals to keep wind driven rain out. The weakness is the small amount of wind driven rain that gets past the drip bead and then sits between the door and the frame, held back by the seal, and when you open the door that small amount comes in.
Economics of DIY and Self Building
ProDave replied to Gus Potter's topic in General Self Build & DIY Discussion
My even more tight economical solution was install lots of cat5 cables but only terminate the ones actually in use, which is about 4 at the moment. The rest are there for future use and in the rooms are coiled up in the service void behind or next to socket boxes, and at the cabinet end, coiled up and labelled where they go ready to be terminated when required. -
The main thing here is you have cooperation from the neighbour who is allowing a footing straddling the boundary and a second wall on his side. i.e. it has every potential to be a proper job done well to last into the future. It is when a neighbour refuses to take part or take an interest that you are forced to do the best from your side which might well be a poor solution. If only all neighbours would share a problem like this then the solutions would be a lot better.
Doing a self build, it is hard to predict the financial position, until it's all done ant the dust has settled. And often, timing is everything. Those that followed our build will recall the original plan had been sell our rental properties which would give us a start, then sell the old house to finance completing the new one. But the timing was wrong. When we put the old house on the market the housing market here was moribund, still not recovered from the financial crash. It sat on the market for 3 years with little interest along with many similar properties around here. It became clear the only way to sell it would have been sell for give away / distress prices, which would almost certainly mean the old house sold for less than the cost of building the new one. There was no way I was going to "pay" to downsize, which is what we were doing. The saviour was an offer to rent it from someone ultimately wanting to buy it. We agreed. The rent income funded a slow build as you earn, and we completed the new one before the old one ultimately sold, which was an unexpected result. The honest advice is don't start a self build until the finance is 100% secure, and it is not so if it relies on a property sale. And if you don't do that, then you must be flexible. -
Then use that for the Tony Tray.
It is hard to tell from the physical size. We are served from a 100KVA transformer. A few years ago it failed. They replaced it with another one half the size. I asked the guys why are they fitting a smaller one and they said it is the same rating.
Trade account - electrics and plumbing
ProDave replied to Lincolnshire Ian's topic in General Self Build & DIY Discussion
Honestly, I just used Screwfix or toolstation for their honest visible pricing. I gave up with electrical wholesalers for their random pricing and often lack of stock. -
post a photo of the transformer from the other side so we can see the connections to it.
Use the same as your air tight layer. Have you chosen that yet? I used Protect Bairiair as being the cheapest of the tough reinforced ones that I could find.
This post just reinforces my view that a self build only makes financial sense if you do a lot of the work yourself. I am sure if I had paid trades to do everything I would have spent much more building the house than it's market value when completed. -
Our previous house had 1.5m walls at the bed head and that was okay, less than that and it would feel oppressive I think. I think and extra half metre of ridge height would make a massive difference. Speak to the planners. You would then just bring the main outer walls above floor height as shown in @Kelvin section plan above. Must then be built with a ridge beam to prevent outward force on those little walls at the bottom of the roof. -
The three horizontal wires on the pole with the transformer are 3 phase 11KV That transformer on the pole is probably about 50KVA That will feed perhaps 4 houses max. I can't see from that view if it is single or 3 phase. Photograph it from the other side, are there 2 or 3 connections to the overhead lines? The cables on the pole with the lamp post are 240V That is probably single phase at that point.
Non-Compliant Upper Floor Windows (Low Sill Height)
ProDave replied to tg77's topic in Building Regulations
If the previous owners removed the guards, then if they had half an ounce of sense they would have kept them, ready to be put back in the event of them being needed upon sale. Have you even asked them if they still exist somewhere? -
How about this sort https://www.amazon.co.uk/Automatic-Adjustable-Stopper-Commercial-Adjusting/dp/B0DKWV536P?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3D385E63SY2UI The spring mechanism would screw to your pillar and the arm would push against the gate. Might need to search a bit harder for an outdoor version that is likely to withstand weather.
Rising but hinges (which is what the tapered washer is trying to create
Sizing ASHP according to heat loss calcs
ProDave replied to flanagaj's topic in Air Source Heat Pumps (ASHP)
You have a room thermostat somewhere. The heating will run until the rooms are warm then shut off. With a well insulated house it will be a while before it turns back on again. -
Look at the normal option, all insulation towards the outside, vapour / airtight layer, service void then plain plasterboard. None of your cables are in insulation, no penetration of vapour / air tight layer, and only the battens that form the service void need drilling or notching for cables. A service void formed with 25mm battens and 12.5mm plasterboard is perfect for 35mm back boxes.
On the subject of ridge beams etc. As you want to use most of the loft space for habitation, don't let your designer design a roof construction based on trusses. Instead insist he designs a cut roof supported by ridge beams. You have enough intermediate walls to support that. That is what we have. It then allows complete flexibility what parts are used for habitation and what are partitioned off for storage etc. And make it a warm roof make up so the insulation follows the roof line right down to the walls.
