Adrian Walker
Everything posted by Adrian Walker
Converting a drystone wall to a mortared wall
Adrian Walker replied to sb1202's topic in Landscaping, Decking & Patios
Sheep make a perfect Sunday roast. -
Passive house Shepards hut ?
Adrian Walker replied to Waterworks's topic in Energy Efficient & Sustainable Design Concepts
Crazy idea. And the stove is a no-no -
It is operationally profitable. It's interesting that it has to launch over 2,000+ satellites every year.
That's unlikely as the signal is very weak and the cost to run satellites is very high.
How old is the slab. What self levelling concrete did you use?
Is anyone actually building at the moment?
Adrian Walker replied to flanagaj's topic in General Self Build & DIY Discussion
An insulated concrete slab is better if you need a radon membrane, as beam & block can create voids where the gas will accumulate. Radon gas is a silent killer. -
Recommended Prodject Manager North Dorset
Adrian Walker replied to Garry's topic in General Self Build & DIY Discussion
What’s your budget for a project manager? -
Visqueen contract design service 😮💨
Best solution is an insulated concrete slab IMHO -
Real world feel of MVHR +heat system
Adrian Walker replied to MPx's topic in Energy Efficient & Sustainable Design Concepts
Lewis decking is a good idea, but it won't need UFH. I wouldn't use air to heat the house, it's a poor way to put heat into the slab. You want a uniform and constant temperature that only UFH can provide. I have visited a certified passive house that didn't have UFH, it's was a disaster. -
You should be looking and considering an insulated concrete slab with UFH. UFH pipes can be used to both distribute heat and cool. -
There are no benefits or advantages in DC light systems in a residential property. LEDs might be DC, but the drivers and controllers are relatively cheap, reliable and available. Overall I2R losses make it inefficient.
In Scotland and in the North of England they often don't use cellular, instead, they connect via a dedicated Long-Range Radio network at 400MHz which travels futher.
Do you have any mobile phone signal at all? If so you can ask for an T3 External Aerial to be added to a smart meter. I wouldn't take no for an answer, the national network (DCC) is required to cover 99.25% of all premises. Demand a Technical Site Survey or a physical visit. Tell them you want an engineer to test the signal at the actual meter point, not just a desk-based estimate. Additionally, when a meter is faulty or reaches the end of its life, the law states the supplier must replace it with a smart meter unless there is a valid reason not to.
Flitch beams are generally only supportive in one direction. Bifolds will have a torsion load.
I understand that it was in jest, based on the comments 🙂 However, you should never engage any professional based solely on price.
I think that's a bit harsh, especially as we have several professionals on Build Hub.
What does this architectural symbol mean?
Adrian Walker replied to Tony L's topic in Surveyors & Architects
It’s similar to a machine surface symbol. -
I presume that you have photographic proof of the construction by the builder?
