Chanmenie
Everything posted by Chanmenie
New series of Grand Designs 31st August 2022
Chanmenie replied to Thorfun's topic in Property TV Programmes
The windows were not free, he said he didnt have to pay for them until he got the mortgage money -
I’m about to start my build with Isotex, insulhub run training days at Swindon where you get the chance to have a go. it is quite straightforward so long as you follow the guidance. Do a search on here for Isotex and you’ll find a couple of builds by Tom’s Barn and Keith65 well worth a read and there’s some good pictures
Are yours attic trusses ? The roof designers said with the 222 joists and 197 rafters at 600 centres I’d be at 60% of allowable deflection, plus there will be some internal walls down the middle, non load bearing but they will stop the flex, the bit that has no internal walls will be 400 centres
Similar size to mine then, I was planning on counter batons as I’m doing the wall plates at 2.5m how wide with your upstairs rooms be ?
Any experience of Liniar upvc windows?
Chanmenie replied to Barryscotland's topic in Windows & Glazing
I had a quote for some PVC windows, it was more than Scandinavian Alu clad timber, by quite a margin You can guess what I said 😀 -
Do they span 14 Meters ? mine will span 8.7m, with 222mm joists I’m hoping there won’t be too much bounce.
I have the same question for my patio doors. So if you leave a course off which is 75mm but if the threshold is say 35mm deep what would you make up the 40mm ? Is it a case of cutting the engineering bricks lengthwise
saw this article and wondered how many potential houses could be suffering similar issues if windows not fitted correctly. I appreciate its in America but could easily happen over here. https://www.greenbuildingadvisor.com/article/rotting-walls-in-a-sip-house?utm_source=Newsletter&utm_content=GBA+eLetter&utm_medium=Newsletter&oly_enc_id=6799F8366167I0Z
Why not make it easier and remove that great big corner pillar you can easily reverse in then.
Problems with how to finish reveal with aluclad windows
Chanmenie replied to cbk's topic in Plastering & Rendering
That looks a really good solution thanks for sharing- 7 replies
- silicone render
- window reveal
HELP---Attic truss or Cut Rafters?????
Chanmenie replied to Renegade105's topic in Roofing, Tiling & Slating
I have decided upon attic trusses, the cost of the steels and then paying chippies to make the cut roof came to a very similar price, but would take much longer. My chalet bungalow not as big as your house, but the principle will be similar. -
My walls are 380mm, I went with 600mm and that’s still a bit tight, so I would go with at least 600mm, 450 with 400 walls would be a nightmare. I was lucky in that I only needed to go 700mm deep as on sand and gravel.
Passivhaus window suppliers to UK - recommendations
Chanmenie replied to markharro's topic in Windows & Glazing
Difficult to compare Ideal combi are quite different to the others, didn’t like the way the frames join together if you have an opening next to a fixed. Allan Brothers are cheapest so far but their showroom is so far away, so not likely to see their products in the flesh. Norssken were competitive but again not actually seen their product in the flesh, other than what they had in a display house at Swindon. Kloeber we’re very nice but higher end price wise I have found a local supplier for Scandinavian Alu clad timber who’s also does Reynears lift and slide doors so will probably go with them. -
Possible unauthorised development notice
Chanmenie replied to craikhill's topic in Planning Permission
Do you need bother with retrospective planning application? I built a 28 x 12 brick and tile extension to the back of my house without planning permission, when I sold the property 7 years later the buyers solicitor queried it, I said no planning permission but showed them evidence it was built 7 years previously and they were happy, didn’t suggest it was worth getting retrospective permission. -
Internal drain for tundish valve discharge from UVC
Chanmenie replied to Chanmenie's topic in General Plumbing
Thanks again @PeterWthat’s how I read it, so as I’m building with ICF (Isotex) I do have the option to use traditional method of running a copper pipe out through the wall and fitting a cage round it, or would it be preferable to use the HepVo waterless trap and discharge to an internal drain. -
Thanks @PeterW the only minimum distance I can find is the 300mm minimum length of pipe below the tundish valve before any bends, or am I missing something
