Everything posted by JohnMo
It comes out slowly, very slowly. If you are putting a wooden floor on top, you may need a liquid DPC, as moisture levels remained high in ours 18 months after the floor went in.
Trying to fix a REAL problem - not. Buy some bottled water. Or an accumulator. Storage tank means air gapping the supply, a super low pressure system.
Why unvented? Why a huge cylinder in the loft, when you have room for a plant room?
Where is the kWh price heading in 2022?
JohnMo replied to epsilonGreedy's topic in General Self Build & DIY Discussion
Wasn't talking gas price, was talking electric which is directly pegged to wholesale gas price, be wind or whatever. -
The government ultimately set the rules -
The biggest cost I have found with my self install is the piping, valves, armoured cable, and general stuff. But you are having to provide all that. I think the grant heat pumps come with flex hoses, so if all the water is within a metre no piping to install, no wiring - think they don't want the job and are pricing high.
We are being ripped off, all the energy companies are taking the p..., and the government is letting them. The pricing rules should be changed and only the government can do that. They don't care because the tax grab is great for them. -
Leaving aside the units being all messed up - if you need a 3kW or 6 kW ASHP at -2.5 you most likely end up with the same unit, once you start looking the actual performance at low temps, as not all manufactures rate their units the same, some will say the unit is 6kW, but at -7 only produces 3kW other will say 6kW but produce 6kW at -7.
Your not comparing apples with apples. Your daily usage is measured in kWh and is affected by the outside temperature, if it is warmer than -2.5 outside your heat losses will be lower - so less gas used. Your gas consumption also incudes DHW. The spreadsheet is calculating the heat power required on the coldest day -2.5, expressed in kW. So if the outside temp was at -2.5 for 24 hrs, you would require a heat input power of 5kW to keep a stable temp inside, so you would use 120kWh of energy that day
ASHP turning out to be very expensive
JohnMo replied to Venkat Rangala's topic in Other Heating Systems
Your cylinder thermostat photo 2 is set high, it is likely your heat pump will struggle to get up to that temperature and will keep trying using loads of energy. Turn down to high 40s. Do you electric immersion in buffer and cylinder are these programmed to come on at any point. Call Grant heat pumps, they have specialist for ASHP that are supposed to help with commissioning issues etc. They hold the MCS certificate for most Grant installs. Get your quote out and heat loss usage estimate, this is a design documents and if you are using more kWh than specified, Grant maybe the ones who have to fix it, even with the original installer going out of business. Where is the controller installed? Inside or outside? How do you operate the system, are you running weather compensation? What are your typical flow temp for central heating? What is the thing with the blue lid? -
Multi Utility connection providers - Central Scotland
JohnMo replied to skeg0's topic in General Self Build & DIY Discussion
If it's just the digging go to a ground contractor- 4 replies
- utility
- connections
(and 4 more)
Easy fix, shower, or don't spend ages in a bath
Octopus energy launch 'their own' Heat pump
JohnMo replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
As standard install is up to 7kW and RED start at 10kW....not likely to be RED -
Just go to SSE, they will do electric and gas. Electrical contractor just connects from meter installed by SSE to temporary consumer unit socket. Scottish water for your water, you need a temporary outside tap to their spec to connect to. If you want BT you need to contact them, they will not connect you until you need it, i.e. you start paying a standing order. But they will contact open reach and they will free issue the cable from house to pole.- 4 replies
- utility
- connections
(and 4 more)
Some heat pumps will let you run in full hybrid mode - i.e. both heat pump and boiler on together, other will not not so its one on or the other. Defrost cycle is not frost or freeze protection - very different, defrost cycle would never run with heat pump off line.. Freeze protection comes from freeze protection valves (opening the pressurised system to atmosphere to dump water) or antifreeze, the same as your your car (but a safe version of glycol).
A hot water tap outside
JohnMo replied to CalvinHobbes's topic in General Self Build & DIY Discussion
My wife asked me to install a hot outside tap the other day. Added it to the other jobs on the list - another hole to put in to my wall -
I recently went through the same thing. Also when I questioned the supplier about suitability for external use they said the C16 was not treated correctly anyway. In then the end anything suitable for external use was not in stock and had the be treated on request. So ended up with the specified C24 which was a 1 week lead time.
But is it down to building control, doesn't the mandatory installers certificate, trump building control?
There you go https://www.cylinders2go.co.uk/shop/uncategorised/telford-open-vented-300-litre-twin-coil-solar-and-heat-pump-stainless-steel-3-pockets/
50mm sounds small. My pipe going into the stove is aluminium. You can wrap in rockwool if you want. Rockwool doesn't burn
UFH controls - conventional or home automation?
JohnMo replied to Hilldes's topic in Underfloor Heating
Mine was running for a few minutes while doing central heating, then being locked out for 10 minutes, this repeated over the day.
