JohnMo
    200
Everything posted by JohnMo
  1. And how far are you running the pipe, a metre or many metres all make a difference. Insulation is important depending on where the heat may be escaping too. 60 Deg water going to heat your cylinder needs insulation. Is under the floor the only way from A to B?
  2. Certainly have, I missed out on the VAT and on the extended warranty also - by 1 day
  3. Sooner they are out of power the better - or at least I hope so.
  4. Weather compensation is when a boiler modulates its flow temp based on outside temp. You are obviously running a set flow temperature so ignore my ramblings about weather compensation (WC) Salus self balancing actuators function by reading flow and return temperature from the floor loops. They have a temperature detector on either end of each pipe loop by the manifold. Below a flow temperature of 30 deg, they (Salus actuators) manage the flow to achieve a set point point 4 deg dT (Delta between flow and return), and over 30 degs they manage this as a 7 deg dT. As more or less energy is taken from the floor (room temp change, solar gain etc) the dT will naturally fluctuate, the actuator will open and close to maintain it's internal dT set point.
  5. I would be more interested in the install, a well installed system and mediocre heat pump, will always out perform a mediocre install and fantastic heat pump. Both are good makes, what else has been quoted. Are you an open single zone system or zones everywhere? Buffer or no buffer? UFH, radiators or a mix? Viessmann tend to take the whole system approach and it's done the German way, so will come weather compensation out the box, usually well set setup. You never here them mentioned on here, maybe for a good reason.
  6. A normal UFH mixer will always mix a proportion of the return water in with supply hot water. So the WC curve never works correctly. An electronic mixer can be operated on WC or if you set to 36 degs and water based on a WC curve is only 30bit will go fully open and flow 30 no more no less. It becomes to degree self balancing. Salus actuator is trying to manage dT at a set point. If the room gets warmer the dT between floor and room reduces, so less heat is transferred to room, and therefore less energy taken from UFH water within the pipes. This is seemingly working at the moment. As a backstop, have set a second set point on the mixer so if house temp drops to 19.9 degs it then controls at 32 degs.
  7. Depends did you get a standard or enthalpy heat exchanger. The enthalpy ones recycle the moisture back into the incoming air. So no condensation will accumulate.
  8. Just had a look at them, would not bother waiting if you want to buy. Basic benefits are spring action closing mechanism, and don't need to be calibrated. Calibration occurs during the first 40 mins of being powered up for the first time, so no real advantage after that.
  9. WC and a normal manifold mixer is a waste of time, been there spent a year recording and messing with things. The mixer works against you all the time. The only way to get a mixer to work with WC is via an electric mixer. Salus self balancing actuators are pretty good, I have my UFH as a single zone but use the actuators on a few loops. I am also using an electronic mixer, set to 28 deg. The heat pump modulates on/off on low load. So the temp going to the mixer also varies. When the flow temp goes below 28 deg, you notice the Salus actuator starts to open and increase the flow to that loop, once the heat pump starts again, it closes in the flow, back to where you expect it to be. It's basically doing a good job of evening out the energy flowing into the floor by varying dT. To convert to open loop you can do it two ways 1. Set your thermostat to say 24, so loops stay open - good first step while you balance system 2. Remove all actuators and fit manual valves 3. Install a jumper on wiring centre instead of thermostat.
  10. That will get two answers, no zoning or zoning. But really depends on how you will use the system. WC requires long run times you could just balance the system on a single zone, keep it simple. Out all day house empty you may be cheaper flowing a slightly higher temperature for a shorter time period and rely on trv's to modulate the room. temperature. I would, based on my experience of starting complex and moving to more simple, start as simple as you can, zero controls. We are currently running an electric mixer valve on our UFH set to 28 degs, house temp has varied around 0.5 degs in the last couple of weeks with outside temp swings from +10 to -2. Heat pump just does it's own thing with very little load on it and no external inputs. Have a thermostat but it just increases the mixer valve set point to 32 degrees, if the house temp drops below 20. Currently sitting at 20.5.
  11. So the yield is just the figure for what the heat pump is gaining and not the total, for energy given out. So a CoP of one, would be a yield of zero?
  12. Hardcore, sand, DPM, concrete. You could add insulation between the DPM and concrete. Or heavy 3x2 slabs on a cement mix. Lits of different ways really. This what I did
  13. I got these from Amazon Roshield External Tamper Proof Rodent Boxes & Wax Bait Rat Killer. Have got though 6kg of bait so far. So some hungry mice about. But the mice seem to be disappearing, we were getting over run by them, prior to this.
  14. It is also a straight line So I have added 2 degs to B10. Moved from 7 to 9 degs. My current curve is B10 9.0 B12 8 B14 (-)16 Hea 33.5 So starts at +8 degs and down to -8 OAT. At +8 and above flow temp is 33.5 degs and at -8 it's at 42.5 deg flow temp. A kink would be better or even an additional set point at zero so it was two flat or the software made a nice curve.
  15. Was down to -1 last night the air very wet, house temp stayed pretty constant with the 28 deg flow temp, but summer house dropped 2 degs, so have added a couple of degrees to the end of the WC curve to compensate. Interesting there was only one defrost cycle all night. Think the ASHP is able to modulate down much further with the continuous drip feeding of heat into the house, so doing very little work.
  16. In Scotland the joiners do the boarding out and then it's just taped at the joints, not skimmed. Ames taper does the taping and filling at the joints.
  17. I also, bedroom window open 24 hrs 365 days per year, no heating in bedrooms. With MVHR, now window open for about 4 weeks in height of summer only. Really don't feel the need at any other time. When we talk about air quality its indoor air quality, in a city or in the country indoor air quality can be good or or bad, it really depends on the ventilation system. Many posts on here talk about mould, condensation, high CO2 in bedrooms etc. MVHR is that magic bullet that fixes those issues.
  18. Why would you want a thermostat with 0.5 deg switching hysterisis with UFH, you will end up with room temp swings of about 2 degs. Get something that has a switching hysterisis of 0.1 for way more stable temperatures. Or set your system so the thermostat effectively isn't needed except for extreme temperature swings - solar gain ect.
  19. Any area of the world, in summer, you exclude solar gain during the day, close curtains and blinds, as soon as it warmer inside than out, you purge, open windows at either side of the house to promote airflow. You do this with it with MVHR. A2A heat pump can be good for cooling. You don't need dogs that shouldn't exist in the first place, a sausage and nearly all dogs are your best friend. If someone wants in to your house they aren't going to squeeze through a small gap, plenty of other ways in. A couple of outside lights on a PIRs is more than enough deterrent. If it's not, they are coming in anyway.
  20. That was way more polite than my draft, which I deleted. Also in a single storey you can close the bedroom door and the room stays cool, has great air quality, CO2 stays below 1000ppm, so doesn't feel stuffy blah blah.
  21. Could be sensor or leak? Can you see the refrigerant side running parameters, check to see what the pressure is, if you are using lots of power, but getting no heat it could be refrigeration leak? Mine a different make, but should be similar. Design pressure (high/low) heat pump mode bar 42,8/1,3 If you can't see the pressure, you may be able to see the temperature at the heat exchanger or at the compressor.
  22. I had what looked to be similar a week or so ago. I had let the floor get very cold. Target flow temp was about 35, it wasn't moving past 30. I left it to run for hours and the temp slowly crept up. My problem the floor was just cold and the water flow heat was just being absorbed by the floor, the heat pump just looked at dT and was therefore happy. As the dT started to fall it added temperature but not until then. Check the flow and return temperature and monitor dT, see what it's actually doing.
  23. I wound start by Turning off the new UFH loops and new radiators, so you start from there you were prior to the modification. Do things methodically. 1. Switch off the upstairs radiators via thermostat and same for UFH. 2. Switch one system on via thermostat, does the ASHP startup? 3. Are you getting the correct temps yes or no. 4. Switch off everything again 5. Repeat same for other system 6. Try both systems what happens. 7. Bring on the new parts of the system one at a time, what happens? Post reply with system photos
  24. Think really until we have a suitably educated work force, we are stuffed. Really need some mechanism to make said training mandatory and more importantly meaningful. Example - A builder recently bought our digger and was discussing the house, said he could never live in an airtight house, and would never build one, because they just go mouldy and are really unhealthy to live in, and wasn't sure why I bothered. Any discussion was straight over his head, as he was convinced otherwise. Long way to go I am afraid
