Everything posted by JohnMo
Vaulted rooms - benefits and issues?
JohnMo replied to Benpointer's topic in New House & Self Build Design
We did vaulted in every room. Our lounge is 6m high with 45 Deg roof. All others rooms are 12 deg. It's very easy to do airtight details. Your roof structure can be a little more expensive and you have three options for insulation, between and under rafters, above rafter, or mostly above rafters and some between rafters. You have slightly more exposed roof area to the inside of the heated environment so a slight knock on heating costs - but nothing massive. You really want to heat via UFH, not high temperature radiators, as all the heat will end up in the roof. Do not install lights high up, other wise you need a scaffold to change a light bulb. Would I have normal flat ceiling - no way. When very high you need plenty of soft furnishings. -
That's a Shelly H&T, within Home Assistant. Shelly own webpage is pretty crude. Batch charging is using the floor as storage heater, in basic terms. Charging the floor similar to storage heater in cheap periods. We are single storey, so no real upstairs.
Don't have any issues with cold blasts of air. Generally air clings to the ceiling and by the time it gets anywhere you feel it's at room temperature. We keep the house between 20 and 21, sometimes a little warmer with solar gain. Bedrooms generally cooler, nearer 18/19. December data below. Currently batch charging the floor at night, and a day or evening top up. All UFH throughout.
My total area is 192m² Original flow rate was set per building regs, then after sign off reduced to closer passivhaus flow rates. Best guide I came across attached below. 1. Above bath, as far from door as possible and opposite side of room to shower. 2. Ceiling - about 2.5m 3. 125mm 4. Big standard adjustable extract terminal 5 Titan HRV - two times units due to layout.
Think there are just a lot of people with a little more money, than sense. Thinking because the tax payer is stumping up £7500 they are getting a bargain. Not done it, but have seen similar schemes for other heat pumps, and others on here have done it.
somewhere around 150m3/hr and boost is 20% above that. Humidity for Dec, longer it spends cold the lower the humidity seems to get, from the 10th the average daily temp has been close to or below zero
I would doubt it actually does anywhere near that. It may say that on the box, but most intermittent fans are just noise generators. Our last house said that, but when I put some tissue over the inlet it fell off. No suck going on. MVHR, mine very rarely goes in to boost these days, no steam buildup. Even if it does it's gone very quickly. When first installed on a new build we would get the MVHR boost quite often. After first year, almost never goes into boost.
Sorry to install a heat pump and cylinder to an existing UFH system - £13k - they are taking the p#ss Panasonic heat pump £2500, cylinder around £1k. Sundries £1k Or contact Cool Energy, they do a self install scheme to get the grant. They design, you install, they commission. Allows you or you plumber and electrician to install. They have a new 6kW heat pump also.
Electrician asked me Q re heat pump
JohnMo replied to CalvinHobbes's topic in Air Source Heat Pumps (ASHP)
If you don't need to run I wouldn't, if your wanting or needing heat then run it. -
MVHR - one unit or two?
JohnMo replied to SBMS's topic in Mechanical Ventilation with Heat Recovery (MVHR)
The more air you take into the house that is cold and heated up (MVHR heat exchanger, heaters) the dryer (low humidity) it gets. This normally balanced by humidity generators (people, showers, general life) the bigger the house the few the people per m² the bigger the issue. We are down to about 40% humidity after a few cold days. Got down to 35% last year. My first quote for MVHR was £10k, ended spending closer to £2k -
Go to building guidance notes, for MVHR and the rules are there. Plenty of posts on here also. Your trouble with a big house is going to be over ventilation. Big house needs big flow rates, a few very cold days will drive humidity down low, if you are not careful. Those prices are daft, but you are building a mansion so you get what you get. Hope you end up saving £350 in heating costs a year, because thats what you are paying just to buy the MVHR over 20 years. Two units (what we have) can make install easy with way shorter runs, but two sets of filters to change each time. -
More than enough to kill you and few others, if you have the hoop stress calculation wrong. Hope you did hydrotest before allow steam in the system.
Trouble is if you have a heat loss in the property of 2kW, you then require 48kWh for 24 hrs. To deliver that in day 7 hours needs 7kW input. If you had a 4kW heat pump you need 12 hrs of running.
I really wouldn't bother chasing the lowest possible temperature, you just going to end up with heat pump cycling. I could run my boiler at 36 degs or below and it cycled every 6 minutes on then off. 6 mins on, 6 mins off. The lower I went the shorter the cycle. Raised the temperature to 40, would run all day every day, never cycling on or off. Just steady running flow temp varied by 0.2 degrees. Same is true with heat pump. You need a differential between flow temp and room or you cannot dump the heat quickly enough. But as said above 100mm centres and radiators is a bit of a waste of time. You may a well do 150mm centres and have an easy life. No do a single zone, I would be trying to single zone the whole house and then run weather comp. If buying again I would look to go out and just buy a Panasonic R32 monobloc ASHP.
Are you using all three phases? Or just one in the house? 2. Our is in plant room. Some have them outside. But as temperature drops so does the battery output. Some will have inbuilt heaters. So you would need to check. 3. If it's a DC battery you need an inverter. If it's AC coupled they are already built in. 4.we have givenergy all in one, it generally provides the whole house straight out the box. Battery size and tariff. With heat pump running in cold weather the battery soon gets depleted. Charging slab in cheap periods is fine but once you get below zero, expect to charge in the evening also, otherwise it's a slippery slope of ever depleted slab energy over a few days. Then you end up running the heat pump for a lot of hours to catch up.
Just wouldn't bother with a low temperature UFH system. As room temp rises the floor output stops as soon as floor and room temp match.
- 8 replies
- underfloor heating
- limecrete
(and 6 more)
Water flowing back into the grid during a mains fail
JohnMo replied to puntloos's topic in General Plumbing
The check valve you show at the left hand dashed box -
Practical spiral layouts for UFH with closely spaced pipes.
JohnMo replied to ringi's topic in Underfloor Heating
Are putting any heat loss calculation into this design? What is your W/m² output target? Are you investing in suitable insulation below the pipes, i.e. 150mm+ of PIR or 50% more in EPS? Is screed or something else going above the pipes? A quick look at 100mm centres and a realistic heat pump flow temp of no more than 40 degs, you are looking at 62W/m². 50mm centres closer to 70W/m² 150mm centres is about 57W/m². -
Most efficient dMVHR
JohnMo replied to sonicboom's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Blauberg? Just about any ventilation supplier. -
blauberg KOMFORT-EC-LB-400-S25
On paper looks fine, 5 year warranty - but How much are filters to replace? You need to look things like that. Do they require an approved contractor install and commission to get the 5 year warranty? Is there UK technical support? Do need modbus and WiFi connected? My opinion no, install, commission, forget (except servicing). Do you need CO2 response? Not really. I would look a Titon also, UK made, UK technical support, good solid unit. -
Are you getting a grant? If so get the installer to do the UFH, it is all part of the grant allowance of £7500 -
Do a spiral - not a zigzag. Or you do an oversized bend and bring the pipes in. Why do you need such tight pipe spacing? -
Not sure I would use a smart thermostat on any boiler. Smart really just means internet connectivity, generally they are just dumb on off devices. If Baxi have a controller use that.
Insulated kitchen floor over cellar
JohnMo replied to chriz1's topic in General Self Build & DIY Discussion
You need to look and see how things connect in the cellar. If the lintel is connected to another cold source (e.g. wall then floor), the lintel will stay cold no matter how much insulation you put under it. So you may need to install insulation in house floor instead. 25mm (or more) under the floor finish would make a big difference. -
Space heating & DHW in all electric house
JohnMo replied to sammiepammie's topic in Other Heating Systems
Possibly will, but the kWh used, no matter if UVC or Sumamp would be pretty much the same on a daily basis. You have more flexibility with an UVC, you just heat to different temperature, to alter capacity. A Sumamp has defined max capacity based on PCM melt temperature, so less flexible on that basis.
