elite
Everything posted by elite
Help POE passive injector for TL-WA801N
elite replied to Jenki's topic in Networks, AV, Security & Automation
I think you need passive POE rather than active POE? A Passive PoE switch is, as you might think, very similar to an active PoE switch, with one notable exception. In PoE, the switch and the remote equipment actually communicate and negotiate the proper voltage and the pins to use for the transfer of electrical power. In passive PoE, no negotiation takes place between the two devices and power is simply drawn from the switch. PoE can supply devices up to 100m away, whereas Passive PoE is limited to 30m. -
Brilliant - thanks
I'm about to prewire for an ASHP - most likely from Cool Energy For the control cable, they specify a 3 core cable, but don't specify a cable size, am I okay to go with 0.75mm SY as I assume this cable will have little or no load?
I'd guess at wired incorrectly or a loose connection, whip the switches off (turn the circuit off first) and take some pics of what you find
I've moved to proxmox on a nuc type machine, having got fed up with SD card failures on write heavy applications. Would recommend
Be good to see a plan - I think the concern would be if there is a room that doesn't have direct access to a means of escape. On our renovation we have a study which is only accessed via the living room, and we had to make sure there was a window big enough to escape without passing through the living room. We also have to have a linked smoke in this room
Your biggest concern is probably escape in event of a fire, see section 2 https://www.gov.uk/government/publications/fire-safety-approved-document-b I'm not sure what regs are around altering the front elevation - might need approval to alter front elevation, and possibly increase thermal properties to match the wall
I don't think it is a cause for concern, but your towel rail will be trying to heat everythinig else on that circuit
You can get dual fuel ones, you just need to isolate from your main heating system when you're using the electric element
Rationalise my smart home automation
elite replied to jayc89's topic in Networks, AV, Security & Automation
Another vote for genius hub here - I have this tied in to home assistant, so the sensors are also available there -
I've not got any experience with Loxone, but have you looked at HomeAssistant or Openhab to tie your existing devices together -
Identify weak points - probably windows and doors Add mass - double layer of plasterboard or acoustic plasterboard Renting will limit what you can do, so ultimately you might better looking to move if it is unbareable. You could possibly look at sound deadening curtains - heavier and more layers better, but obviously not as effective as adding mass
https://www.juanmtech.com/location-tracking-with-owntracks-http-mode-and-home-assistant/
An app installed on her phone that will do geofencing (https://owntracks.org/ maybe?), then turn off x seconds after she joins wifi Re mesh, I'm on unifi here and can see which AP a device is connected to, assume that is possible on ASUS?
Good to know, they do look smart 🤞 they keep support, always a worry with devices tied to external services
@pocsterHave there been any issues with Andersen going into administration and subsequent buy out by Evios?
Are they using the ROW in accordance with the deeds? I don't believe there is any limit to the number times they may excercise pass and repass, though obviously that does not allow them to abuse you and your family, or require you to not to use your property as long as you are not obstructing the ROW Have you seen the gardenlaw forum? There is a lot of useful info on there
How to 'option in' home automation in future?
elite replied to Andeh's topic in Networks, AV, Security & Automation
I struggled using pir for rooms where you might sit still for long periods, the best solution I've found is checking which wireless access point our phones are connected to, though obviously this requires you to have many access points. I manage it though openhab, but I'm sure possible with others -
The best way to run network cables to upstairs?
elite replied to JohnBishop's topic in Networks, AV, Security & Automation
Difficult to advise without knowing your layout, I would look to locate your network stuff in a central location - under the stairs maybe? Then look to terminate all your CAT cables there I'm not sure I'm going to bother with COAX other than at the main TV location as everyone is now streaming, but obviously it is a lot easier to run cables during construction than afterwards. If your build allows I would recommend running some kind of coduit / ducting to allow pulling new cables easier -
I had ground elder and treated it over time by painting Glyphosate with a paintbrush, tedious, but it meant it only reached the target and as I also keep bees it kept it away from them I wouldn't worry too much about dogs after it has dried unless they have a habit of eating what you have sprayed
- 15 replies
@fletcher5555 The project has be delayed by a structural wall that needed to be rebuilt or more accurately replaced with a steel. Once the steel is in place, we'll be putting various test pits in as the property has been extended over the years.
So the lower sockets are on a proper ring? Then yes, you should be good to spur one socket from each, though I would probably extend the ring Is the junction accessible? If not I would move this to spur from a socket
Rats - Trail Cam and Poison recommendations?
elite replied to Ferdinand's topic in General Self Build & DIY Discussion
I've used Formula B in the past, and it did the trick. Make sure bait is protected from non target species and is placed in known rat runs. Also keep bait topped up until it is no longer being taken for a week or so. If using live traps, consider trapped rats can be fairly feisty, and have a plan for how you are going to dispose of them humanely or how you will transport them and where you will release them - needs to be quite some distance away and certain species should not be released. Depending on your location you my find someone who has a good ratter dog or wants some shooting practice -
Many thanks @Olf & @Gone West I'll sound out a friendly SE and then see where it is best to go from there
Thanks @Gone West The house is not on mains gas, so the plan is for heating to be provided by ASHP, my understanding is that this runs more efficiently at lower flow temps, so would be better suited to UFH than increased sized rads? How would you tackle this? Just dig out the bare earth area and fill with concrete?
