elite
    1
Everything posted by elite
  1. You shouldn't need a switch assuming you have enough ports on your router. You can configure using unifi network server (I think it's called), a cloud key or something like UDM pro. I run my router in bridge mode and have a UDM pro doing the routing, but previously I have used cloud key and the software.
  2. Not a SIP roof, but I used UPVC fascia board on my garden room, with the EPDM kerb trims added on top
  3. I'd start by checking the gutters and fixing, making sure there is sufficient capactiy to take the water from next door if they are unable to have their own down pipe Bathroom and kitchen need an extractors What temperature is the house kept at when unoccupied?
  4. I'd be very surprised if it wasn't possible to "unlock" directly on the device - maybe it was easier for them to do remote access than talk the customer through it? What was the actual fault/fault code? I have a solax inverter, it does connect to the internet to email me stats, but other than that it functions fine without connectivity
  5. I think it is meant to be vented, to prevent any build up of gas - I think there is a certain amount of leakage that is permissable and obvs you wouldn't want that to build up.
  6. You can get heat recovery extractors. Failing that you could put a fused spur in the bathroom as long as it's outside of zones and protected by RCD - I'm not a spark, so you would need to check exact regs
  7. Just make sure you double check how the power consumpsion compares to newer models and if you will be happy with noise levels if they have fans
  8. Agree on mix and match if you are on a budget - though I do like being able to manage all my ubiquiti stuff in the one place Ubiquiti do the Standard 24 PoE (usw-24-poe) which is a fair bit cheaper, than the pro, but it is limited to 1G SFP and only PoE+ rather Also keep in mind not all ports on a PoE switch always have PoE
  9. I think default holiday temp is the frost temp - this can be adjusted up to 17 in optional settings - info in the manual
  10. Nothing bad about having a switch, I'd have it at the router end though and pull two cables for the added flexibility. I always advise pulling at least two ethernet cables if you are going to the trouble of pulling one
  11. Do as @oliwoodings suggests, but in an ideal world you would avoid the daisy chaining of the switch / router, and run two cables from the back room to the router
  12. If your CF WIFI router is doing the routing / DHCP etc, you will want to do: Modem -> Router -> Switch -> back room I'd run CAT6 cable (solid copper not copper coated aluminium). If the cable is being run externally you will need external rated stuff. I'd run at least two cables - one for access point and one for the PC If the proposed access point in the back room is going to be powered by PoE you would need a switch that supports this, and provides the PoE standard used by the access point
  13. I went with Aico, but I did get staff discount through someone that works there
  14. I'm two storey, with kitchen open to lounge and diner. I've done heat alarm in kitchen, smokes in lounge and first floor landing. Additional smoke in snug which is accessed via the lounge. I've gone central-ish positioning on the ceiling for all of them. Don't recall a reg for room size, but I think they are meant to be within 7m of the door of each habitable room, but obviously not applicable if you're open plan
  15. Not a spark, but you should be able to do this with a grid 2 module yoke, wiring same as previous
  16. I went with AT from jupiter blue, but I don't think they go that big. Not fitted yet, so can't comment if it was worth it
  17. elite
    light stays on
    I've seen this before where switches with indicator lamps are installed on switches. Guess it could be a faulty/dirty switch or neutral is being switched rather than the line
  18. TV, Games Console, AV amp, streaming box. or as you say gives the option for HDMI over Cat6 if you wanted to move all the additional boxes to the network cab. That said a switch can often get you out of a hole if you haven't run enough In one of my bedrooms there are two potential TV positions, so I have cables running to both, one set I have just left in the cavity to be utilised as and when I change the room configuration
  19. On my renovation I've gone with the ubiquiti in wall access points rather than ceilings, which for me are more discrete The ubiquiti access points will plug direct into any POE switch providing the switch is capable of providing the POE spec required. I am currently running off a cheap netgear You will need a way of managing your access points, I do this via a cloud key, but you can install the software on Windows etc, or I beleive their routers have this built in. The benefit of going all ubiquiti - switch, router, access points is that you will get an entire overview of your network from the user interface. I'm sure there are other mesh networks that are of a similar quality, probably for a cheaper price and others will advise on their experiences Notes: I'd consider going to 4 cat6 behind the TVs depending on your needs - maybe only main TV position needed? I'd have at least 2 cat 6 to living, lounge, kitchen, study and garage Don't forget to provision for WIFI externally, especially if not in a good network area It is a lot easier and cheaper to run extra cables now if you think you might ever configure your rooms differently Don't forget provision for terestrial TV / radio and satellite if required
  20. I'd go with @RichardL's suggestion, but I guess it depends on what is below
  21. I've just replaced a bitumen roof on the chicken run with Suntuf corrugated polycarbonate sheets, they seem better than the really cheap ones, though they do need a fair amount of support
  22. Thanks - much appreciated
  23. On my renovation most of the ground floor is concrete, however there is a 3m x 3m area which was quarry tiles straight on to earth, which now the stairs are out I need to fill. What should I be aiming for, current thoughts are: Dig down 250mm 100mm subbase - MOT type 1?? 50mm sand DPM 100mm concrete I intend to mix on site with a mixer The entire floor will have self leveller applied after the new concrete has cured Questions: Does this sound sensible? Do I need rebar? I have ommitted insulation as the rest of the floor doesn't have any - is this a mistake? I'm not sure how to lap the DPM as the existing slab (I assume) does not have one - should I just lap it up the sides? Thank you for any tips and advice
  24. Electric chainsaw for me, so much more convenient than my old temperamental petrol one. I'm sure decent petrol ones aren't as much of a faff. Only downsides to my dewalt is it is down on power compared to petrol and it does eat through the batteries
  25. I agree sounds like an issue with the diverter. Though I am curious about what error the diverter is managing to throw on the Joule Maybe diverter and sender need rebooting if they have lost connection?
