bassanclan
Everything posted by bassanclan
Advice Needed - Bonnet Hip Tiles
bassanclan replied to ProblematicPanda15's topic in Roofing, Tiling & Slating
The bottom 10-20 rows look staright, but going along the wrong direction for the ridge point, after that the bonnets are all over the place -
That is poor, you can definitely do better -
Chimney breast removed and joist floor needs to be added.
bassanclan replied to moe's topic in General Structural Issues
Option 1 is less desirable. Removing any part of the structure which is sound has higher risk and may have unintended consequences, especially as you appear to have limited knowledge. If you follow as I said before it will provide equal stability without the risk -
Way less disruptive to follow option 2,but use your design in option 1 for the stairs area -
Bad idea to go in excess of the specified spans as it doesn't keep the floor feeling "solid"
Yes I agree. In my case the engineer from Hanson designed it based on 150 beam and gave a deflection which I felt was too high, so requested the 225 beam, (at no extra cost) which greatly reduced the deflection. In retrospect, with such a small amount of concrete topping (50-60mm) I wish there was an even thicker beam option to make the floor seem even more solid
Would you be able to move the lower door up 4mm and leave a 4mm gap nearer the floor?
How are you fixing the straps? Concrete screws? Also a spare sds drill bit wouldn't go amiss.
Buy some PAR timber and make exactly what you need
I fitted this on our utility cupboard and it does the job 2Amp 250v push to break electrical mortice switch https://amzn.eu/d/2s6oTKl
Architraves with proud door linings/frames
bassanclan replied to Brendan's topic in Doors & Door Frames
+1 electric planer and a sander to get it to 2mm -
If his screed is level then you can have no complaint, you have a problem with your existing house, the new extension is not the problem. However if its actually your existing house that's level and the new bit is out, then you have grounds to complain
Looks like old type bitumen felt rather than modern breathable membrane, never the less it is on a roll, so there are laps where one roll overlaps the next
Immersion diverter - can these confuse the app "usage" data?
bassanclan replied to MrTWales's topic in Photovoltaics (PV)
Worth checking the fuse on the fused spur of the immersion heater -
How to hide manhole covers in garden
bassanclan replied to puntloos's topic in Landscaping, Decking & Patios
Another vote for recessed covers -
I think you just need to click "change payment method" as I have had no problem
Head height is fine for storage, the stairs and dormers led me to presume it was for a home office/gym etc. You could have saved a couple of thousand by not having the dormers.
Just as an aside, have you modelled the cross section to see the useable head height in the upstair as 5.5m ridge height seems fairly low, especially after insulation etc
You could build with a wider cavity and therefore insulation, but it looks like its only the gable walls which would benefit from a wider cavity (and the garage area), so far better to build it as the architect has shown
It might be something to go with the first floor of the garage
Rotary vs cylindrical lawn mowers
bassanclan replied to Adsibob's topic in Landscaping, Decking & Patios
Cylinder mowers give a better finish to the lawn and will stripe it nicely. Rotary are easier to maintain and you can have a roller on the back to give a stripe. -
Or an old land drain
new wiring, all sockets tripping charging a phone !?
bassanclan replied to connick159's topic in Consumer Units, RCDs, MCBOs
No. Just no! -
It might be that property with a D rating had the latest available boiler fitted in 2020. The same boiler may have been fitted in 2021, but improvements in technology may have meant it was no longer considered the most efficient available. A don't know if energy ratings of boilers changed, but certainly electrical items did https://markselectrical.co.uk/connect/energy-rating-labels-have-changed.html
Narrow extension for laundry and shower room
bassanclan replied to Jilly's topic in General Self Build & DIY Discussion
If you have awkward neighbours the party wall act might make the costs too high for a small sq ft
