bassanclan
Everything posted by bassanclan
Your local decorator centre trade paint will be the best bet. Dulux, crown or Johnson, or independent like Brewers etc but you need a proper trade account to get a good price. Crown own Farrow and Ball so might be a good choice if you want a lot of their colours as they have the recipe on computer so can match it exactly
Carpet over UFH. is it special stuff?
bassanclan replied to saveasteading's topic in General Flooring
This may be helpful to someone: https://www.cormarcarpets.co.uk/tog-values/ -
Also i thickened the stud wall, partly for sound deadening and partly to get an exact fit for the 1700 shower tray
I didn't bother with a premoulded tray. Just moisture resistant plasterboard, tanking kit and then tiles and grout. Although I did use epoxy grout as I can't be doing with dirty grout
Usually double rafters around a velux, but depends on size of velux. Has a roof truss company supplied this? If not worth getting a quote from them
The wise architect groups the bathrooms together above the ground floor wc...
You need a structural engineer
Schneider lisse are my go to white sockets of a decent quality and price
Does anyone know a Balustrade supplier with this type of fixing?
bassanclan replied to Mikey's topic in Timber Frame
F Brundle nr Ilkeston -
No, just buy something from Argos if you want that sort of quality
Chimney balloon might be what you are looking for
Without pictures of the actual roof nobody can start to advise you. Have you got a selfie stick you could aim towards the offending area when you at eaves level?
Spanish style window nets?
Visually it looks better and you don't want to spend time and money making an air tight insulated house then put loads of holes for pipes in it
To fit ufh pipes you definitely don't need the house to be watertight
Use a screw from an easier switch/socket until you can replace it e.g. single light switch
I looked at a few online calculators and 16mm² kept coming up. I unearthed the incoming mains and it looks like 16mm² swa. At 2pm on a Saturday most electrical wholesalers are closed, except one which had 19m 16mm² 4 core SWA, so that was just long enough and has gone in!
If it was a fairly straight line I would put a duct with a rope in, but I don't want to risk it with the route the cable will go
Its 50ft from the house incoming mains to the proposed garage
Our existing 3 phase electric layout is as shown in the attached diagram. I am planning to demolish the existing garage and build a new one elsewhere on the plot and am digging a trench for water and electric. I'm trying to decide what size of armoured cable to run. I don't need 3 phase (for any tools etc), but I am wondering about future ev chargers Mains Supply Design.pdf
Advice Needed - Bonnet Hip Tiles
bassanclan replied to ProblematicPanda15's topic in Roofing, Tiling & Slating
I meant that the bottom fee rows are in a straight line, but if you put a string line from the ridge to the corner of the house, these bonnets (although in a straight line) would not be on the string line
