Everything posted by Pocster
First sheet down . Pushed it into the corners . Can see though when they pour the screed suddenly causing the plastic to slip and slide inwards .
Emergency question ! i assumed the vapour barrier would have a ‘ install this side facing up ‘ ( like roofing barrier ) . But it doesn’t - so it doesn’t matter ? Seems strange
Lol No dpm ; just vapour barrier to go ontop
Just waiting for foam to go off ; then will cut excess followed by foil tape all joints . I don’t know ; feels like my build consists solely of pir with some cladding ?
He said it would be more level with sand & cement
Just googled screed depth and got a variety of answers .... It’s unbonded and we will assume fibres in it .
No idea about fibres - i’ll Ask . Why would you choose sand / cement over liquid @Mr Punter ?
Lol F’ing can’t ! i think ( as the price difference is nominal ) any more benefits for choosing one over the other ?
Costs in materials and labour 130m sq sand cement £2200 60mm Liquid £2400 50mm Thoughts ???
Well ! screeders been He said sand and cement barrowed in ! ? I assumed he would suggest liquid screed like everyone uses in grand design . Apparently liquid screed material cost is naturally more expensive and isn’t as level as people think ! He was implying that the labour is cheaper than the material therefore use cheap materials ! what do we all think ? . He also said sand and cement screed has to be at least 60mm with ufh to avoid tikes cracking
Erm , which Clint Eastwood film was that ? Must have missed that one .... ?
- 22 replies
- bathroom refurb
- ferdinand bathroom
Best remove all clothing aswell to get that ‘authentic ‘ feel ...
- 22 replies
- bathroom refurb
All internal . Problem is I need to ‘shutter’ this bit for ufh and screed . Balustrade some way off ? , but yes they could drill through the lot to bolt off the steel
Lol like I know what the balustrade will be like ! Making it up as I go along Of more concern is a helical self supporting staircase . ? So essentially a steel spine that’s only fixed at the top ( to that beam ) and at the base into the floor . This I can envisage in my minds eye
So bed the fixing in the 1st base mortar and then drill/screw 2nd course to fixings ? That edge will have balustrade and also self supporting stair case will fix to it
Here’s the steel to make it clear . i just need a nice concrete base along its length ( and probably as wide ) I could just cement concrete blocks to it but i’m worried when they are drilled for fixings the vibrations will cause concrete block to disconnect from steel beam
No welding !!! ?
Hey Thanks for the replies . Not entirely sure what you guys mean . Will stick a photo up tomorrow. Did wonder if I could drill the steel and somehow bolt concrete blocks to it ...
It’s an internal steel whose function is just to provide support for the stairwell . I need to shutter the edge for ufh screed . But also need a good edge for fixing of balustrade and the actual staircase .
Hey all i need to build up a concrete plinth that happens to be on an internal steel . Whats the best way to attach concrete blocks to structural steel ? I could cement them but i’m Guessing that’s not the preferred way .... ?
Just what DO we want to build?
Pocster commented on Sue B's blog entry in 5 (2 adults, 3 dogs) go building in Dorset
And so the bidding war begins ! -
Almost ! -
That walk on glazing is affordable ????? -
Poe cameras I link mine to cloud based Mangocam ; works well for off site monitoring .
