Pocster
    29
Everything posted by Pocster
  1. Best remove all clothing aswell to get that ‘authentic ‘ feel ...
  2. All internal . Problem is I need to ‘shutter’ this bit for ufh and screed . Balustrade some way off ? , but yes they could drill through the lot to bolt off the steel
  3. Lol like I know what the balustrade will be like ! Making it up as I go along Of more concern is a helical self supporting staircase . ? So essentially a steel spine that’s only fixed at the top ( to that beam ) and at the base into the floor . This I can envisage in my minds eye
  4. So bed the fixing in the 1st base mortar and then drill/screw 2nd course to fixings ? That edge will have balustrade and also self supporting stair case will fix to it
  5. Here’s the steel to make it clear . i just need a nice concrete base along its length ( and probably as wide ) I could just cement concrete blocks to it but i’m worried when they are drilled for fixings the vibrations will cause concrete block to disconnect from steel beam
  6. No welding !!! ?
  7. Hey Thanks for the replies . Not entirely sure what you guys mean . Will stick a photo up tomorrow. Did wonder if I could drill the steel and somehow bolt concrete blocks to it ...
  8. It’s an internal steel whose function is just to provide support for the stairwell . I need to shutter the edge for ufh screed . But also need a good edge for fixing of balustrade and the actual staircase .
  9. Hey all i need to build up a concrete plinth that happens to be on an internal steel . Whats the best way to attach concrete blocks to structural steel ? I could cement them but i’m Guessing that’s not the preferred way .... ?
  10. And so the bidding war begins !
  11. That walk on glazing is affordable ?????
  12. Poe cameras I link mine to cloud based Mangocam ; works well for off site monitoring .
  13. Yeah I’m not sure what I should have to be honest . i was allowing 150mm insulation 50/60mm screed and ufh Then 20mm ( ish ) for tile and adhesive I also assumed a liquid self levelling screed . Screeder looking tomorrow see what he says ?
  14. Lol ! I’ll get murdered in my sleep before then ?
  15. So here’s the bathroom At far end shuttered section for inner timber frame for hidden cistern Directly in front where Porto loo is - the bath section . To the right shower tray area Plan is ufh and screed only go in the other area . So cistern , bath , shower dealt with at a later date ( like years from now ? ) Bit like brexit tbh ?
  16. Not priced the screed yet but can guess . Now if only I could sell some glazing to pay for it ...
  17. I believe that’s what the ufh company has said . Erm , that not the best ???
  18. Perfect ! 100mm it is !
  19. As if I know which one ! I *assumed* the depth required was pretty similar.
  20. A breaker for 40 quid !!! It would break ! Got my Hilti for that !
  21. Equation of faith goes like this : want bathroom + dont know exactly what suite + dont know what shower x not really sure how this is going to go / wife-factor Lots of variables not many constants ...
  22. Better dig it up ?
  23. Right ! It’s complicated ! Doing the ufh prep in the bathroom . How thick does the wall need to be to take a geberit hidden flush cistern ? Because we don’t know the exact size of our shower tray nor the bath type ( as in where the waste is or where the taps are ) i’m going to shutter out those areas so they have no ufh nor screed ; same for inner geberit wall . This a sensible plan given the situation? cheers
  24. I’m ok then ? . Vcl ordered for non GF
