Everything posted by Pocster
Does it leak ?
No - it’s my (expletive deleted)ing house
Manifold system versus hot return system
Pocster replied to Russell griffiths's topic in General Plumbing
You are indeed a master of photoshop skills .? -
(expletive deleted)ing amateurs !
Thanks -
Then you are a baiters utopia
I’d change that title ...
New velux is included in his quote anyway .
I know tiles lose their glaze overtime . Roofs probably not been touched in 20 yrs since I’ve owned it . Roofer also offers a 10 yr warranty so tempted to replace the tiles also . Then everything is covered in the event of any further issues .
I’ve got to get a new roof on a rental . I mean a complete removal. Then ... Strip off old tiles and felt and batten, removing all rubbish as we go Renew felt with new breathable roofshield felt and 25x50 treated batten Remove all lead work and render to all parapet walls and coping stones Renew all lead work to all walls and chimney stack and dormas to the back Use new stainless steel belcast beeds Use existing tiles and put back onto roof replacing with new as and when we need to Re-render wall back in using 2 layers of sand and cement Renew velux windows like for like (these may have to be plastered around the inside of windows if they do not come out correctly which we do not cover) To finish we will rebed new coping stones back on with a DPC Barrier We will then ridge off the roof using new breathable dry ridge kit My quote includes the cost of scaffolding and all rubbish removal from site Why replace the velux ? Or is it not advisable to make a new roof for existing velux ? Also is it worth replacing all the tiles or just reuse the existing - cost extra is 700 thanks
Only 4 ? You sure ? Every episode of her previous series she always seemed like one was about to push out .
ordered ! . I’ll get those actuators from wunda also . @ProDave needs to shut down his ebay shop ????
like this ? https://www.ebay.co.uk/itm/Underfloor-heating-wiring-centre-with-LED-Water-Underfloor-Heating-8-Zone-230v/254004013962?hash=item3b23d1ab8a:g:I5cAAOSw2~Nb~sCr
Lol only just ordered it . Can cancel it . What should I order ??
@PeterW https://www.wundatrade.co.uk/shop/home/quick-shop/wundatherm-quick-shop/controls-quickshop/actuator-auto-balancing/# Be ok with my wiring centre ?? ( I can cancel that if need be )
Ok - any particular recommendations? Appreciate they open / close quicker but as my slab will take hours to adjust to any change what other advantages do they have ??
But @ProDave said these. ?? Also with motorised how do I open and close ? I assume they don’t auto close on loss of power ( some spring solenoid type thing ) .
https://www.ebay.co.uk/itm/ACTUATOR-FOR-UNDERFLOOR-HEATING-MANIFOLD-230V-2W/322000676572?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200520130048%26meid%3D4e57802ebc61451ca437e8e9536f7f8e%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dpf%26sd%3D322000682302%26itm%3D322000676572%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithDarwoV3BBEV2b&_trksid=p2047675.c100005.m1851 These?
Yes. So my wireless sensor somewhere reports the temperature to HA. Simple code for HA to signal appropriate fibaro to activate actuator via wiring centre ( which in turn operates the pump ). I suppose in theory I don't really need the wiring centre - I could manage the pump on/off simply based actuators active or not. But I think the wiring centre makes it neater. Re-read your original response @Temp and yes Fibaro's powered off wiring centre. Also, I see 4 core + earth . As 1 fibaro will need L,N,E,S1,S2
There is no room stat connected ; it's a wireless device. So the HA would simply ( wirelessly ) trigger the Fibaro. My potentially flawed logic was the fibaro acts as the room stat i.e. just switches the actuator on/off via the writing centre. For the moment I just want to wirelessly control the fibaro which intern activates the actuator. Actually adjusting to temperature/usage of the room etc. I'll add later.
Or indeed anyway website. Most seem to have a plastic thread. Some metal ones here https://underfloorparts.co.uk/product/watts-26lc-230v-2-wire-underfloor-heating-electrothermic-thermal-actuator/#prettyPhoto
@ProDave from that website which 240v actuators would you recommend instead ( didn't realise they were plastic and yes I prefer real metal ). Let me know and I'll try and get the order changed. Cheers
Thanks Those actuators were recommended by the UHF/ASHP installer - whom inturn has been recommended on here. I'll go with them and see how good/crap they are. Nobody but me understands it anyway! ?. I didn't really want a room stat per room on the wall. What I can do easily is have a room stat on iphone/ipad etc.- so it's part of the HA and accessible ( but yes, when it goes wrong/fails no-one can fix it apart from me ). Indeed SWMBO has already said "If you die how will I control the in room music?" ; I think if I die opening the front door and turning the heating on will be bigger issues ?
I'm not quite sure what I'm asking either! ? ( I think it's called 'post and see if someone thinks it's wrong' ) Just checking I've got the basics correct. Currently no room stats. Will have z wave aeotec sensors in each room which inturn via the HA server would operate the appropriate fibaro relay switch.
Perhaps some kind of Wago junction box???
