Pocster
    29
Everything posted by Pocster
  1. Fitting was a faff but it’s on the wall with element in ( element insertion was easy ) . As I put the element in liquid came out as I displaced it . Assumed it would be oil or something but as far as I can tell just plain water .
  2. Cornish simplicity
  3. I went for z wave . Currently running surveillance station off a nas but might change to blu iris mvhr should be self activating but I might link the boost to an event ASHP again fairly self sufficient Will control the ufh off z wave relays Raspberry pi with max2play I.e squeezebox with a stereo single speaker in each room . Works great I’m less concerned on this . So freeview , kodi , cat5 to each tv - so options open I believe you can get an auto blind opener that sits on the track - I might look into that .
  4. Shhhh @Onoff hasn’t told SWMBO he can do that ...
  5. Just bought 250 mixed size grub screws off ebay for 8 quid . Best thing is they come in a box with a lid ! ?
  6. What’s annoying is I bought grub screws off ebay incase I lost any . But now I can’t find the eBay grub screws ! Ffs !!! THEY are too small !!
  7. Not fully on . Lost 1 of the microscopic grub screws !!! ?
  8. I grew a pair and went for it ?? First 2 fittings up .
  9. The rads approx 120cm by 50cm . Guess I’m wondering how high ( or low ) up the wall should it be ???
  10. Is the position relative to the electric point critical ? 2 green dots are first fitting . Horizontal green ,base of rad ( add a bit if the element was installed ) then a rough flex line .
  11. Yes fluids in . I’m tempted to just drill and fit to the wall with no element in . Remove it - fit element ;then leave for sparky .
  12. Presumably the element goes in the left fitting in the 2nd photo . I.e when on the wall would be bottom left . Just turn rad upside down . Take cap off . Put element rod in - tighten up - that it ??
  13. Got 2 of these to install . It says to install the element first before mounting on the wall . Should I let the sparky do this ? . Or would he expect that to be already done ? .
  14. Brrrrrrrr ; cold in this bathroom ?
  15. No understandy
  16. I don’t know what this is
  17. Not (expletive deleted)ing random . 2 at far end are for bath when your heads and tails with a friend ? 2 in shower are ; lower for midgets ; higher one for normal people like me over 6 ft .
  18. Gym closed ☹️ So mega grout session . Have back ache now
  19. Yeah - on the side
  20. What about on the k rend ? . Can that have a vertical cut inserted and then expansion joint inserted ?
  21. Sure . Where the cement has cracked can I get that out and refill with something ? Or must an expansion joint be a vertical strip ?
  22. The stone wall is about 15 metres long - there are no expansion joints - I know this because I built it ?
  23. Noticed a crack in the k rend . The crack continues down the cement of the stone wall . Presumably an expansion gap should of been put in . What’s a fix for render and wall ? . Just ct1 over it to stop water getting in ?? Not critical - but dont want it getting worse .
  24. All cleaned . Grouting tomorrow
