Everything posted by Pocster
Yeah I think so . Did search the forum and found some other threads on the issue . Will experiment next week ? It was just strange that the return / flow on that zone were cold after a few hours - even though actuator was on .
I’ll do more testing Monday
That’s what i would assume . But that flow / return on the actuator zone was cold
Maybe . But I’m still confused ! ( not hard to do ) . It would seem actuator powered is zone off I.e pin down . But in that case pump should be off . or I’ve got this all wrong ( ? ) . Ignoring the clever delta stuff - power to actuator means zone on or off ....??
Not sure https://www.wundatrade.co.uk/shop/home/quick-shop/wundatherm-quick-shop/controls-quickshop/actuator-auto-balancing/
If you zoom in on my previous photo the flow regs can be seen
Not on site now . The caps are on but loose I.e pin is up - zones open So I guess I’m saying I need to power the zones for heating off ? - but shouldn’t the pump be off then ???
Dirty dog ! Too early for that
The packaging??
What I’m saying is with zero power applied the actuator pin is in ; so if installed zone would be heated . So powering it closes the valve . So I’m heating all of upstairs apart from the bathroom???
Oh you thick (expletive deleted) ! Of course ALL the valves are open ! But I assume if I turn off the only installed actuator ( bathroom ) - power off will close the loop . So no heating in the bathroom ?!
Flow and return pipes for this zone don’t seem particularly warm . I assume I should be able to feel the heat at this point ??
I think it’s meant for detecting earthquakes - so perhaps you are right ?
That doesn’t mean I’m right ! The aeon multi sensors are z wave devices . Can measure movement , light , humidity , temp , vibration and 1 other thing ?
No I read up on this and thought it was a bit pointless . I’m just testing 1 zone at the moment , the bathroom . If has aeon multi sensors in it - so I can read the room temperature there .
Assuming this all works correctly what things should I take into account to control the ufh . All done via software . Do I take the external temperature and use that to adjust the ufh ? Perhaps use occupancy of a room to activate ufh ( though its slow to heat so not sure about this ) Any other suggestions to take into account ??
Ok . I left it for 5 minutes- it’s now switched the pump on .
I’ve wired this up correctly I think ? Can turn my fibaro z wave relay on and off which in turn activated the actuator ( though I broke one of the clips !! ) Pump is wired off S1 ( L1 and N ) . But when I enable an actuator ( actuator flashing led as it calibrates ) the pump doesn’t come on . It has to doesn’t it ???
Oi @joe90 you took a vow of silence!!
Ffs ! I posted a link to help @zoothorn Not directed at you @Declan52
Reminds me of the girl behind the bike sheds telling me I didn’t understand
Ah ! Haven’t got one of those . I’d add to your can’t take a joke list Be a landlord Face bankruptcy Highly judgemental of people ( see point 1 ) Highly cynical of people ( see point 1 )
Hmmmmm I’ve done most of those . Not sure what PPL is ? Does it hurt ?
Think that quote should go in the “ Self Build Bible “
Yes . I found one lying around but it’s 1 1/2” ; need quarter inch . Ordered it will try that first ?
