Everything posted by Pocster
Perhaps some kind of Wago junction box???
Preparing to wire up and automate my wet UFH I've purchased some actuators to sit on the manifold https://heatmisershop.co.uk/underfloor-heating-actuator-heatmiser-ta230/ A wiring centre https://heatmisershop.co.uk/heatmiser-uh8-8-zone-230v-underfloor-heating-wiring-centre/ Apparently it's easier to use this as it will turn on/off the ufh pump based on whether actuators are open or not i.e. one less thing for me to mess up Then to control each actuator https://www.vesternet.com/products/z-wave-fibaro-double-switch-2-gen5?utm_campaign=order-confirmation-email&utm_medium=email&utm_content=product&utm_term=link&utm_source=OrderlyEmails All 230v stuff. So! The wiring to the wire centre and pump seems simple enough, as does to the actuators. The fibaro double relay confuses me though on how this is wired to the wiring centre It's 1 fibaro for 2 zones as it's a double relay N to neutral obviously L to live Both the above on fibaro and wiring centre zone input Q1 to SL 1 for zone 1 Q2 to SL 2 for zone 2 That in essence it? Assuming that's correct I presume I should take 1 mains input to some kind of multi connector so that each fibaro comes off that; any suggestions what is best to use for that? Just a standard terminal block? Any advice or fear welcome!
I ain’t no amateur! ??
Fixed it obviously!
Nah ! She’s not leaking
we have potable water ...
Patrick Swayze is a knob and his walk on glazing leaks
No idea . SWMBO is forcing me to watch dirty dancing at the moment ? Before mr knob arrives I shall flood the basement anyway .......
Oi ! PM me ! . I’ve got everything you need girls , drugs , walk on glazing .......
They are (expletive deleted) at the best of time . But as you lot bitch about the mess I’m sure I’ll be ok
They can visit that’s not a problem. Annoying the council ( and recording the conversation) is a prerequisite! . As they tend to lie !!! .
Why’s that ? So you can access the non functional ufh in the bathroom ?
I hate them at the best of times . Today I receive the voa council tax valuation junk . I’m assuming once the tw*t visits I’ll get hopefully 12 months exemption. But how do they value for banding ? . They aren’t estate agents - do they just find a comparative property? Or ( unlikely ) some more complex method . Either way I shall tell him to (expletive deleted) himself
For sure ! Only activity you can do then is watch me . Perhaps I should setup a live camera feed . Imagine the joys that await you !!! ?
As most of you (expletive deleted) wits are in tier 4 you can just sit inside and watch a free man work ?
Holy Moly - bath taps in ! Was tricky getting it all together . Those screws are a bit long ? ; but impossible to catch the pipe . Might do a cheat for tiling this box especially on top . Just cut some pieces to slide under the tap shroud base . Going to aluminium trim the box because I want to - even though once the bath is in no one will see it .
Wee colour was SWMBO choice or as she calls it ‘biscuit’ colour
Must agree again ! Grey grout better than wee yellow
Agree ! It’s an easily accessible tile at least ! .
Ok ! I’m just thinking ahead . Sounds like a uvc for a few showers would be better
Another stupid question does an electric fed uvc draw far less current than an electric shower ?? .
It’s a hmo rental . So current wise anything else could be on . Would a photo of the cu help ?
A general question ! Is it possible to run 2 electric showers simultaneously off the CU ? . Water pressure not an issue . Just wondering if this is a big no no or depends on what the current CU setup is . Can grab a photo later . Was more worried about the loading ; don’t want anything tripping ...
