Pocster
    29
Everything posted by Pocster
  1. Sure thing . I could stick that in the wall outlet .But I’ve still got limited space to get that higher so the trap is higher ( so not hitting the drawer ) .
  2. I did a poo poo . The waste outlet on the wall is 40mm so I need a compression reducer to get it to 32mm . Prefer compression at this point as it’s all accessible . Once i solvent weld anything off the 40mm I’m committed
  3. https://www.toolstation.com/wirquin-neo-air-telescopic-bottle-trap/p58875?store=L9&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAiAo5qABhBdEiwAOtGmbgITKW8J_wSpU3BtAf0diKIgYBN19dpALUSSAsIXNr37f315w2ZcXRoCWU0QAvD_BwE
  4. That’s certainly worth a look !! ?
  5. Shhhhhhhhhhhh ?
  6. Don’t know ! How shallow are they . I did like the telescopic one - makes life easier
  7. Erm no ? Don’t remember ever seeing such a thing
  8. Christ it’s a fight ! Fittings on wall first . Then tried fittings on pan first ( at least you can just about see pipe alignment) . It’s still fighting me though !!
  9. Usually use fairy . Be he seems to have gone missing !
  10. Think of an answer that contains 2 words . The second word is “ off “
  11. Ok ; seems simple enough . Measure distance of pipe off wall . Measure distance of pipe off wc . Cut that difference off the end + 3mm
  12. Assuming if I fit it all dry I flush it and make sure no leaks . Then take it off ,ct1 , clean it up , leave it for 3 days
  13. Going to do it all dry first . Now need to read ( well look at pics ) for cutting the waste and supply pipes to the correct length . Plenty of opportunities for fs still ?
  14. Ahhhh there it is ffs !!
  15. Ok ! Phone call to geberit ! Apparently there’s an embedded grub screw in the fitting which is embedded in the pan ! I shall now go and look for it !!
  16. Yep . These are the bolt end attachments. There’s no way you can tighten with an Allen key
  17. Ehhhhhh ?????????
  18. Yeah I watched that exact video I’m obviously having a (expletive deleted)ing thick as sh*t day ( blame being a LL for that ) - I just can’t see what the Allen key connects into ( no hex receiver ) to tighten it
  19. Whilst I wait / ponder over the basin trap decided to look at the geberit pan . Hmmmmm - confusion !! ( not my day today ) . Can’t see how you tighten those bolts with the supplied Allen key - must be mis understanding something !!
  20. I thought that . Might be able to stick a flexcon on it if it won’t fit .
  21. Yeah I could do all that but you know ! At the moment it’s a choice of lesser of evils ! I always prefer more than 1 option ...
  22. Ordered ! Jtm plumbing don’t do this and said it would work . Their previous suggestion was hack the cabinet ?
  23. I was hoping it was this . I’ll leave it for a few days then start turning on other zones ?
  24. This ???? https://www.toolstation.com/viva-magna-self-sealing-waste-valve/p82878?store=I6&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAiAo5qABhBdEiwAOtGmbrFZi2H_0gIsy54sv_lRQ69SBiiDA_jUpNr5S_UN0YuCsnEs0Bw7xxoCVHIQAvD_BwE
  25. 30 I believe
