Pocster
    29
Everything posted by Pocster
  1. The washers / packers under each stringer won’t be visible when complete
  2. Head visible under the staircase - not worried about that
  3. More comfortable with those . The stringers heavy and awkward . So want to place it - drill holes without moving it away I.e drill in situ . Assume this is ok still ?
  4. Sometimes I’m brave with mains electric , sometime I’m not . Want to wire this fancy switch . Current manual switch is just the 2 browns . Where do they go on this new switch though ? ( ‘O’ is the load ? for one of them ?? )
  5. Ok Not used resin ones before ? Recommendations ? . Can I have bolts that are resin and anchor ??
  6. Got to attempt to fix my external metal staircase to the concrete wall . Been told m12 anchor bolts . Any type / brand recommendations? Also the stairs will need packing under the stringers . What should I use for external packing ? . Assume plastic window packers aren’t really going to do it . Packing maybe as much as 30mm
  7. Anyway it’s been so long isn’t it time you redid the ensuite again ?
  8. That would be stagnant
  9. Thought this thread was closed down due to lack of activity. Glad to see it’s been resurrected yet still no work will commence.
  10. I only deal in metres as you know
  11. B a s t a r d - you’ll still be paying the child maintenance
  12. My sparky let me do these . But as others have said he wanted them left off the wall so he could inspect . He’s the one signing the lot off so it’s fair enough
  13. My reputation precedes me ! ?
  14. Many years ago when expanding foam was new I bought some and filled a hole . As it expanded at a zillion times I used my bare hands to push it back in . Took months to have usable hands again .
  15. Use when the kindle has run out . Books are for peasants- I’m in a mood tonight
  16. What’s a “ book “ ?
  17. I donated more than you . That makes me a moderator in training . I am happy to say you have passed the initial test with flying colours . Have you considered walk on glazing ?
  18. Amateurs ! Even I didn’t make that mistake ???
  19. To match the walnut ‘effect’ . I bet it still looks awesome
  20. Cut backs due to brexit , Covid , climate change . Sign of the times
  21. https://www.eurofitdirect.co.uk/products/recessed-folding-coat-hook-height-80mm
  22. Rather than 36 quid each. I found some quite nice ones for 7 quid each ?
  23. Think I'll go for the veneer . Cheaper; also at the width I want they would have to biscuit join 3 pieces.
  24. ? If you stopped all your pornhub subscriptions you’d be much wealthier
  25. Yes they can do . Is “ real “ walnut worth the extra cost ?? . Will it look different/ feel different??
