Pocster
    29
Everything posted by Pocster
  1. Otherwise will use those Fischer ones as I actually have them !!
  2. Order those bolts from ffx - loads in stock . Now get an email out of stock until October ! . @Onoff find me something else !!!
  3. I’ll show you stains
  4. Shelia in town ?
  5. Looks like my bowel implant
  6. Daily as you well know “ Gimp the Spice “ - as your party name …
  7. Gimp party on the staircase maybe an issue then ?
  8. Pre hung doors look great ! . Still a lot of work . How many hours can I spend trying to get the doors aligned to near perfect . Not quite there and yes handle not straight …
  9. I’ll order the ffx ones ! . Read some bad reviews of the Fischer ones anyway ….
  10. Not so ! My solvent weld is spot on now . Get back to your gang bang shed you pansy !
  11. No expert of course . But , if I can do better then it must be real shit . As others have said stop all work getting BC to look . You sure I didn’t do it ? - can’t remember….
  12. The cheaper hooks turned up. Seem pretty decent. The 'lip' around them is maybe half a mm. So it's just as well I'm getting the walnut supplier to cut the holes accurately!
  13. https://uk.rs-online.com/web/p/masonry-plugs-anchors-fixings/6221988/ ????? for example or https://www.ffx.co.uk/product/Get/Spit-055345-3439510553459-Fix-Z-Through-Bolt-Anchor-Stainless-Steel-A4-100Mm-X-25?gclid=Cj0KCQjws4aKBhDPARIsAIWH0JX3BNFpcYhnYZktHBNgznaXMXYPXDFYxW9IhTzNeEGFRfbuRyr48BoaAsP2EALw_wcB#FPD ??
  14. Don't seem to do them any longer. I would prefer a deeper fixing.... any thing else you recommend? Just worried it's only 70mm. Remember 2 top fixings have to go through the wall lip steel then the stringer steel ( that's at least 20mm just there ). 100mm I would be happy.
  15. Ok . Did try without an airbag . But of course will try again . Been a long day and perhaps I was too tired and not thinking straight . Feel a bit sapped lately as I plough on trying to get us moved in by the end of the month …. ??? ?
  16. Struggling with this hinge . Want to simply raise the door a few mm . But just can’t get it to do it . Loosen everything as it states , put air bag under door …. Ends up lifting the door frame !! . Don’t get it ?
  17. Still waiting for comments on mine ???
  18. Absolutely. Tbh clang or not isn’t an issue .
  19. Appears to bolt direct to the wall afaik
  20. Clang ? The metal steps do have tread covers .
  21. Missed this . No RAL - just black
  22. Ok , ok ffs ! , I’ll order those . But I’ll see if they do longer ones ….
  23. Supplied bolts are indeed stamped 8.8
  24. Here’s the wall fixing bolts I’ve ordered . I’ll check the supplied bolts when on site
