Pocster
    29
Everything posted by Pocster
  1. Nah not a blog , that would be a pane ?
  2. The glass or the super posh customer? ?
  3. I am that man ! ?
  4. https://www.ikeahackers.net/2019/11/ikea-pax-wardrobe-problems.html hmmmmmmm ?
  5. SPACE-PLUG KITCHEN this for fitting to the wall . But still hate that IKEA flimsy back ! ( cardboard ffs ! )
  6. Really interesting vid I have sliding doors that sit over the frame so need a skinny infill . Even if I did manage to scribe ( !!! ) a perfect 2 metre length what should I use to fill the gap ( between wall and scribe ) caulk ???
  7. The rear I need some adjustable bolty type things to make it secure . What I hate is that the flimsy IKEA back will wobble as it’s not flush against the wall . Almost tempted to screw osb to the back …. As for that side bit ; how do I scribe some bead to suit the variable gap ??
  8. Could do …….. but he might guess what’s happening as I have 9 flat pack IKEA wardrobes on the floor ???
  9. Got lots of IKEA wardrobes to build ? and bolt together . What do I do about walls being out at the side and rear . Do I pack the rear out ? What about that side gap . Beading it won’t make it any better as it will be on the wee also …
  10. Yes . I was more concerned about the min size hatch regs - if there were any ???! ???
  11. That supports the end of the wardrobe ? It’s part of 4 all bolted together . Can’t run it the other way either . Not sure of the point of the hatch anyway . It’s a straight run flue so nothing serviceable in it ….
  12. Got my flue in with access hatch all good . Unfortunately the fitted wardrobe will literally end slap bang in the middle of the hatch ? What are the regs on this ? Hatch size I mean ? . Presumably it’s just so a carbon monoxide test could be done in the flue ? Can I wardrobe across the opening ? ( removing the hatch door of course. But access for a monoxide test still do able .
  13. I use fibaro rgbw2 ‘s ( make sure it’s that version ) for rgbw led control ;no issue . How do you intend to use these lights ? I.e how are they controlled ? ( wall switch , HA. ? )
  14. This is click bait ! Worked for me though !
  15. I put a lever valve - much easier to turn . Outside I also have a non return valve as water company insisted on one as we were going to have rainwater harvesting. That plan was binned though as ROI was around a billion years
  16. Conversion to flats ? . With an underground house in the grounds ?
  17. Buy it . I’ll lend you the money
  18. Same problem. When I’m in the bathroom sometimes I miss the toilet. - straight in the bath trap . Never dries out now ; but does smell a bit funny .
  19. I assumed my sparky would do this but he didn’t . His logic is if there’s faulty wiring you’re going to find it either way . So he just wired everything up and powered on . I did all the wiring so tbh was expecting an issue like a screw through a cable - nothing - perfect I’m so multi talented even I’m surprised ?
  20. I get called that a lot . When people see me they say “ Oh God ! “ ?
  21. No need now. All corners done. I'll get plasterer to fix it next time he's in
  22. Don't you dare get my squiffy thread locked!
  23. Nothing wrong with my tool .
  24. Yes , yes ! You buy me the Aico ones ?
  25. Sure .
