Pocster
    29
Everything posted by Pocster
  1. No ! I tried all of them - complete shite . Did a thread on it ; can’t be bothered to link edit : Used the (expletive deleted)ing search function
  2. Yeah @Onoff in one , SWMBO in the other
  3. You can get a new ring . I always worry it won’t be the exact size . So I buy a new fitting entirely as to be certain .
  4. I can beat that ! My in the ground soil pipe 110mm was filling up with 💩. So I rodded it to the next access chamber . What came out was a round head disc used on a rodding fixing !!!
  5. Sure . I *assumed* it was visible . Still want to zip tie it though . If it’s a long pipe and gets pushed out the waste pipe it’s going to be messy .
  6. Could just loop the excess pipe behind washer and zip tie again . Then it’s not cut nor visible . Depends on bravery skills 😁
  7. I think the problem is the WM waste pipe is too long . Even fully inserted in the waste pipe @zoothorn will have a big loop of waste pipe hanging out . It probably won’t make much difference tbh I.e washer will still pump it out ; but looks crap .
  8. Yeah - you can’t tell if it’s blocked . Stick mr muscle down there ; wait 30 minutes and see . Worst case no difference and you’ve wasted 5 quid or so . Much easier ( if it is blocked ) than coat hangers etc. and faffing around .
  9. Big loop is bad . Also once cut if you ever need to extend the waste pipe again you can get couplers etc. to do that . How long is the white wall pipe the WM waste is going into ?
  10. If blocked try a ‘ mr muscle ‘ type drain cleaner product . They produce a foam in the pipe and eat through any organic stuff . In my rentals ; shower gel / soap seem to be a common sink / shower blocker .
  11. I’d cut it ( but not too short ) then zip tie it or similar around the pipe and back to the machine - so it’s got no chance of coming out .
  12. Sorry about that . We got both plumbing sorted 👍
  13. Yeah . I’m not exactly sure where it will go though . Sod’s Law I place it where no noggins are . I like a biggie .
  14. @Onoff decided to re do my ufh pipework etc .
  15. Yeah , I was being sarcastic 🙄😎
  16. Ufh working then ?
  17. Definitely a rip off in my opinion . Every 12 months I just pull all pumps floats up to make sure they work . Clear any debris around the pump and float . Also have a spare pump for those “ just in case “ moments . Been doing that on my rainwater pumps for around 4 yrs - all good .
  18. I always worry about things like this . Currently in the incomplete lounge I just have 3x2 vertical to support plasterboard once ready . Really I suppose I need to fix osb or similar inbetween them for where the tv is going . Planning a big 60” ; much to swmbo’s pleasure 😉
  19. I’m going to form an EV club . You can all get to use my charger at any time at the fixed rate of 60p a kw. As well as that generous offer you also get to look at my hole . I mean hole in the ground …
  20. It will end in tears. ( or indeed even tears!)
  21. Don’t worry about it . A year or 2 or 3 … late ; no worries 😎
  22. Come see
