Thorfun
    36
Everything posted by Thorfun
  1. without wanting to sound rude but i think the answer is to find another TF company that WILL get you to 0.8ACH if that's the level you want to get to. otherwise there are things you can do but it'll cost you time and money on top of what the current TF company will charge. or maybe negotiate with them to get below 1ACH as a target. then they have the knowledge and kudos of achieving that and can then market it as a reason to choose them
  2. bought a 2.7T Kubota. great little machine but the lack of reach is frustrating. i managed to get smallish trees out with it by digging around the roots and then lifting out. it's been a great purchase and i've used it to dig our driveway, trenches, move pallets of blocks, carry materials around site and other things too. but i think a 5T would've given me a longer reach. But as @Conor says would probably be not as usable on a smaller site. for insurance i added machinery to our site insurance so it's covered under that.
  3. so no one said not to go for the cheaper Aspen pump so I'm going to go for that one. saves me around Β£500!
  4. I bought the Loctite 55 and have used it to put my water manifolds together. can't give any indication as to how good it is as they're not plumbed in or been tested yet! but it was easy to use. πŸ˜‚ I also seem to struggle with PTFE, I think mostly because I'm not as methodical as @Nickfromwales and just slap it on and turn until I can't turn any more and then realise that it's not vertical and have to undo it a bit and then it leaks and then I have to do it again and mess up in the same way. whoever thought it was a good idea for me to do my own plumbing was an idiot.
  5. welcome. sounds like a very interesting project and I know I speak for the majority on here when we say we want pictures!! πŸ™‚ many on here have built basements (us included) but I don't recall reading any with those sorts of plot size constraints. would love to hear more details of the build so far and as you progress.
  6. not used but did have a quote from them but they were too expensive to consider for us. YMMV. although they do use Norrsken windows and doors (at least they did when we were looking!) which we do have and are very good. πŸ™‚
  7. I think the TV position is more important than the sound.
  8. if the soundbar is level with your ears when above the tv then your eyes are level with the top of the TV. I don't believe that's optimal. ultimately, the height of the TV depends on the screen size, distance from the screen, height of the sofa seats, the style of the sofa even (if it's a sofa where your head slumps back then you'll be looking upwards more!) etc so every case is different. yes, a fair point.
  9. In my opinion the centre sound stage should be below the screen. If above the dialogue might keep drawing your attention higher up the wall.
  10. We had Cemfloor and the guys that laid it were really good. Nice smooth and level surface with no laitence needing to be removed and could walk on it after 48hrs.
  11. yeah, I could potentially find a place for it on the ground floor. was just thinking that if there was already a pump in the basement then I could put it in the plant room.
  12. yeah, we had these discussions earlier in the thread. it's a long way and a REAL ballache to run a pipe and @PeterW mentioned something about max distance for UVC discharge. primarily i need a pump to deal with the UVC discharge via the tundish. but i'm still thinking about a water softener which, if in the basement, needs a discharge to a sump/pump. so with the Aspen one with 2 inputs i could run both to it. assuming that the Aspen one is up to the job of dealing with the fan being hit with brown stuff.
  13. what the Aspen pump has going for it is it has 2 x inputs. so i could potentially feed another device output in to it and kill 2 birds with one stone.
  14. +1. πŸ™‚
  15. hi all. resurrecting this as my UVC is now installed and want to find a solution before the heating engineers come back to finish off. they have suggested this https://www.aspenpumps.com/en-gb/aspen-pumps/tank-pumps/hot-water-economy as a potential solution and is substantially less that this one that @TonyT suggested from BES https://www.bes.co.uk/high-temperature-pressure-relief-pump-23745/?q=23745 @PeterW? @Nickfromwales? or anyone else?
  16. I had a quote from one guy who wanted to use NuHeat. was stupidly expensive. I ended up buying the stuff direct from Wunda and doing it myself. Also, is your place a new build or renovation? what are the insulation and airtight levels like? most folk on here who have well insulated and airtight houses don't have any heating on the upper floor and they say they don't need it. are you sure you need UFH on all 3 floors? depending on the layout and insulation/airtight levels it's generally thought that electric UFH in the bathrooms is enough to heat the upstairs. might save you enough to be able to afford the ASHP here's our blog post for our attempt at laying UFH.
  17. welcome. you'll find answers to most of your questions are already on this site! as you've yet to find a piece of land you'd be wise to spend the next few months while looking for land simply reading the relevant forums. you'll soon get an idea as to the answers you're looking for. best of luck with it all.
  18. Seems expensive to me. That’s around Internorm quote we had for triple glazing iirc. Maybe shop around with other suppliers?
  19. at that price those BPS towers look an absolute bargain!
  20. just a quick Google and using Jewson as i have an account there and get a reasonable discount on hire. this tower https://www.jewson.co.uk/p/double-width-alloy-tower-2-5m-x-1-35m-x-6-05m-JTH1709L would cost me approx Β£140/week inc VAT. similar sized and labelled 'Industrial' at BPS would cost approx Β£1920 inc VAT. so if we presume you could sell it for half what you paid for it, let's say Β£950 then we're looking at breaking even if hiring for approx 7 weeks. the only thing to also take into account is the hassle of having to phone up and have it delivered every time you needed it whereas if bought it could be left on-site in a shed/garage and used as and when you want. realistically you probably wouldn't need it for a total of 49 days but it seems that Jewson only hire these for minimum 1 week period so you'd have to hire for the week even if you wanted it for a day. so that's only 7 uses over it's lifetime. i think i'll probably end up buying one nearer the time i need it but will re-asses nearer that time!
  21. i presume the 'tall' towers come in sections so you can have height's UP TO the max platform height? it does look that way from the pictures but thought i'd ask. and, if so, anyone know what height each section is?
  22. while i agree with this (caveated with the fact that i'm nowhere near close to being a professional plumber as my diy plumbing thread will attest to!) i would question the 50% less pipe for the second floor, simply because the room may not always be used as a gym. i do agree that you probably won't need heating on the 2F but for the very small cost of a bit more pipe i would simply lay it as normal and put a separate thermostat in the room so as to keep the heat down to the level required. that way if in the future it becomes a study, bedroom, play room or whatever that needs more heat than a gym you have that facility. just my 2 cents.
  23. maybe stale wasn't the right word. i've gone through previous emails and it was said that the dirtiest water is at the top of the tank so it's good to overflow that. it might be sales BS, who knows? πŸ˜‚
  24. this one seems to have the same specifications as the Boss Youngman one you linked to! so could one say that they're equivalent?
