Thorfun
    36
Everything posted by Thorfun
  1. I bought a FLIR camera. It’s brilliant and so glad I did. I’m sure it’ll be worth its weight in gold as I move forward with the build.
  2. You’ll get nothing but great reviews for MBC on here. Our friends had an MBC TF and I watched it going up and was very impressed. We would’ve gone with them but the fact we were having a basement and the wouldn’t do the foundations and we wanted to save money by insulating ourselves meant it wasn’t worth it. but….we also used the same chippie as our friends and he said he noticed some walls not plumb or square and some other slight issues that would only have been apparent later on in the build. Nothing he couldn’t overcome but thought I’d mention that they’re (and no one is) infallible. still, if I had my time again I’d pay the extra and go for the MBC twin wall TF.
  3. It’s a cliche but everything happens for a reason. best of luck moving forward.
  4. For the cost of the hole saw I’d be using a jigsaw. In fact, that exactly what I did and it all worked out well!
  5. I have a Huepar. It’s a great little unit. A few others on here also have one. Do a search and you’ll find some threads about them.
  6. your foundation costs are pretty much half of what it cost me to build a 120m2 basement sitting on an insulated raft as well as the foundations for the rest of our structure. those QS costings seem crazy to me.
  7. modern sewage treatment plants output pretty clean water. do your research and find the cleanest outputting STP and put that to the EA and see what they say.
  8. i'm going to need to drop a ceiling in the basement to cover the MVHR pipes and other things. i look forward to seeing how yours turns out. i was thinking some kind of metal frame could be used? other option was joist hangers and timbers? it is a long way off though but my mind turns to it occasionally.
  9. 🤣 well, our heating engineers are coming back to connect the UVC to the manifolds in lovely soldered copper and so I can't easily connect the pipes they've left ready and the manifold. I guess I could just put the manifolds on the wall and then attach the hep2o pipes AFTER they've been connected up with water but I'm a little impatient. also, the hep2o pipes for the cold water manifold will be underneath a piece of wood with the hot water manifold over them so connecting the cold water pipes might be a bit trickier with the lack of movement available in the pipes once covered over (if that makes any sense at all!). which is why I simply wanted to test the manifolds first and then I could connect at my leisure while I await the heating engineers to come back and finish the job.
  10. i was trying to do something correctly for a change. and the thought of unplugging >15 hep2o pushfit pipes from each manifold was something i was hoping to avoid
  11. ok. thanks. me being naive then! will make sure that my boards are flat and true when i come to fit them. 😉
  12. qq. what's the best way to test my water manifolds before I put them on the wall and attach the pipes? I have a pressure tester (https://www.screwfix.com/p/bailey-drain-air-testing-kit/19536) that I used for my soil pipes. will this suffice with a 3/4" testing plug? or is there a better way?
  13. we're a long way away from tiling but from what i've read on the tiling forum here it's very well thought of and used often. apparently it is expensive but worth it. so it's on my list of products to consider and to talk through with the tiler when we get there.
  14. surely the plasterer will get all the minor imperfections out? or am i being naive?
  15. yeah. obviously that's an approximation but i'm still very happy. all those hours, days, weeks, months fitting insulation, AVCL and taping will hopefully be worth it in the end!
  16. if i may join in here....our house isn't finished yet and isn't airtight (we have 2 openings to the garage and the garage doors are sheets of OSB on hinges (i have a piece of PIR leaning against a wall between the house and those openings). we only have heating in the basement at the moment. yesterday at about 4pm i turned off the heating as it's dry down there now and it's just using electricity for no real reason. when i left the build it was 19.6°C in the basement and 14.8°C on the ground floor. overnight temps were -3°C. this morning when i went and checked (at about 10am), the basement was at 16.8°C and the ground floor at 12.2°C. i'm pretty happy with those loses for now considering we're not even airtight and it's fricking freezing outside (Mr. Bigglesworth). so it really makes me feel good that eventually we should have an efficient and warm house with minimal heating loses. when i finally get it finished that is!
  17. build a basement with a dedicated music room. 😉
  18. this is a very valid point but for us the GI gave us soil composition, water levels, CBR rating, percolation rates, radon levels and many many other things so it was quite invaluable. the SE used a lot of the information and the CE also used it for their design of the driveway and crossover. in the grand scheme of things it wasn't stupidly expensive either.
  19. might be worth looking at an insulated slab for foundations? obviously your SE will design what's suitable but i was of the understanding that a raft/slab foundation works ok on clay. also agree with the comment on getting a proper ground investigation done. it's what your structural engineer will work off.
  20. battery storage isn't just for running an ASHP though! what about lights at night? the TV? fridge? etc. it all uses electricity that can be powered by the batteries.
  21. That’s some plot! Well done. I look forward to following your journey. thanks for the photos. I can’t wait until we’re finished and can demolish our bungalow.
  22. any photos? Timelapse video? everyone loves to see stuff being smashed up!
  23. our ASHP/UVC is a long story but after being left in the lurch I had to find someone to install the equipment that was already on-site. found a local company who did it for £3500. that's install the UVC, buffer, ASHP, electrics (although I ran the SWA cable to save a bit of money), about 10m of lagged 28mm flow and return copper pipework from ASHP to UVC and commissioning and connecting to our UFH system. they did a brilliant job and I thought it was a reasonable cost. so there are good reliable heating engineers/companies out there that don't take the pi$$ with costs. generally they've been going for a number of years and aren't just cashing in the grant schemes.
