Thorfun
Everything posted by Thorfun
Out of interest, are you going to run the house on 3-phase? We have a 3p supply but run the whole house on a single phase and so our PV inverter is also single phase and can power the whole house. If splitting over 3-phases you will have to balance what appliances use each phase PV production so, afaik, you’re more likely to “waste” generated electricity if nothing on a phase is running. It just all complicated the house electrics for me and I’m happy we kept it simple! I have run a 3p cable from the cabinet to the house so I can install a 3p EV charger at a later date if required.
Like Nick said I think you’re over complicating things just put a board up and chalk line where the cross battens are and you can’t miss! (Unless they’re screwing at a strange angle) and we pre drilled and countersunk all our service cavity battens. Got a cheap table drill and eventually got it down to a short overhead of time. But we were doing it ourselves so weren’t paying someone the extra time it took.
i hope no one gets burned financially by this. our TF company Flight Timber went out of business and i remember at least one member on here lost money because of it. i think if i were to ever do this again i would seriously consider a stick built house. could then buy materials as required through a local BM and substantially reduce risk
you da man!
only 9/10? you need to up your game mister
You sound like that CEO who lost his job and family coz he got caught on camera with his head of HR. He blames Coldplay.
Battening for Vertical Timber Cladding - Tips, Hints and FAQs
Thorfun replied to Thorfun's topic in General Joinery
i can only presume so but tbh i didn't even remember asking. i just asked my BM for 2x2 and they sent stuff over. 🤣 we used 90mm nails to fix the battens. they're also mildly galvanised afaik. but our cladding is tongue and groove and so very little water should get behind it so i wasn't worried at all. -
Openreach taking the proverbial for tree lopping
Thorfun replied to BotusBuild's topic in Electrics - Other
@BotusBuild our copper broadband is finally installed and running. In the end I raised a complaint with EE and our order was escalated on openreach and, despite this we got loads of “update by next week” type messages until the message was “Openreach need to cancel your order and then you’ll need to raise a new order which will be escalated and expedited“! once that was done we got an appointment for OR to attend a couple of days later to connect the cable and got it working. it’s taken about 8 months, although only about 5 months of that was with EE who have been very communicative throughout and it was obvious all the delays were on the OR side. I’m looking forward to seeing what the compensation I’m due will be. so if it drags on some more ask EE if you can lodge a formal complaint as to how long it’s taken and ask to have your order escalated.- 16 replies
- tree lopping
- openreach
(and 2 more)
If your inverter of choice already has certification then it should be pretty straightforward. Ours was solaredge so it was easy. but I went through this quite a while ago so can’t really remember! I think I posted about my G99 application on here though so might be some information in there if you can find it.
Drain/gulley in patio......recessed or flush?
Thorfun replied to Thorfun's topic in Landscaping, Decking & Patios
Thanks @nod out of interest is it normal to keep the square surround or ditch it and just keep the round drain top? -
got a last minute question! the groundworkers are pouring our patio slab tomorrow and we have a drain/gulley from the flat roof above that will eventually have a rain-chain on it going in to a plant pot that will sit on top of the drain. they're saying that they've set the level of the drain cover to be about 5mm below the concrete slab which means it'll be about 30mm recessed from the top of the porcelain tiles. I'm thinking it should be flush with the patio tiles. what does the forum say?
and don't forget acoustic sealant to fill all the small gaps!
I think it’s 12kW
Just standard 2”x2” for us (ends up about 45mm/47mm). No angling at all, figured that as the cladding was tongue and groove very little (if any) water would get behind. -
We used these https://www.impeyshowers.com/Wetroom-floor-formers/Aqua-Dec-EasyFit-Wetroom-Floor-Former/ made things easier to fit!
With a ducted system there is minimal drafts that we can feel. but I agree with the wall units. Careful placement is required so you’re not sitting in the draft. one regret I have is not having the money for ducted system downstairs and having to have wall units instead. But something had to give as money runs out quickly!
Extra installation costs for sure but when running it’s very efficient when just maintaining a room temperature
ultimately it depends on how much dampening you want and how much money you want to throw at it! we used Rockwool throughout and standard 12.5mm plasterboard on both sides of internal walls. we do get sound transfer but then again, it's a house and not a museum so we don't mind a bit of transfer. besides, more often than not doors are left open so no amount of sound insulation is going to fix that! 🤣 i'd suggest RWA45 personally. nicer to work with than the Isover stuff afaik and it stays in place between the studs well. we put 50mm in the walls and 100mm in the ceilings
Mitsubishi AC unit. i got a local company in to design and install it to the budget we had. as the budget wasn't limitless we had to compromise and have one ducted unit cooling both kids bedrooms which is a bit of a pain if one kid wants their room cooler than the other. but such is life.
this all equals faff! it's why i ditched the idea and just went separate AC.
there's only one solution......air conditioning. 😉
our house is cool but that's because we have the AC on! 🤣 we knew we'd want AC for the bedrooms as even with external shading things just warm up quickly and so the AC keeps us at our desired set temperature. we didn't put heating upstairs apart from electric towel radiators and ufh in the bathrooms safe in the knowledge that if we ever did need supplementary heating upstairs then the AC would do that.
Sweet spot when buying a digger
Thorfun replied to Post and beam's topic in General Self Build & DIY Discussion
i previously bought a 2.6T Kubota used it for a while to dig a driveway and some trenches and move blocks/tonne bags etc around site. i sold half of it to a friend and then eventually sold him all of it for pretty much what i paid for it. now the house is nearly complete i do need a smaller digger to help with landscaping and moving heavy things around (i'm a wimp) and so i'm looking at a 1.7T machine for around £10k inc VAT. i figure that will see me for the next 5 - 10 years and with the amount of use it will get probably won't devalue too much. in the last couple of months i've hired 2 x diggers (one 2.5T and one 1.5T) and have spent over £600 for 2 x full week hire (i didn't need it for a full week but a day's hire is stupidly expensive). i had to plan when i wanted to do the work and wait for it to be delivered etc. i feel like i've thrown that money away and i could've put it towards the purchase of a digger. having a machine on site means i can pop out whenever i feel the need to do some work. for me that's priceless as i'm a lazy ******* and am not organised at all! 🤣
